    QRB5165M vs QSM8250
    • W
      wilkinsaf ModalAI Team
      Hello, I noticed the 2 hardware versions here: https://docs.modalai.com/m0054-versions/
      1. Is there a difference for the end user between QRB5165M vs QSM8250
      2. Is ModalAI switching over to ONLY using QSM8250
      M 1 Reply Last reply 15 Mar 2024, 01:16 Reply Quote 0
      • M
        Moderator ModalAI Team @wilkinsaf
        @wilkinsaf The M0054-2 uses the QSM8250, but that is not sold in dev kit form. It only supports up to 4 image sensors concurrently, instead of the typical 7. The M0054-2 is frequently found on Starling as it only has 3 image sensors
        W 1 Reply Last reply 21 May 2024, 15:11 Reply Quote 1
        • W
          wilkinsaf ModalAI Team @Moderator
          Noting here that flashing the wrong kernel will brick the device (ie flashing the QRB on the QSM) make sure to select the correct option when upgrading the board.
