  3. voxl-docker-mavsdk-python build issues
voxl
48 Posts 6 Posters 32.1k Views 4 Watching
    @Eric-Katzfey The latest attempts, yes. After running that and
    docker run --rm -it --net=host --privileged -e DISPLAY=$DISPLAY -v /dev/input:/dev/input:rw -v /tmp/.X11-unix:/tmp/.X11-unix:ro voxl-gazebo-docker ./run_gazebo.bash
    gazebo will open up. The issue is connect gazebo with VOXL2 to run in HITL mode. I've followed two of the video from Modalai and Ascend exactly with no luck. Also went through the documentation again.
    All instances are being ran on the host computer. When comparing the image from above to docs, we are only getting heartbeat packets.
    @Alexander-Saunders Definitely looks like a permissions issue of some sort in your system.
    Alexander SaundersA 1 Reply Last reply
      Alexander SaundersA Offline
      Alexander Saunders
      @Eric-Katzfey Are you suggesting giving the file/repo permissions with
      xhost si:localuser:root
      Also we are using the FDTI cable provided with the ESC AND USB C to A to connect to host.
        @Alexander-Saunders I'm only suggesting that there is a permissions problem of some sort. I don't see that on my machine so just trying to figure out what is different in your environment.
        Alexander SaundersA 3 Replies Last reply
          Alexander Saunders
          @Eric-Katzfey I tried giving permission to user with no change.
            Alexander Saunders
            @Eric-Katzfey Is it possible to see a picture of your terminal of the commands you sent?
              Alexander Saunders
                @Alexander-Saunders iris_hitl.sdf is part of the docker image so it will be the same.
                  @Alexander-Saunders
                  modalai@modalai-XPS-15-9570:~$ docker run --rm -it --net=host --privileged -v /dev/input:/dev/input:rw voxl-gazebo-docker
                  root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls
                  CMakeLists.txt           build-gazebo.bash    include       package.xml            scripts
                  Dockerfile               build-mavlink.bash   mavlink       resources              src
                  README.md                cmake                mavlink-libs  run-docker-image.bash  unit_tests
                  build                    docker-commands.txt  models        run_gazebo.bash        worlds
                  build-docker-image.bash  external             msgs          run_headless.bash
                  root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls /dev/ttyUSB0
                  /dev/ttyUSB0
                  root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ls -l /dev/ttyUSB0
                  crw-rw---- 1 root dialout 188, 0 Jun  3 16:02 /dev/ttyUSB0
                  root@modalai-XPS-15-9570:/usr/workspace/voxl2_hitl_gazebo# ./run_headless.bash
                  GAZEBO_PLUGIN_PATH :/usr/workspace/voxl2_hitl_gazebo
                  GAZEBO_MODEL_PATH :/usr/workspace/voxl2_hitl_gazebo/models
                  LD_LIBRARY_PATH :/usr/workspace/voxl2_hitl_gazebo/build
                  Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
                  Opened serial device /dev/ttyUSB0
                    @Alexander-Saunders
                    modalai@modalai-XPS-15-9570:~$ docker images | grep gazebo
                    voxl-gazebo-docker            latest       1c8ce4f31e4f   3 months ago    3.73GB
                    voxl-gazebo-docker            v1.2         1c8ce4f31e4f   3 months ago    3.73GB
                      @Alexander-Saunders We have quite a few customers using HITL successfully and they are using the instructions in the document so I'm thinking there is something in your environment that is causing the issue. Do you have access to a different Linux machine that you can use?
                        Alexander Saunders
                        @Eric-Katzfey Update:
                        We switched some of the wires for the FTDI cable and now receiving data. We went back to following the HITL docs along with https://forum.modalai.com/topic/3511/serial-port-closed-and-other-hitl-errors/9 . We have the drone running in HITL via QGC and running the voxl-px4-hitl command. Despite this, gazebo is still not showing the drone or connecting. Could the issue possibly be with the Dockerfile that reflects bionic instead of focal since that had to be changed for the image to be pulled? We also tried running ./run-docker.sh within the directory and received docker run --help.
                          @Alexander-Saunders Looks better now. What does the dsp_hitl start command look like now? Seems like it is setup for VIO only.
