  2. VOXL Compute & Autopilot
  3. VOXL Flight
  4. voxl-io & I2C
voxl-io & I2C
Scheduled Pinned Locked Moved VOXL Flight
5 Posts 2 Posters 1.1k Views 2 Watching
  • T Offline
    T Offline
    traffic_light
    wrote on last edited by traffic_light
    Hello everyone,
    Currently I'm developing some software that will talk, over I2C, to a self-build powermodule with a microcontroller onboard.
    This software is a node for ros and runs in a docker.
    When it received the batterypercentage from PX4 it will start sending and receiving data to the powermodule.
    The part that receives the batterypercentage works great.
    The only problem is that I receive a linker error when I'm building the software with the I2C commands
    Error's:
    CMakeFiles/powermodule_node.dir/src/powermodule.cpp.o: In function `PowerModule::OpenI2CDevice()':
    powermodule.cpp:(.text+0xbc): undefined reference to `voxl_i2c_slave_config'
    powermodule.cpp:(.text+0xd0): undefined reference to `voxl_i2c_init'
    collect2: error: ld returned 1 exit status
    powermodule/CMakeFiles/powermodule_node.dir/build.make:165: recipe for target '/root/yoctohome/peter-dev/control/devel/lib/powermodule/powermodule_node' failed
    make[2]: *** [/root/yoctohome/peter-dev/control/devel/lib/powermodule/powermodule_node] Error 1
    CMakeFiles/Makefile2:1551: recipe for target 'powermodule/CMakeFiles/powermodule_node.dir/all' failed
    make[1]: *** [powermodule/CMakeFiles/powermodule_node.dir/all] Error 2
    Makefile:138: recipe for target 'all' failed
    make: *** [all] Error 2
    Invoking "make -j4 -l4" failed
    I already tried a lot of option.
    Some options i already did:
    • Include a lot of header and cpp files into the includes folder
    • Building the voxl_io in a docker on my pc and move the ipk to the voxl
    The hardware is a voxl_flight and I'm using the I2C port 6 (located on the J7 header)
    I don't know what to do for now so I'm searching for help. I can't find anything that helps me with my solution and the docs of modalai doesn't have a lot of information about I2C usage.
    Here a part of the code that's opening the i2c:
    int8_t PowerModule::OpenI2CDevice()
        if (I2C_is_open_)
            // I2C bus is already opened. Return -2
            return -2;
        if (voxl_i2c_slave_config(I2C_bus_id_, I2C_address_, 400000, 1000) == 0)
            //return -3;
        int8_t response{0};
        response = voxl_i2c_init(I2C_bus_id_);
        if (response == 0)
            I2C_is_open_ = true;
        return response;
    Thanks in advance!
    (I'm sorry for my English 😉 )
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @traffic_light ,
      Are you building your application in the voxl-docker or on target (e.g. on VOXL)?
      Is it possible to post your CMakeLists.txt file here? It looks like it's failing to link to libvoxl_io.
      Here's an example file where we build some applications, one of which is an i2c tester, which may help:
      https://gitlab.com/voxl-public/core-libs/libvoxl_io/-/blob/master/lib/apps/CMakeLists.txt#L51
      (also, your English is Great!)
      T 1 Reply Last reply
      • T Offline
        T Offline
        traffic_light
        Hello @modaltb ,
        Thank you for your (really fast) answer!
        I'm building it with catkin_make inside the docker image.
        Maybe I need to mount more files into the docker image?
        Currently I added some header and cpp files to the include folder inside the project.
        I'm currently not at work, it's 20:40 over here, so I can't send the makefile.
        I'll tryout your suggestion the first thing tomorrow.
        By the way: I'm sorry for posting it, atleast that's what it think, in the wrong forum part. Developing software forum was a better option 😉
        • T traffic_light
          Hello @modaltb ,
          T Offline
          T Offline
          traffic_light
          @traffic_light (So, the makefile is a catkin makefile. A little bit different then a normal cmakelist files)
          • modaltbM modaltb
            Hi @traffic_light ,
            T Offline
            T Offline
            traffic_light
            @modaltb my current cmake without the addition you mentioned:
            cmake_minimum_required(VERSION 2.8.3)
            project(powermodule)
            ## Compile as C++11, supported in ROS Kinetic and newer
            add_compile_options(-std=c++11)
