  3. Image streamer
Image streamer
6 Posts 3 Posters 1.5k Views 2 Watching
  • G Offline
    G Offline
    gauravshukla914
    We recently got the VOXL flight deck. And we are in the process of setting up everything. Currently, we are stuck in this issue where we are trying to stream the image using Stream with voxl-image-streamer. And we are continously getting segmentation fault error and also we are unable to run the python image viewer script. It just opens a GUI with a black screen. I have attached the images for your reference. I have followed the steps prior to this to set up everything. Could you please let me know any possible solution to this? Thanks.
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @gauravshukla914 ,
      Are you OK with using a different client to view the data?
      That set of tools is near deprecation.
      voxl-rstp along with something like VLC works nicely for viewing and is found here: https://docs.modalai.com/voxl-rtsp/
      • G Offline
        G Offline
        gauravshukla914
        Thank you @modaltb for your suggestion. I did try the rstp solution and it seemed to work for camera mode 0 (high res) and camera mode 2(tracking camera), but for for stereo camera, I'm getting this error (attached the picture).
        • modaltbM Offline
          modaltbM Offline
          modaltb
          Hi @gauravshukla914,
          If voxl-vision-px4 is setup for VOA it will connect to the stereo and 'take over', if that's the case can you try the following before launching?
          systemctl stop voxl-vision-px4
          FYI for the future, the MPA architecture (https://gitlab.com/voxl-public/modal-pipe-architecture) will provide 'fan out' and allow multiple clients for a given camera.
          • G Offline
            G Offline
            gauravshukla914
            thank you @modaltb was able to see it now
            • K Offline
              K Offline
              kiprock
              I'm having same issue. Might want to update the documentation.
