    VOXL2 - HITL/VIO
    2183
    • leonardo Andrade 0L
      leonardo Andrade 0
      Hey guys !
      I want to run PX4-HITL using VIO, but I'm running into some problems.
      I was able to create the communication with the FTDI cable, but using the docker image or using gazebo on my computer I had problems with the pre-flights checks.
      I also had problems with QGC, which kept alerting me to an unknown mode-
      The data presented was strange
      The version of the sdk and packages are:
      I used as reference :
      https://docs.modalai.com/voxl2-PX4-hitl/
      I would like to know if there are any additional steps for the parameters with VIO and what would be the correct way to execute VOXL-PX4-HITL.
        Eric Katzfey ModalAI Team @leonardo Andrade 0
        @leonardo-Andrade-0 Doesn't look like the HITL driver is receiving any data over the serial port. That's why you see those failures about baro, gyro, and accel data missing. Can you execute the command qshell dsp_hitl status and see that it says?
        leonardo Andrade 0L 1 Reply Last reply Reply Quote 0
          leonardo Andrade 0 @Eric Katzfey
          @Eric-Katzfey said in VOXL2 - HITL/VIO:
          I runned the command , but seems it's ok.
          What could I check? What do you suggest?@Eric-Katzfey
            @leonardo-Andrade-0 Is px4 generating a log for the failed takeoff attempt? It's best to go into /data/px4/log and clear out any logs that may be saved there. Then run your test and verify that a new log was created. That log should indicate the reason for the arming failure. You can also just look at topics like failsafe_flags and vehicle_status with the listener command to see what they are indicating as failures. What does the start command look like in /usr/bin/voxl-px4-hitl-start? Did you change it from the default qshell dsp_hitl start -g -m -o?
              Hi Eric, this is my first time doing any setup with HITL.
              I'm using the standard voxl-px4-hitl-start file, on the host computer it apparently opens communication with the usb, I send the command to arm the drone and when I tried the first time, it still tookoff, without showing any stability, now it triggers the failsafe and doesn't even takeoff.
              Do you have any suggestions as to how I could approach it better? As it's my first time, I'm a bit lost as to how to debug in this case.
              ps: I'm not using GPS
              voxl-px4-hitl-start
              During the execution of voxl-px4-hitl
              Failsafe triggered
                @leonardo-Andrade-0 It shows you are just running gazebo from the command line. You need to be running our version of gazebo from the Docker. See https://docs.modalai.com/voxl2-PX4-hitl/#gazebo-simulator-setup-on-host-computer
                  Now using the docker image.
                  Screenshot 2024-05-17 17:03:53.png
                  Screenshot 2024-05-17 17:03:42.png
                    @leonardo-Andrade-0 Can you change the start command to remove the -o option from dsp_hitl start? That will try prevent VIO odometry from being published and only leave GPS and magnetomer for position hold. See if that works. You can see that home position is not valid in the failsafe flags but it should be if GPS is coming in.
                      Eric Katzfey ModalAI Team @Eric Katzfey
                      @Eric-Katzfey If that works then try using only the -o option and removing the -g and -m options so that you have no gps or magnetometer coming in, only VIO odometry. With that also change the PX4 parameters SYS_HAS_GPS and SYS_HAS_MAG to 0 and EKF2_MAG_TYPE to 5. Then try to fly VIO only with that.
                        hey @Eric-Katzfey
                        Using GPS/MAG in case -g -m, its stopped to warning the pre-flight check of yaw estimate error, however I noticed seems missing params.
