  3. SYS_AUTOSTART param missing, shown in QGC, after flashing the flight deck with voxl2_SDK_1.4.1
11 Posts 2 Posters 1.6k Views 1 Watching
  • W Offline
    W Offline
    will.huang.oksi
    To whom it may concern,
    When flashing the flight deck with voxl2_SDK_1.4.1,
    here are my steps
    Step 1
    PLEASE SELECT WHICH KERNEL TO FLASH
    1. M0054-1 -> QRB5165M, Starling (D0005), Sentinel (D0006), FPV (D0008), D0010, PX4 Dev Kit (D0011)
    Step 2
    VOXL is not yet configured for a particular SKU.
    Please select the new desired product family:
    16) flight-deck
    Step 3
    4) voxl2
    Step 4
    If you would like to select a special camera config that differs
    from the default for your product family, please select an option.
    Simply hit ENTER to use the default
    ENTER
    family code: MDK-F0001 (flight-deck)
    compute board: 4 (voxl2)
    hw version: 1
    cam config: 3
    modem config: 0 (none)
    tx config: 0 (none)
    extras config: 0 (none)
    SKU: MDK-F0001-4-V1-C3-T0-M0-X0
    Step 5
    Station mode is for connecting to a normal wifi network.
    1. leave as-is
    Step 6
    To work with the Taoglas GPS "Classic" M9N w/IST8308 - M10034 which is connected to the J19 port,
    and see the connection in the QGC,
    I made the following changes:
    in /etc/modalai/voxl-px4.conf,
    GPS=AUTODETECT
    in /etc/modalai/voxl-mavlink-server.conf,
    "primary_static_gcs_ip": "192.168.110.205",
    "primary_static_gcs_port": 14550,
    "secondary_static_gcs_ip": "0.0.0.0",
    "secondary_static_gcs_port": 14550,
    Then
    1.
    I saw
    fix type is always NO GPS even in the outdoor condition in which GPS is 3D fixed before updating to voxl2_SDK_1.4.1
    Any suggestions to investigate/fix the issues above?
    Thank you for your precious time on this matter.
    • W will.huang.oksi
      here are my steps
      Step 1
      Step 2
      16) flight-deck
      Step 3
      4) voxl2
      Step 4
      ENTER
      hw version: 1
      cam config: 3
      tx config: 0 (none)
      Step 5
      1. leave as-is
      Step 6
      GPS=AUTODETECT
      Then
      1.
      I saw
      @will-huang-oksi Don't worry about the missing parameter warning in QGC. VOXL 2 is slightly different in it's operation from standard microcontroller based boards and it doesn't use all of the same parameters which confuses QGC a bit.
      W 1 Reply Last reply
      • W will.huang.oksi
        here are my steps
        Step 1
        Step 2
        16) flight-deck
        Step 3
        4) voxl2
        Step 4
        ENTER
        hw version: 1
        cam config: 3
        tx config: 0 (none)
        Step 5
        1. leave as-is
        Step 6
        GPS=AUTODETECT
        Then
        1.
        I saw
        @will-huang-oksi Can you share a px4 flight log? How do you have the parameter SYS_HAS_GPS set?
          W Offline
          W Offline
          will.huang.oksi
          As shown below, many sections are in red.
          Are they not related to the missing parameter?
          If not, how to resolve this issue after updating to voxl2_SDK_1.4.1?
            W Offline
            W Offline
            will.huang.oksi
            Because having the missing parameter issue and a lot of sections are in red,
            the VOXL flight deck is never armed and therefore there is no px4 log.
            Thank you for your precious time on this matter, and please let me know any other log/file will be helpful.
            • W will.huang.oksi
              @will-huang-oksi You need to set some parameters, calibrate sensors, etc. to properly setup PX4 for flight. If that hasn't been done then QGC will show those tabs in red indicating that you need to address something. If you set SYS_AUTOSTART to 4001 does that make the Airframe tab change from red?
              • W will.huang.oksi
                @will-huang-oksi We have setup routines to do all of this on our drones. But if you are making your own drone then you have to know how to set those values up yourself.
                  W Offline
                  W Offline
                  will.huang.oksi
                  wrote on last edited by will.huang.oksi
                  Thank you for the feedback.
                  Before your response, I added "-w" to re-flash the VOXL and resolved the SYS_AUTOSTART issue
                  ./install.sh -w
                  Now I can calibrate the VOXL 2 flight deck.
                  If you need the flashing process log, let me know since I don't have privilege to upload any file yet.
                  NOW the remaining issue I have is no GPS fix.
