    Product Selection
    • M
      muleworks
      We are currently using Cube Orange flight controller with ArduPilot software for our large septacopter cargo UAV with a 200 lb payload. We want to switch to one of your flight controllers. Which one would you recommend for our type of UAV and function?
      • M
        muleworks
        I am assuming the following will work:
        1. VOXL® 2 - Board Only - ECCN: EAR99, NLR
        2. VOXL Cellular LTE and USB hub add-on - V2 North American Carriers Sierra WP7610
        3. VOXL & VOXL 2 Microhard Modem Add-on with USB Hub
        4. VOXL 2 WiFi Add-On Kit
        5. VOXL 2 USB3.0 / UART Expansion Adapter
        6. Wall Power Supply with 12V/3A XT60 Output
          tom admin @muleworks
          @muleworks Choosing between 2-4 really depends on how you're going to be communicating to your ground station, whether it is via a cellular network + VPN, microhard point to point, or just WiFi
          • M
            muleworks @tom
            @tom Thank you for the response. Besides the communication method selection, nothing else is needed, correct?
              @muleworks If you're using voxl2 as your flight controller you'd likely want to use one of our ESCs as well, you'll also need an APM in order to power the board, this ESC has one built in: https://www.modalai.com/products/m0138?variant=47413130101040
              • M
                muleworks @tom
                @tom Thank you.
