  3. AT commands to a Sierra Wireless EM9291
cellular
42 Posts 4 Posters 29.0k Views 4 Watching
    @groupo /dev/ttyUSB0 only enumerates if the driver recognizes the hardware of having said capability. In this case, the driver that controls that port doesn't recognize that modem hardware, likely the driver is from before that hardware existed.
    In these cases we usually have to make custom tweaks to the linux kernel drivers in order to add the support for the hardware.
    If you'd like to experiment with doing that you can, building custom kernels allows adding custom support for new or existing hardware.
    You can read more about building a custom kernel here: https://docs.modalai.com/voxl2-kernel-build-guide/
    groupoG Offline
    groupoG Offline
    groupo
    @tom I will explore the kernel stuff.
    Re updating qmicli, I need meson >= 0.53.0 which is not supported on drone's ubuntu version. Is upgrading to a newer ubuntu on the drone an option?
    • groupoG groupo
      @groupo It is not. Ubuntu 20 is on our road map but that's a while out
      groupoG 1 Reply Last reply
        groupoG Offline
        groupoG Offline
        groupo
        @tom If I solely wanted to update the driver that controls that port is making a custom kernel the only way to do that? If that is the case, what is the least invasive way to do that? Where does that driver exists and what is the process for updating it? Which driver is responsible for that port? It looks like the guide shows you the things to download if you wanted to make your own kernel, but where do you change stuff to make it your own?
          groupoG Offline
          groupoG Offline
          groupo
          @tom Found the drivers I believe I want to change. Do i change them inside or outside of the docker?
          • groupoG groupo
            #30
            @groupo , all the source code for the kernel will exist on your host system. When you enter the docker container, it maps your current directory into the docker container. qrb5165-sync.sh and qrb5165-patch.sh commands (executed inside docker) will download all the required sources to the shared folder and will be accessible on host system and inside the docker container.
            You should make sure you can build the original kernel according to the standard instructions (sync, patch, build). Then make change to your driver either manually or apply your custom diff / patch and build again (do not sync or patch the whole project again).
            groupoG 2 Replies Last reply
              groupoG Offline
              groupoG Offline
              groupo
              wrote on last edited by groupo
              #31
              @Alex-Kushleyev @tom
              Yeah I was able to sync, patch, and build successfully. When making those changes, is it done inside or outside of the docker? I can see the drivers I want to change in qrb5165-kernel-...sh, but that is outside the docker. I dont find the driver files insiede the docker.
              For any driver I want to edit, my understanding is that I change it in the qrb5165-kernel-...sh folder outside the docker, then I go into the docker and build. Is that correct?
                groupoG Offline
                groupoG Offline
                groupo
                #32
                hey have made some good progress on the drivers - still curious about the docker question but because they are mounted, does it not matter which side of the docker (inside or outside) I change them?
                anyways other question:
                I see in the repo README it discusses debug messages, and I can see debug msgs in the code for drivers like below:
                How can I print these out/where are they printed so I can read thru them?
                • groupoG groupo
                  @groupo , it does not matter where you edit the files (inside the docker container or the host). On the host side, there will be a new folder created for the kernel source files (workspace), where you can find all the source files and build output. In the docker container, the same files will be in /home/user/build_mount, as specified here : https://gitlab.com/voxl-public/system-image-build/qrb5165-kernel-build-docker/-/blob/qrb5165-ubun1.0-14.1a/docker-run-image.sh?ref_type=heads#L9
                  If you build the kernel in debug mode, you can use dmesg command to print out all the kernel messages. Even with non-debug kernel, there will be some essential messages from kernel there. If you are looking for a particular string, you can use grep to filter the messages:
                  dmesg -w | grep "Num Interfaces"
                  If the messages from your driver have some common string, you can use that string to filter the dmesg output.
                    groupoG Offline
                    groupoG Offline
                    groupo
                    Thanks for the explanation - I am still getting the hang of Docker.
                    I think logging was turned off in all the drivers I am curious about. I think I just turned it on.
                    Do i need to run ./qrb-clean.sh every time before I run ./qrb-build.sh? I see you use it in the example on the documentation, but I am unclear if its necessary for what I am doing (make changes -> build -> flash -> repeat if not working)
                    • groupoG groupo
                      @groupo,
                      When in doubt, it is better to do a full clean before re-building. Especially when you are changing configuration like debug or non-debug version of the kernel.
                      For simple changes inside your kernel module / driver, you can test by trial and error to see if you need to re-build when you make a small code change. Once you have the debug prints working, this will be easy to test.
                        groupoG Offline
                        groupoG Offline
                        groupo
                        #36
                        Some further investigation, I grep'd inside the docker for one of the driver files I am trying to edit (qcserial.c) and find it in a few locations, all of which are in the build_mount.
                        I vim'd all files and none of them reflect the changes I made to qcserial.c located in qrb5165-kernel-v1.1.7.4.... am I changing this file in the wrong place?
