  2. VOXL SDK and Software
  3. Error when lunching voxl_mpa_to_ros.launch
ros
5 Posts 3 Posters 3.4k Views
  • Mohammad GoliM Offline
    Mohammad Goli
    I installed ROS on our VOXL2 machine following this guide:
    https://docs.modalai.com/ros-installation-voxl2/
    when I try to run the voxl_mpa_to_ros node, by running the below command, it runs roscore correctly but gives an error with the actual node:
    voxl2:~/$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    here is the error:
    /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node: error while loading shared libraries: libyaml-cpp.so.0.5: cannot open shared object file: No such file or directory
    failed to start local process: /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2.log
    local launch of voxl_mpa_to_ros/voxl_mpa_to_ros_node failed
    [voxl_mpa_to_ros_node-2] process has died [pid -1, exit code 127, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2*.log
    I appreciate your advice on how to fix this.
      Mohammad Goli
      To resolve the issue with the missing shared library, I followed these steps:
      Download the YAML-CPP source code archive:
      wget https://github.com/jbeder/yaml-cpp/archive/refs/tags/yaml-cpp-0.5.3.tar.gz
      Extract the archive:
      tar -xvf yaml-cpp-0.5.3.tar.gz
      Navigate to the extracted directory and create a build directory:
      cd yaml-cpp-0.5.3
      mkdir build
      cd build
      Configure the build with CMake, enabling shared libraries and setting the installation prefix:
      cmake .. -DBUILD_SHARED_LIBS=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/usr/local
      Compile the library:
      make -j$(nproc)
      Install the compiled library:
      sudo make install
      Update the shared library cache:
      sudo ldconfig
      After completing these steps, the shared library issue was resolved successfully.
      However, now when I run the launch file I get the following error ( echo: write error: Broken pipe)
      voxl2:/$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      ... logging to /home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/roslaunch-m0054-6563.log
      Checking log directory for disk usage. This may take a while.
      Press Ctrl-C to interrupt
      Done checking log file disk usage. Usage is <1GB.
      started roslaunch server http://m0054:38143/
      SUMMARY
      PARAMETERS
      • /rosdistro: melodic
      • /rosversion: 1.14.13
      NODES
      voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
      auto-starting new master
      process[master]: started with pid [6577]
      ROS_MASTER_URI=http://localhost:11311
      setting /run_id to eb195fbe-b8e2-11ef-b28f-00c0cab3a5da
      process[rosout-1]: started with pid [6588]
      started core service [/rosout]
      process[voxl_mpa_to_ros_node-2]: started with pid [6591]
      MPA to ROS app is now running
      Found new interface: hires_large_color
      Found new interface: hires_large_encoded
      Found new interface: hires_large_grey
      Found new interface: hires_small_color
      Found new interface: hires_small_encoded
      Found new interface: hires_small_grey
      Found new interface: hires_snapshot
      Found new interface: qvio_overlay
      Found new interface: tracking_down_color
      Found new interface: tracking_down_grey
      Found new interface: tracking_down_small_color
      Found new interface: tracking_down_small_encoded
      Found new interface: tracking_down_small_grey
      Found new interface: tracking_front
      /usr/bin/voxl-list-pipes: line 38: echo: write error: Broken pipe
      /usr/bin/voxl-list-pipes: line 32: echo: write error: Broken pipe
      /usr/bin/voxl-list-pipes: line 35: echo: write error: Broken pipe
      [voxl_mpa_to_ros_node-2] process has died [pid 6591, exit code -11, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/voxl_mpa_to_ros_node-2.log].
      log file: /home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/voxl_mpa_to_ros_node-2
      .log
      I appreciate if someone can provide any help on this.
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        I will take a gander at this today @Mohammad-Goli and get abck with an answer - I will say the ros1 is deprecated and we tend to support or push for ros2 - does the same issue persist with ros2?
        Mohammad GoliM 1 Reply Last reply
          Mohammad Goli
          wrote on last edited by Mohammad Goli
          @Zachary-Lowell-0
          All our robots are currently operating on ROS1, and we haven’t transitioned to ROS2 yet. Any help, advice, or guidance on this would be greatly appreciated. Thank you!
          • T Offline
            T Offline
            teddy.zaremba
            Hi @Mohammad-Goli, it seems like something on your VOXL is prematurely closing the file descriptor attached to the process that lists the pipes - I'm not sure what that is. I'm also not getting any errors with libyaml-cpp so that could be part of the problem. I'm running on SDK version 1.3.5, so I if were you I'd re-flash your VOXL and try the install again.
            Flashing the VOXL guide
            Sorry I couldn't recreate your issue. If you're still having a problem after re-flashing, let me know what SDK you tried and I'll give it a shot on my end.
            • System moved this topic from ROS
