  2. FAQs
  3. 360 avoidance
360 avoidance
Scheduled Pinned Locked Moved Unsolved FAQs
5 Posts 3 Posters 3.1k Views
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    If I wanted to get 360 degree obstacle avoidance. What is the recommended path to do so?
    front and back stereo depth? two TOF? outside sensor?
    ModeratorM 1 Reply Last reply
    • wilkinsafW wilkinsaf
      @wilkinsaf is this for indoor or outdoor avoidance?
      wilkinsafW 1 Reply Last reply
      • ModeratorM Moderator
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @Moderator Indoor
        James StrawsonJ 1 Reply Last reply
          @Moderator Indoor
          James StrawsonJ Offline
          James Strawson
          @wilkinsaf voxl-vision-hub's configuration file can be modified to subscribe to multiple sources of relevant data. By default it it set up to consume point cloud data from voxl-dfs-server (stereo cameras on Sentinel and M500), TOF data from PMD TOF sensors (Seeker, Starling, and Starling 2), as well as VL53L1CX mini rangefinders. Data from all concurrent sources are merged together and passed to the autopilot as an obstacle_distance message over mavlink.
          Multiple of the VL53L1CX rangefinders can be set up using the open-source voxl-rangefinder-server https://docs.modalai.com/rangefinders/
          However, you can integrate any sensor you like by publishing one of the above 3 MPA types that voxl-vision-hub can consume.
            wilkinsafW Offline
            wilkinsafW Offline
            wilkinsaf
            @James-Strawson This is perfect! Thank you James!
