voxl-io & I2C
Hello everyone,
Currently I'm developing some software that will talk, over I2C, to a self-build powermodule with a microcontroller onboard.
This software is a node for ros and runs in a docker.
When it received the batterypercentage from PX4 it will start sending and receiving data to the powermodule.
The part that receives the batterypercentage works great.The only problem is that I receive a linker error when I'm building the software with the I2C commands
Error's:
CMakeFiles/powermodule_node.dir/src/powermodule.cpp.o: In function `PowerModule::OpenI2CDevice()': powermodule.cpp:(.text+0xbc): undefined reference to `voxl_i2c_slave_config' powermodule.cpp:(.text+0xd0): undefined reference to `voxl_i2c_init' collect2: error: ld returned 1 exit status powermodule/CMakeFiles/powermodule_node.dir/build.make:165: recipe for target '/root/yoctohome/peter-dev/control/devel/lib/powermodule/powermodule_node' failed make[2]: *** [/root/yoctohome/peter-dev/control/devel/lib/powermodule/powermodule_node] Error 1 CMakeFiles/Makefile2:1551: recipe for target 'powermodule/CMakeFiles/powermodule_node.dir/all' failed make[1]: *** [powermodule/CMakeFiles/powermodule_node.dir/all] Error 2 Makefile:138: recipe for target 'all' failed make: *** [all] Error 2 Invoking "make -j4 -l4" failedI already tried a lot of option.
Some options i already did:- Include a lot of header and cpp files into the includes folder
- Building the voxl_io in a docker on my pc and move the ipk to the voxl
The hardware is a voxl_flight and I'm using the I2C port 6 (located on the J7 header)
I don't know what to do for now so I'm searching for help. I can't find anything that helps me with my solution and the docs of modalai doesn't have a lot of information about I2C usage.
Here a part of the code that's opening the i2c:
int8_t PowerModule::OpenI2CDevice() { if (I2C_is_open_) { // I2C bus is already opened. Return -2 return -2; } if (voxl_i2c_slave_config(I2C_bus_id_, I2C_address_, 400000, 1000) == 0) { //return -3; } int8_t response{0}; response = voxl_i2c_init(I2C_bus_id_); if (response == 0) { I2C_is_open_ = true; } return response; }Thanks in advance!
(I'm sorry for my English
Hi @traffic_light ,
Are you building your application in the voxl-docker or on target (e.g. on VOXL)?
Is it possible to post your CMakeLists.txt file here? It looks like it's failing to link to libvoxl_io.
Here's an example file where we build some applications, one of which is an i2c tester, which may help:
https://gitlab.com/voxl-public/core-libs/libvoxl_io/-/blob/master/lib/apps/CMakeLists.txt#L51
(also, your English is Great!)
Hello @modaltb ,
Thank you for your (really fast) answer!
I'm building it with catkin_make inside the docker image.
Maybe I need to mount more files into the docker image?
Currently I added some header and cpp files to the include folder inside the project.I'm currently not at work, it's 20:40 over here, so I can't send the makefile.
I'll tryout your suggestion the first thing tomorrow.By the way: I'm sorry for posting it, atleast that's what it think, in the wrong forum part. Developing software forum was a better option
Hello @modaltb ,
@traffic_light (So, the makefile is a catkin makefile. A little bit different then a normal cmakelist files)
Hi @traffic_light ,
@modaltb my current cmake without the addition you mentioned:
cmake_minimum_required(VERSION 2.8.3) project(powermodule) ## Compile as C++11, supported in ROS Kinetic and newer add_compile_options(-std=c++11) ## Find catkin macros and libraries ## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz) ## is used, also find other catkin packages find_package(catkin REQUIRED COMPONENTS roscpp std_msgs ) ## System dependencies are found with CMake's conventions # find_package(Boost REQUIRED COMPONENTS system) ## Uncomment this if the package has a setup.py. This macro ensures ## modules and global scripts declared therein get installed ## See http://ros.org/doc/api/catkin/html/user_guide/setup_dot_py.html # catkin_python_setup() ################################################ ## Declare ROS messages, services and actions ## ################################################ ## To declare and build messages, services or actions from within this ## package, follow these steps: ## * Let MSG_DEP_SET be the set of packages whose message types you use in ## your messages/services/actions (e.g. std_msgs, actionlib_msgs, ...). ## * In the file package.xml: ## * add a build_depend tag for "message_generation" ## * add a build_depend and a exec_depend tag for each package in MSG_DEP_SET ## * If MSG_DEP_SET isn't empty the following dependency has been pulled in ## but can be declared for certainty nonetheless: ## * add a exec_depend tag for "message_runtime" ## * In this file (CMakeLists.txt): ## * add "message_generation" and every package in MSG_DEP_SET to ## find_package(catkin REQUIRED COMPONENTS ...) ## * add "message_runtime" and every package in MSG_DEP_SET to ## catkin_package(CATKIN_DEPENDS ...) ## * uncomment the add_*_files sections below as needed ## and list every .msg/.srv/.action file to be processed ## * uncomment the generate_messages entry below ## * add every package in MSG_DEP_SET to generate_messages(DEPENDENCIES ...) ## Generate messages in the 'msg' folder # add_message_files( # FILES # Message1.msg # Message2.msg # ) ## Generate services in the 'srv' folder # add_service_files( # FILES # Service1.srv # Service2.srv # ) ## Generate actions in the 'action' folder # add_action_files( # FILES # Action1.action # Action2.action # ) ## Generate added messages and services with any dependencies listed here # generate_messages( # DEPENDENCIES # std_msgs # ) ################################################ ## Declare ROS dynamic reconfigure parameters ## ################################################ ## To declare and build dynamic reconfigure parameters within this ## package, follow these steps: ## * In the file package.xml: ## * add a build_depend and a exec_depend tag for "dynamic_reconfigure" ## * In this file (CMakeLists.txt): ## * add "dynamic_reconfigure" to ## find_package(catkin REQUIRED COMPONENTS ...) ## * uncomment the "generate_dynamic_reconfigure_options" section below ## and list every .cfg file to be processed ## Generate dynamic reconfigure parameters in the 'cfg' folder # generate_dynamic_reconfigure_options( # cfg/DynReconf1.cfg # cfg/DynReconf2.cfg # ) ################################### ## catkin specific configuration ## ################################### ## The catkin_package macro generates cmake config files for your package ## Declare things to be passed to dependent projects ## INCLUDE_DIRS: uncomment this if your package contains header files ## LIBRARIES: libraries you create in this project that dependent projects also need ## CATKIN_DEPENDS: catkin_packages dependent projects also need ## DEPENDS: system dependencies of this project that dependent projects also need catkin_package( #INCLUDE_DIRS ../../include #LIBRARIES powermdole #CATKIN_DEPENDS roscpp std_msgs #DEPENDS system_lib ) ########### ## Build ## ########### # DOESN'T WORK: #FASTRPC_STUB_GEN(../../include/io_rpc.idl) ## Specify additional locations of header files ## Your package locations should be listed before other locations include_directories( # include ${catkin_INCLUDE_DIRS} include ./include /usr/local/include /usr/include ../../include/ ) link_directories( ../../include /include include /usr/local/lib /usr/lib ) ## Declare a C++ library add_library(${PROJECT_NAME} src/${PROJECT_NAME}.cpp ) ## Add cmake target dependencies of the library ## as an example, code may need to be generated before libraries ## either from message generation or dynamic reconfigure # add_dependencies(${PROJECT_NAME} ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS}) ## Declare a C++ executable ## With catkin_make all packages are built within a single CMake context ## The recommended prefix ensures that target names across packages don't collide #add_executable (voxl_i2c ../../include/voxl-i2c.c) #target_link_libraries (voxl_i2c /usr/lib/voxl_io) add_executable(${PROJECT_NAME}_node src/main.cpp src/powermodule.cpp ../../include/colorprinting.cpp ) ## Rename C++ executable without prefix ## The above recommended prefix causes long target names, the following renames the ## target back to the shorter version for ease of user use ## e.g. "rosrun someones_pkg node" instead of "rosrun someones_pkg someones_pkg_node" # set_target_properties(${PROJECT_NAME}_node PROPERTIES OUTPUT_NAME node PREFIX "") ## Add cmake target dependencies of the executable ## same as for the library above #add_dependencies(${PROJECT_NAME}_node ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS}) ## Specify libraries to link a library or executable target against target_link_libraries(${PROJECT_NAME}_node ${catkin_LIBRARIES} /usr/local/lib/ # /usr/lib/aarch64-linux-gnu/libi2c.so #/usr/lib/rfsa/adsp/libio_rpc.so #/usr/lib/rfsa/adsp/libio_rpc_skel.so #/usr/lib/libvoxl_io.so #/usr/lib/libvoxl_io ) ############# ## Install ## ############# # all install targets should use catkin DESTINATION variables # See http://ros.org/doc/api/catkin/html/adv_user_guide/variables.html ## Mark executable scripts (Python etc.) for installation ## in contrast to setup.py, you can choose the destination # install(PROGRAMS # scripts/my_python_script # DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION} # ) ## Mark executables for installation ## See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_executables.html # install(TARGETS ${PROJECT_NAME}_node # RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION} # ) ## Mark libraries for installation ## See http://docs.ros.org/melodic/api/catkin/html/howto/format1/building_libraries.html # install(TARGETS ${PROJECT_NAME} # ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION} # LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION} # RUNTIME DESTINATION ${CATKIN_GLOBAL_BIN_DESTINATION} # ) ## Mark cpp header files for installation # install(DIRECTORY include/${PROJECT_NAME}/ # DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION} # FILES_MATCHING PATTERN "*.h" # PATTERN ".svn" EXCLUDE # ) ## Mark other files for installation (e.g. launch and bag files, etc.) # install(FILES # # myfile1 # # myfile2 # DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION} # ) ############# ## Testing ## ############# ## Add gtest based cpp test target and link libraries # catkin_add_gtest(${PROJECT_NAME}-test test/test_shutdown.cpp) # if(TARGET ${PROJECT_NAME}-test) # target_link_libraries(${PROJECT_NAME}-test ${PROJECT_NAME}) # endif() ## Add folders to be run by python nosetests # catkin_add_nosetests(test)I think I need to figure out how I can add the IO correctly inside it.
I'll post a new makefile when I did that.