                        voxl2:/$ voxl-px4-hitl
                        Found DSP signature file
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-hitl-start 0
                        Running on M0054
                        INFO  [param] selected parameter default file /data/px4/param/hitl_parameters
                        INFO  [parameters] BSON document size 4109 bytes, decoded 4109 bytes (INT32:79, FLOAT:114)
                        INFO  [logger] Start file log (type: full)
                        INFO  [logger] [logger] /data/px4/log/2024-05-20/16_01_02.ulg
                        INFO  [muorb] SLPI: Advertising remote topic mavlink_log
                        INFO  [muorb] SLPI: Advertising remote topic event
                        INFO  [logger] Opened full log file: /data/px4/log/2024-05-20/16_01_02.ulg
                        INFO  [muorb] SLPI: Advertising remote topic logger_status
                        INFO  [qshell] Send cmd: 'sensors start -h'
                        INFO  [muorb] SLPI: qshell gotten: sensors start -h
                        INFO  [muorb] SLPI:   arg2 = '-h'
                        INFO  [muorb] SLPI: Ok executing command: sensors start -h
                        INFO  [qshell] qshell return value timestamp: 1597879835, local time: 1597887360
                        INFO  [qshell] qshell return value timestamp: 1598279802, local time: 1598282277
                        INFO  [qshell] qshell return value timestamp: 1598401731, local time: 1598403944
                        INFO  [qshell] qshell return value timestamp: 1598464342, local time: 1598467697
                        INFO  [qshell] qshell return value timestamp: 1598592592, local time: 1598595052
                        INFO  [qshell] qshell return value timestamp: 1598667266, local time: 1598670137
                        INFO  [qshell] qshell return value timestamp: 1598716330, local time: 1598718644
                        INFO  [muorb] SLPI:   arg0 = 'land_detector'
                        INFO  [muorb] SLPI:   arg2 = 'multicopter'
                        INFO  [qshell] qshell return value timestamp: 1598767502, local time: 1598769992
                        INFO  [qshell] Send cmd: 'manual_control start'
                        INFO  [muorb] SLPI: qshell gotten: manual_control start
                        INFO  [muorb] SLPI:   arg0 = 'manual_control'
                        INFO  [uORB] Advertising remote topic vehicle_land_detected
                        INFO  [muorb] SLPI: Ok executing command: manual_control start
                        INFO  [qshell] qshell return value timestamp: 1598825243, local time: 1598828079
                        INFO  [uORB] Advertising remote topic manual_control_setpoint
                        INFO  [qshell] Send cmd: 'control_allocator start'
                        INFO  [muorb] SLPI: qshell gotten: control_allocator start
                        INFO  [muorb] SLPI:   arg0 = 'control_allocator'
                        INFO  [uORB] Advertising remote topic control_allocator_status
                        INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
                        INFO  [uORB] Advertising remote topic actuator_motors
                        INFO  [uORB] Advertising remote topic actuator_servos
                        INFO  [uORB] Advertising remote topic actuator_servos_trim
                        INFO  [muorb] SLPI: Ok executing command: control_allocator start
                        INFO  [qshell] qshell return value timestamp: 1599211146, local time: 1599212999
                        INFO  [qshell] Send cmd: 'rc_update start'
                        INFO  [muorb] SLPI: qshell gotten: rc_update start
                        INFO  [muorb] SLPI:   arg0 = 'rc_update'
                        INFO  [muorb] SLPI: Ok executing command: rc_update start
                        INFO  [qshell] qshell return value timestamp: 1599596741, local time: 1599602277
                        INFO  [qshell] Send cmd: 'commander start -h'
                        INFO  [muorb] SLPI: qshell gotten: commander start -h
                        INFO  [muorb] SLPI:   arg0 = 'commander'
                        INFO  [muorb] SLPI: Creating pthread commander
                        INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097647
                        INFO  [uORB] Advertising remote topic led_control
                        INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
                        INFO  [uORB] Advertising remote topic tune_control
                        **INFO  [muorb] SLPI: Ok executing command: commander start -h
                        INFO  [qshell] qshell return value timestamp: 1599865670, local time: 1599867387
                        INFO  [muorb] SLPI: Preflight Fail: Accel Sensor 0 missing
                        INFO  [muorb] SLPI: Preflight Fail: barometer 0 missing
                        INFO  [muorb] SLPI: Preflight Fail: ekf2 missing data
                        INFO  [muorb] SLPI: Preflight Fail: Gyro Sensor 0 missing**
                        INFO  [uORB] Advertising remote topic health_report
                        INFO  [uORB] Advertising remote topic failsafe_flags
                        INFO  [uORB] Advertising remote topic actuator_armed
                        INFO  [uORB] Advertising remote topic vehicle_control_mode
                        INFO  [uORB] Advertising remote topic vehicle_status
                        INFO  [uORB] Advertising remote topic failure_detector_status
                        INFO  [qshell] Send cmd: 'commander mode posctl'
                        INFO  [muorb] SLPI: qshell gotten: commander mode posctl
                        INFO  [muorb] SLPI:   arg1 = 'mode'
                        INFO  [muorb] SLPI:   arg2 = 'posctl'
                        INFO  [uORB] Advertising remote topic vehicle_command
