  3. Red blinking light when connecting WiFi
m500
22 Posts 4 Posters 6.8k Views 3 Watching
  • Ward JavoronokW Offline
    Ward Javoronok
    @modaltb said in Red blinking light when connecting WiFi:
    m500 is on the same IP network as your windows machine
    Can you help me set up m500 on the same IP network windows machine over a video call?
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hey @Ward-Javoronok , before a call we need to get some basic functionality setup on your end that has a lot of good documentation.
      One thing to note, is you can use a USB cable to get a connection between the m500 and QGC if you don't want do deal with networking.
      This "USB to QGC" connector (likely this connector is blue on your end):
      If you want to continue with the networking route:
      • Can you "adb" onto the m500? We can use this to update config files. If not:
        https://docs.modalai.com/setup-adb/
      • Are you using the m500 in "Access Point" mode or in "Station" mode? If out of the box, then you are using "Access Point".
        https://docs.modalai.com/wifi-setup/
        Ward Javoronok
        Thanks for working with me. Is ADB: android debug bridge? I’m using the out of box mode. I guess it’s access point.
        • modaltbM Offline
          modaltbM Offline
          modaltb
          No problem! We are generally on Ubuntu so our docs are geared towards that, but we test on Windows setups, and besides the possible firewall issue (if using WiFi), then it should be OK.
          Yes for android debug bridge on windows, check out this: https://www.xda-developers.com/install-adb-windows-macos-linux/#adbsetupwindows
          I also forgot about a video that walks through the WiFi setup, it's using the 'guts' of the m500, but is relevant: https://www.youtube.com/watch?v=bQraPU4pFiY
          Ward JavoronokW 1 Reply Last reply
            Ward Javoronok
            I'm not good at this stuff yet but I will learn from you and share my learning with others. I'm excited to get this thing flying. I have spoken to Chad about my plans in building a solution for a large retail customer in Atlanta. I'm a sales guy hungry to learn this stuff and will be a good student of your direction. Forgive me if I ask novice questions.
            • modaltbM modaltb
              Ward Javoronok
              @modaltb Do I need an Android devise to download ADB? I don't have an Android devise. Do I need ADB to connect the drone or program the drone?
              • modaltbM Offline
                modaltbM Offline
                modaltb
                Hi @Ward-Javoronok ,
                No need for Android, you can use Windows, you can install adb using this link: https://www.xda-developers.com/install-adb-windows-macos-linux/#adbsetupwindows
                The "Android" term is used because the VOXL hardware is based off an Android phone in many ways, and these are developer tools used for this type of hardware.
                If you just need a connection to QGC, you can use the little 4-pin JST to microUSB cable adapter that shipped with the m500 and connect it here: https://docs.modalai.com/flight-core-connections/#usb (note, you connector might be blue).
                So if you just want to setup the Flight Controller (PX4), you can simply use this connection and avoid ADB.
                  Ward Javoronok
                  I plugged in the JST microUSB connection into my computer with QGC opened. QGC does not see the m500. I tried to set up vehicle firmware but it is not QGC is not recognizing anything. I tried unplugging and plugging it in with QGC opened and tried rebooting QGC but neither worked.
                    Ward Javoronok
                    Can we do a short video call now please?
                    Adrian HidalgoA 2 Replies Last reply
                    • Ward JavoronokW Ward Javoronok
                      Adrian HidalgoA Offline
                      Adrian Hidalgo
                      @Ward-Javoronok I'd be more than happy to do a video call with you. We can do a google meet if that works with you. You can join me here:
                      To join the video meeting, click this link: https://meet.google.com/omu-vzvt-bhb
                      Otherwise, to join by phone, dial +1 585-286-3199 and enter this PIN: 465 086 254#
                      To view more phone numbers, click this link: https://tel.meet/omu-vzvt-bhb?hs=5
                        Adrian Hidalgo
                        @Ward-Javoronok Let me know when's a good time and we can chat
                          Ward Javoronok
                          Great. Can we do tomorrow at 12 PM ET, 9 AM PT? If not, please suggest a call Tim tomorrow. I’m pretty much open tomorrow. Thank You!
                          • Adrian HidalgoA Offline
                            Adrian Hidalgo
                            Tomorrow at 12ET, 0900PT works perfectly!
                            Talk soon
                              Ward Javoronok
                              Great. I’ll join the Google meet link.
                                Adrian Hidalgo
                                wrote on last edited by Adrian Hidalgo
                                #21
                                Link to set up & first flight: https://docs.modalai.com/voxl-m500-getting-started/
                                There is no app, only url for this forum
                                  Ward Javoronok
                                  Got it. Thanks.