                  The output from voxl-inspect-gps is
                  dt(ms) |fix type|Sats|Latitude(deg)|Longitude(deg)| Alt(m) |Vel(m/s)|HorErr(m)|AltErr(m)|
                  124.9 | NO GPS | 0 | 0.0000000 | 0.0000000 | -17.0 | 0.00 | 4294967.295 | 3794659.840 |^C
                  In voxl-px4.conf
                  I tried GPS=AUTODETECT and GPS=MRO, but none of them works.
                  I connect Taoglas GPS "Classic" M9N w/IST8308 - M10034 to the J19 port.
                  Here is the full configuration in the voxl-px4.conf
                  AIRFRAME=MULTICOPTER
                  GPS=AUTODETECT
                  RC=CRSF_RAW
                  ESC=VOXL_ESC
                  POWER_MANAGER=VOXLPM
                  AIRSPEED_SENSOR=NONE
                  DISTANCE_SENSOR=NONE
                  OSD=DISABLE
                  DAEMON_MODE=ENABLE
                  SENSOR_CAL=ACTUAL
                  ARTIFACT_MODE=DISABLE
                  EXTRA_STEPS=()
                  Also there is no output from
                  cat /dev/ttyHS0
                  cat /dev/ttyHS1
                  cat /dev/ttyHS2
                  cat /dev/ttyHS3
                  And this is what I have from journalctl -u voxl-px4 -n 100
                  -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:35:18 UTC. --
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [uORB] Advertising remote topic takeoff_status
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: Ok executing command: mc_pos_control start
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: qshell gotten: mc_att_control start
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: arg0 = 'mc_att_control'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: arg1 = 'start'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: Ok executing command: mc_att_control start
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: qshell gotten: mc_rate_control start
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [muorb] SLPI: arg0 = 'mc_rate_controINFO [qshell] Send cmd: 'mc_rate_control start'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] qshell return value timestamp: 2036903088, local time: 2036905841
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] qshell return value timestamp: 2036964219, local time: 2036966402
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] qshell return value timestamp: 2037021853, local time: 2037025239
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] Send cmd: 'land_detector start multicopter'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] qshell return value timestamp: 2037083571, local time: 2037085728
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] Send cmd: 'manual_control start'
                  Mar 02 13:31:54 m0054 voxl-px4[4783]: INFO [qshell] qshell return value timestamp: 2037144972, local time: 2037146917
                  Any suggestions or any information you need?
                  Thank you for helping.
                  • W will.huang.oksi
                    ./install.sh -w
                    In voxl-px4.conf
                    GPS=AUTODETECT
                    RC=CRSF_RAW
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=ENABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA_STEPS=()
                    cat /dev/ttyHS0
                    cat /dev/ttyHS1
                    cat /dev/ttyHS2
                    cat /dev/ttyHS3
                    W Offline
                    W Offline
                    will.huang.oksi
                    #9
                    @will-huang-oksi said in SYS_AUTOSTART param missing, shown in QGC, after flashing the flight deck with voxl2_SDK_1.4.1:
                    ./install.sh -w
                    In voxl-px4.conf
                    GPS=AUTODETECT
                    RC=CRSF_RAW
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=ENABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA_STEPS=()
                    cat /dev/ttyHS0
                    cat /dev/ttyHS1
                    cat /dev/ttyHS2
                    cat /dev/ttyHS3
                    I found a mistake
                    Previously I select flight-deck when re-flash.
                    This time with -w I select voxl2 flight-deck
                    Sorry for confusion.
                    So the only issue I have now is the GPS issue.
                    Please let me know if any questions or suggestions.
                    • W will.huang.oksi
                      ./install.sh -w
                      In voxl-px4.conf
                      GPS=AUTODETECT
                      RC=CRSF_RAW
                      ESC=VOXL_ESC
                      OSD=DISABLE
                      DAEMON_MODE=ENABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA_STEPS=()
                      cat /dev/ttyHS0
                      cat /dev/ttyHS1
                      cat /dev/ttyHS2
                      cat /dev/ttyHS3
                      I found a mistake
                      @will-huang-oksi On VOXL 2, if you enter the command px4-listener sensor_gps what do you get? (Try it a few times)
                        W Offline
                        W Offline
                        will.huang.oksi
                        #11
                        From other discussion,
                        I add
                        qshell gps start -d 7 -b 115200
                        and get the GPS now.
                        Here is my setting and please let me know if any questions.
                        GPS=AUTODETECT
                        RC=CRSF_RAW
                        ESC=VOXL_ESC
                        OSD=DISABLE
                        DAEMON_MODE=ENABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA_STEPS=(