                        INFO  [muorb] SLPI: Ok executing command: commander mode posctl
                        INFO  [qshell] qshell return value timestamp: 1599909239, local time: 1599912144
                        INFO  [uORB] Advertising remote topic vehicle_command_ack
                        INFO  [qshell] Send cmd: 'load_mon start'
                        INFO  [muorb] SLPI: qshell gotten: load_mon start
                        INFO  [muorb] SLPI:   arg0 = 'load_mon'
                        INFO  [muorb] SLPI: Ok executing command: load_mon start
                        INFO  [uORB] Advertising remote topic cpuload
                        INFO  [qshell] qshell return value timestamp: 1599943912, local time: 1599946598
                        INFO  [qshell] Send cmd: 'flight_mode_manager start'
                        INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
                        INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
                        INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
                        INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
                        INFO  [qshell] qshell return value timestamp: 1600088995, local time: 1600091860
                        INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
                        INFO  [muorb] SLPI: Advertising remote topic transponder_report
                        INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
                        INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
                        INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
                        INFO  [muorb] SLPI:   arg0 = 'pwm_out_sim'
                        INFO  [muorb] SLPI:   arg2 = '-m'
                        INFO  [muorb] SLPI:   arg3 = 'hil'
                        INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
                        INFO  [qshell] qshell return value timestamp: 1601306980, local time: 1601309848
                        ------------- RUNNING JUST THE GPS/MAG!!! -------------
                        INFO  [uORB] Advertising remote topic actuator_outputs_sim
                        INFO  [qshell] Send cmd: 'dsp_hitl start -g -m'
                        INFO  [muorb] SLPI: qshell gotten: dsp_hitl start -g -m
                        INFO  [muorb] SLPI:   arg0 = 'dsp_hitl'
                        INFO  [muorb] SLPI:   arg2 = '-g'
                        INFO  [muorb] SLPI:   arg3 = '-m'
                        INFO  [muorb] SLPI: Creating pthread dsp_hitl__main
                        INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_hitl__main with tid 2097645
                        INFO  [muorb] SLPI: Ok executing command: dsp_hitl start -g -m
                        INFO  [muorb] SLPI: DSP HITL Serial Port is open: 0
                        INFO  [qshell] qshell return value timestamp: 1601353759, local time: 1601354484
                        INFO  [muorb] SLPI: Got 5 from orb_subscribe
                        INFO  [uORB] Advertising remote topic esc_status
                        INFO  [uORB] Advertising remote topic battery_status
                        INFO  [muorb] SLPI: Advertising remote topic telemetry_status
                        INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_local_position_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
                        INFO  [uORB] Advertising remote topic trajectory_setpoint
                        INFO  [uORB] Advertising remote topic vehicle_constraints
                        INFO  [uORB] Advertising remote topic landing_gear
                        INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
                        INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
                        INFO  [muorb] SLPI: Advertising remote topic timesync_status
                        INFO  [uORB] Advertising remote topic sensor_gps
                        INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
                        INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
                        INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
                        INFO  [uORB] Advertising remote topic actuator_controls_status_0
                        INFO  [muorb] SLPI: Advertising remote topic camera_status
                        INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
                        pxh> INFO  [muorb] SLPI: Advertising remote topic ping
                        pxh> qshell commander takeoff
                        INFO  [qshell] Send cmd: 'commander takeoff'
                        INFO  [muorb] SLPI: qshell gotten: commander takeoff
                        INFO  [muorb] SLPI:   arg1 = 'takeoff'
                        INFO  [muorb] SLPI: Ok executing command: commander takeoff
                        INFO  [qshell] qshell return value timestamp: 1681880057, local time: 1681883664
                        pxh> INFO  [muorb] SLPI: Armed by internal command
                        INFO  [navigator] Using minimum takeoff altitude: 3.00 m
                        INFO  [muorb] SLPI: Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
                        INFO  [muorb] SLPI: Advertising remote topic mission_result
                        WARN  [mavlink] Event dropped (25, 65527)
                        INFO  [muorb] SLPI: Failsafe activated
                        WARN  [mavlink] Dropped 65502 events (seq=65527)
                        WARN  [mavlink] Event dropped (65528, 25)
                        WARN  [mavlink] Dropped 15 events (seq=25)
                          leonardo Andrade 0 @leonardo Andrade 0
                          Using just -o I get the yaw estimate error all the time
                          INFO  [muorb] SLPI: Preflight Fail: Yaw estimate error
                          PX4 Exiting...
