  2. Software Development
  3. AprilTag Relocalization
  4. Hires With AprilTags
Scheduled Pinned Locked Moved AprilTag Relocalization
6 Posts 2 Posters 4.1k Views 1 Watching
  • jacob yaacubovJ Offline
    jacob yaacubov
    Hi guys i have a hires IMX412 mounted on my drone , my camera is looking to the right side of the drone (Positive y axis on the local frame)
    I have configured the tag rotation matrix from tag to fixed correctly my tag is hanged on the wall.
    but seems the drone rotating 90 degrees CCW, I guess its doing this since it assumes the camera which is catching the tag, is mounted at the front
    hence, when right side camera sees the tag it rotates to the left (ccw) to "fix" this!
    I tried to add extrinsics to extrinsics.conf both from IMU to hires and from body to hires with the correct camera name (which used in voxl-camera-server)
    but it has no effect
    any one had this issue ? any suggestions ? does the voxl code is really taking into account that tags are seen only in front of the drone (X axis)
    jacob yaacubovJ 1 Reply Last reply
    • jacob yaacubovJ jacob yaacubov
      jacob yaacubov
      @jacob-yaacubov the picture describes TOP VIEW the tag is attached to a wall
        @jacob-yaacubov , it seems the voxl tag detector sends out the tag info with respect to the camera (not drone) frame : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tag-detector/-/blob/master/server/main.cpp
        You can check the consumer of the tag data to see what transforms it is using to put the tag in the global frame.
          jacob yaacubov
          wrote on last edited by jacob yaacubov
          basically the consumer is the vision hub
          specifically [https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/v1.7.3/src/geometry.c?ref_type=tags](link url)
          as far as i understood
          and i am trying to fix the right part
          the issue lies in this transformation i marked red .. i think i need to change the cam_wrt_to_imu since it looks like
          the code assumes my hires in looking forward of the drone while its actually mounted on the right side ( Local frames Y axis)
          so tag works well and detection of my tag on fixed is Ok but when afterwards drown is moving with just qvio without tag the axis are flipped
          voxl-vision-hub -g output
          example
          y can see that fixed_wrt_local x=-0.83 while it corresponds to the local_wrt_fixed y= 0.83 so the frames i get from both arrow in the pic above are not the same do you have suggestions where should i start with , should i modify the geometry.c?
            example
            @jacob-yaacubov , I am not 100% sure but it looks like the code assumes that the tags are being detected by the same camera that is doing vio (tracking camera). In your case this assumption is not true, because you are using Hires camera for the tag detection.
            I need to check with @James-Strawson about this, but he is out of office. I will ask around.
              jacob yaacubov
              @Alex-Kushleyev yes seems like it, thank you!