                        Again, my process is
                        • Change files in mydir/qrb5165-kernel-v1.1.7.4
                        • Enter mydir/qrb5165-kernel-build-docker-qrb5165-ubun1.0-14.1a
                        • run ./docker-run-image.sh
                        • (in docker) run ./qrb5165-build.sh
                        • once that is done, I follow the steps listed here https://docs.modalai.com/voxl2-kernel-build-guide/#flashing-guide
                        I assume I am not changing qcserial in the right place?
                        Also, one of the places Grep returns is in patches. I can see you guys have made edits to that driver too. Will the version in patches override anything else I try to do?
                        • groupoG groupo
                          @groupo , I will ask my colleagues to help answer this question..
                          Are the changes that you are making being undone after you run the build? This will tell you if the build process is patching the files again, but i would assume that the patching step (/qrb5165-patch.sh) applies the patches and no more patching is done.
                          You can look at what the patch is doing and modify the file that is the patch is patching. and then clean and rebuild.
                          Another way to check if your change is being compiled or not, is to modify the .c source file and add something with a syntax error (some stray characters), so that the build should fail. If the build does not fail, then your changes are not being compiled.
                            groupoG Offline
                            groupoG Offline
                            groupo
                            #38
                            @Alex-Kushleyev No there are no changes to the files in mydir/qrb5165-kernel-v1.1.7.4
                            I am not sure what my drone shipped with, but I assume 1.1.3 or 1.2 as we received them in May. I did have to reflash at one point and grabbed SDK 1.3.0. I followed the kernel build guide to the letter, which has steps for 1.1.3 and tags 1.7.4. I assume this is another issue of mine. It looks like I need tag 1.7.8 for SDK 1.3.0... can you confirm? Do all the steps defined in kernel-build-guide still hold save the tag differnece?
                            the c syntax error is a good idea. I will try that once I get back to a workable state
                            for clariity here is what my start up screen says
                            looks like my image and voxl-suite are good, but I def followed the kernel steps for 1.7.4 so that kernel I just put on there I believe is outdated - if you think that would matter.
                            • groupoG groupo
                              groupoG Offline
                              groupoG Offline
                              groupo
                              @Alex-Kushleyev You can ignore most of my last post - I believe I understand now that running qrb-sync just pulls all assets (qrb5165-kernel, voxl2, etc.). I pulled them myself and had them sitting outside the docker on my host machine making changes assuming somehow your build script was mounting them. I am running out of time today but I do believe that when I went through through the kernel build steps and flashed the drone it did not work properly. I want to repeat the drone flashing process again to ensure I am not missing something before I broach this though
                              • modaltbM Offline
                                modaltbM Offline
                                modaltb
                                @groupo jumping in a bit and hopefully am in context.
                                We do mount from host to docker here:
                                During the build, you'll get 'copies' of everything at something like:
                                qrb5165-build-docker/workspace/qrb5165-ubun-1-0_amss_oem/lu.um.1.2.1/apps_proc/build-qti-distro-ubuntu-fullstack-perf/
                                Don't edit those...
                                If you edit files in say this dir directly:
                                apps_proc/src/kernel/msm-qrb5165-4.19/drivers/
                                Then they should get picked up by the build. Easy way to tell, throw a compiler error on purpose in a file and try to build it.
                                • modaltbM modaltb
                                  Don't edit those...
                                  groupoG Offline
                                  groupoG Offline
                                  groupo
                                  #41
                                  @modaltb hey Travis, thanks for chiming in. I can confirm that throwing in a syntax error in files in that path does break the build - so now I know where those changes need to be made. I appreciate the clarity.
                                    groupoG Offline
                                    groupoG Offline
                                    groupo
                                    hey not sure if this is an @tom or @modaltb inquiry, but when following the steps for the kernel build guide, stuff is off with the drone. It boots up and I can adb fine, but there are issues with the wifi, similar to another post Tom helped me with two weeks ago, but for definitely not the same hardware-related reason. The wifi adaptable does not turn on and when you run voxl-wifi the mac address is undefined. I remember stepping through those scripts while troubleshooting the hardware issues and recall that script queries to find its mac address, which must be returning something invalid.
                                    I have tested this with both of my drones. I can very easily flash them back with https://docs.modalai.com/sentinel-factory-reset/ and they operate as expected. While my desire is to edit part of the usb driver scripts, the kernel I am attempting to put on the drone is the unchanged version following the steps here https://docs.modalai.com/voxl2-kernel-build-guide/. The only deviation from the guide is that the guide is written for SDK 1.1.3. I have put 1.3.0 on both of my drones, and from my understanding the docker scripts pull the default branch of each repo which has the same commit tags as 1.7.8. I have included the output of dmesg for both the 1.3.0 image available from the downloads page, and the results when following the custom kernel build steps.
                                    https://drive.google.com/drive/folders/14L5gLbAOfF2OcSW2rHFTI4VIoREkTCFJ?usp=sharing