                          pxh> Exiting NOW.
                          voxl2:/$ export PX4_HOME_LAT=0000.0000
                          voxl2:/$ export PX4_HOME_LON=0000.0000
                          voxl2:/$ export PX4_HOME_ALT=0000.0000
                          ______  __   __    ___
                          | ___ \ \ \ / /   /   |
                          | |_/ /  \ V /   / /| |
                          |  __/   /   \  / /_| |
                          | |     / /^\ \ \___  |
                          \_|     \/   \/     |_/
                          px4 starting.
                          Running on M0054
                          INFO  [logger] [logger] /data/px4/log/2024-05-20/15_46_58.ulg
                          INFO  [logger] Opened full log file: /data/px4/log/2024-05-20/15_46_58.ulg
                          INFO  [qshell] qshell return value timestamp: 754123932, local time: 754131474
                          INFO  [qshell] qshell return value timestamp: 754536383, local time: 754541063
                          INFO  [qshell] qshell return value timestamp: 754669164, local time: 754672431
                          INFO  [qshell] qshell return value timestamp: 754745299, local time: 754748135
                          INFO  [qshell] qshell return value timestamp: 754875390, local time: 754878249
                          INFO  [qshell] qshell return value timestamp: 754923562, local time: 754926616
                          INFO  [qshell] qshell return value timestamp: 754987805, local time: 754991271
                          INFO  [qshell] qshell return value timestamp: 755042360, local time: 755044865
                          INFO  [qshell] qshell return value timestamp: 755087130, local time: 755089796
                          INFO  [qshell] qshell return value timestamp: 755468579, local time: 755470589
                          INFO  [qshell] qshell return value timestamp: 755849262, local time: 755851518
                          INFO  [qshell] qshell return value timestamp: 756119900, local time: 756121221
                          INFO  [qshell] qshell return value timestamp: 756161492, local time: 756163381
                          INFO  [qshell] qshell return value timestamp: 756209650, local time: 756212110
                          INFO  [qshell] qshell return value timestamp: 756337917, local time: 756339906
                          INFO  [qshell] qshell return value timestamp: 757571489, local time: 757574531
                          ------------- RUNNING JUST THE ODOMETRY!!! -------------
                          INFO  [qshell] Send cmd: 'dsp_hitl start -o'
                          INFO  [muorb] SLPI: qshell gotten: dsp_hitl start -o
                          INFO  [muorb] SLPI:   arg2 = '-o'
                          INFO  [muorb] SLPI: Ok executing command: dsp_hitl start -o
                          INFO  [qshell] qshell return value timestamp: 757621699, local time: 757622539
                          INFO  [uORB] Advertising remote topic vehicle_visual_odometry
                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
                          INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
                          INFO  [uORB] Advertising remote topic estimator_baro_bias
                          pxh> INFO  [uORB] Advertising remote topic home_position
                          pxh> INFO  [muorb] SLPI: Preflight Fail: Yaw estimate error                  INFO  [muorb] SLPI: Preflight Fail: Yaw estimate error                                INFO  [muorb] SLPI: Preflight Fail: Yaw estimate error
                            @Eric-Katzfey both cases I using just mag/gps did not takeoff , and with odometry (with/without mag/gps) did not have stability.
                            Do have any idea? what are the reasons?
                              @leonardo-Andrade-0 How are your SYS_HAS_GPS, SYS_HAS_MAG, and EKF2_MAG_TYPE parameters set for each case?
                                @leonardo-Andrade-0 For the case where you are using only GPS and MAG the parameters need to reflect that. SYS_HAS_GPS = 1, SYS_HAS_MAG = 1, EKF2_MAG_TYPE = 0.