            ## Find catkin macros and libraries
            ## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
            ## is used, also find other catkin packages
              roscpp
              std_msgs
            ## System dependencies are found with CMake's conventions
            # find_package(Boost REQUIRED COMPONENTS system)
            ## Uncomment this if the package has a setup.py. This macro ensures
            ## modules and global scripts declared therein get installed
            ## See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html
            # catkin_python_setup()
            ## Declare ROS messages, services and actions ##
            ## To declare and build messages, services or actions from within this
            ## package, follow these steps:
            ## * Let MSG_DEP_SET be the set of packages whose message types you use in
            ##   your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...).
            ## * In the file package.xml:
            ##   * add a build_depend tag for "message_generation"
            ##   * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET
            ##   * If MSG_DEP_SET isn't empty the following dependency has been pulled in
            ##     but can be declared for certainty nonetheless:
            ##     * add a exec_depend tag for "message_runtime"
            ## * In this file (CMakeLists.txt):
            ##   * add "message_generation" and every package in MSG_DEP_SET to
            ##     find_package(catkin REQUIRED COMPONENTS ...)
            ##   * add "message_runtime" and every package in MSG_DEP_SET to
            ##     catkin_package(CATKIN_DEPENDS ...)
            ##   * uncomment the add_*_files sections below as needed
            ##     and list every .msg/.srv/.action file to be processed
            ##   * uncomment the generate_messages entry below
            ##   * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...)
            ## Generate messages in the 'msg' folder
            # add_message_files(
            #   FILES
            #   Message1.msg
            #   Message2.msg
            ## Generate services in the 'srv' folder
            # add_service_files(
            #   FILES
            #   Service1.srv
            #   Service2.srv
            ## Generate actions in the 'action' folder
            # add_action_files(
            #   FILES
            #   Action1.action
            #   Action2.action
            ## Generate added messages and services with any dependencies listed here
            # generate_messages(
            #   DEPENDENCIES
            #   std_msgs
            ## Declare ROS dynamic reconfigure parameters ##
            ## To declare and build dynamic reconfigure parameters within this
            ##   * add a build_depend and a exec_depend tag for "dynamic_reconfigure"
            ##   * add "dynamic_reconfigure" to
            ##   * uncomment the "generate_dynamic_reconfigure_options" section below
            ##     and list every .cfg file to be processed
            ## Generate dynamic reconfigure parameters in the 'cfg' folder
            # generate_dynamic_reconfigure_options(
            #   cfg/DynReconf1.cfg
            #   cfg/DynReconf2.cfg
            ## catkin specific configuration ##
            ## The catkin_package macro generates cmake config files for your package
            ## Declare things to be passed to dependent projects
            ## INCLUDE_DIRS: uncomment this if your package contains header files
            ## LIBRARIES: libraries you create in this project that dependent projects also need
            ## CATKIN_DEPENDS: catkin_packages dependent projects also need
            ## DEPENDS: system dependencies of this project that dependent projects also need
            catkin_package(
              #INCLUDE_DIRS ../../include
              #LIBRARIES powermdole
              #CATKIN_DEPENDS roscpp std_msgs
              #DEPENDS system_lib
            ## Build ##
            # DOESN'T WORK:
            #FASTRPC_STUB_GEN(../../include/io_rpc.idl)
            ## Specify additional locations of header files
            ## Your package locations should be listed before other locations
            include_directories(
            # include
            	${catkin_INCLUDE_DIRS}
            	include
            	./include
            	/usr/local/include
            	/usr/include
            	../../include/
            link_directories(
            	../../include
            	/include
            	include
            	/usr/local/lib
            	/usr/lib
            ## Declare a C++ library
            add_library(${PROJECT_NAME}
               src/${PROJECT_NAME}.cpp
            ## Add cmake target dependencies of the library
            ## as an example, code may need to be generated before libraries
            ## either from message generation or dynamic reconfigure
            # add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
            ## Declare a C++ executable
            ## With catkin_make all packages are built within a single CMake context
            ## The recommended prefix ensures that target names across packages don't collide
            #add_executable (voxl_i2c  ../../include/voxl-i2c.c)
            #target_link_libraries (voxl_i2c  /usr/lib/voxl_io)
            add_executable(${PROJECT_NAME}_node
               src/main.cpp
               src/powermodule.cpp
               ../../include/colorprinting.cpp
            ## Rename C++ executable without prefix
            ## The above recommended prefix causes long target names, the following renames the
            ## target back to the shorter version for ease of user use
            ## e.g. "rosrun someones_pkg node" instead of "rosrun someones_pkg someones_pkg_node"
            # set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX "")
            ## Add cmake target dependencies of the executable
            ## same as for the library above
            #add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
            ## Specify libraries to link a library or executable target against
            target_link_libraries(${PROJECT_NAME}_node
            ${catkin_LIBRARIES}
            /usr/local/lib/
            # /usr/lib/aarch64-linux-gnu/libi2c.so
            #/usr/lib/rfsa/adsp/libio_rpc.so
            #/usr/lib/rfsa/adsp/libio_rpc_skel.so
            #/usr/lib/libvoxl_io.so
            ## Install ##
            # all install targets should use catkin DESTINATION variables
            # See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html
            ## Mark executable scripts (Python etc.) for installation
            ## in contrast to setup.py, you can choose the destination
            # install(PROGRAMS
            #   scripts/my_python_script
            #   DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
            ## Mark executables for installation
            ## See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_executables.html
            # install(TARGETS ${PROJECT_NAME}_node
            #   RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
            ## Mark libraries for installation
            ## See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_libraries.html
            #   ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
            #   LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
            #   RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION}
            ## Mark cpp header files for installation
            # install(DIRECTORY include/${PROJECT_NAME}/
            #   DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
            #   FILES_MATCHING PATTERN "*.h"
            #   PATTERN ".svn" EXCLUDE
            ## Mark other files for installation (e.g. launch and bag files, etc.)
            # install(FILES
            #   # myfile1
            #   # myfile2
            #   DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
            ## Testing ##
            ## Add gtest based cpp test target and link libraries
            # catkin_add_gtest(${PROJECT_NAME}-test test/test_shutdown.cpp)
            # if(TARGET ${PROJECT_NAME}-test)
            #   target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME})
            # endif()
            ## Add folders to be run by python nosetests
            # catkin_add_nosetests(test)
            I think I need to figure out how I can add the IO correctly inside it.
            I'll post a new makefile when I did that.
