    Tracking camera won’t initialize when configured with stereo
    • G
      Gary Holmgren
      Hello, I have the stereo, tracking, and hi res dev kit and all the cameras have been working fine together until just recently. The tracking camera will not appear in the stream and is not recognized at all by the voxl2. When I configure the cameras to only be hi-res and tracking then the tracking is recognized and works fine. Configuring it to tracking and stereo then tracking does not initialize. What could be causing this as I don’t see how that makes any sense.
      A 1 Reply Last reply 6 May 2024, 19:03 Reply Quote 0
      • A
        Alex Kushleyev ModalAI Team @Gary Holmgren
        @Gary-Holmgren ,
        Can you please clarify whether you have single stereo or dual stereo? The dual stereo, tracking, hires is the standard configuration: https://docs.modalai.com/voxl2-camera-configs/#c-11-front-stereo-rear-stereo-hires-and-tracking-d0006-sentinel
        or is it this one https://docs.modalai.com/voxl2-camera-configs/#c-03-front-stereo-hires-and-tracking ?
        G 1 Reply Last reply 6 May 2024, 21:09 Reply Quote 0
        • G
          Gary Holmgren @Alex Kushleyev
          @Alex-Kushleyev Hi, I have the dual stereo C11 kit but I am trying it with single stereo, configuration 03 on voxl-configure-cameras
          I cannot get the tracking camera to initialize when the stereo is configured simultaneously not matter what I try. It did used to work fine but something must haver been changed. I am on the latest SDK as well.
          A 1 Reply Last reply 6 May 2024, 21:24 Reply Quote 0
          • A
            @Gary-Holmgren , ok I understand.
            Can you please confirm that you actually have the cameras connected in C03 configuration as shown here : https://docs.modalai.com/voxl2-camera-configs/#c-03-front-stereo-hires-and-tracking (stereo is NOT in J8)
            and that you run voxl-configure-cameras and select option 3?
            also can you please paste output of ls /usr/lib/camera/*sensormodule* and output of voxl-camera-server -l just the top part, where it detects the connected cameras, before it prints out resolutions.
            By latest SDK, i am assuming you mean 1.2.0 (just to double check)
            Considering that the tracking camera is working in hires/tracking only configuration, there must be some kind of mix up, but we should be able to figure it out. I will also try this configuration. on SDK 1.2.0.
            A 1 Reply Last reply 6 May 2024, 21:29 Reply Quote 0
            • A
              i just ran this config, here is my output:
              DEBUG:   ----------- Number of cameras: 4
              DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
              DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x00E4, Sensor Id: 0x7750
              DEBUG:   Cam idx: 2, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
              DEBUG:   Cam idx: 3, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
              DEBUG:   Number of cameras: 4
              /usr/lib/camera/com.qti.sensormodule.imx214_3.bin  /usr/lib/camera/com.qti.sensormodule.ov7251_combo_0.bin
              /usr/lib/camera/com.qti.sensormodule.ov7251_2.bin  /usr/lib/camera/com.qti.sensormodule.ov7251_combo_1.bin
              voxl-inspect-cam -a
              |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
              |   hires_large_color |19693440 | 4208 | 3120 | 33.23 |  431 |       90 |     85.1  | 30.0 | 4733.6 | NV12
              | hires_large_encoded |  224827 | 4208 | 3120 | 33.23 |  431 |       90 |    120.4  | 30.0 |   28.8 | H265 (I)
              |    hires_large_grey |13128960 | 4208 | 3120 | 33.23 |  431 |       91 |     77.9  | 30.0 | 3155.7 | RAW8
              |   hires_small_color | 1179648 | 1024 |  768 | 33.23 |  431 |       92 |     58.5  | 30.0 |  283.5 | NV12
              | hires_small_encoded |   31783 | 1024 |  768 | 33.23 |  431 |       91 |     73.5  | 30.0 |    1.8 | H265 (I)
              |    hires_small_grey |  786432 | 1024 |  768 | 33.23 |  431 |       92 |     57.8  | 30.0 |  189.0 | RAW8
              |      hires_snapshot |
              |              stereo |  614400 |  640 |  480 | 15.84 | 1399 |      358 |     34.5  | 30.0 |  147.5 | STEREO_RAW8
              |            tracking |  307200 |  640 |  480 |  6.32 |  496 |      357 |     10.9  | 30.0 |   73.7 | RAW8
              • G
                Gary Holmgren
                Hi, thank you for the input, I have attempted to reflash the SDK 1.2.0 and then reboot after configuring the voxl to option #03. I disassembled everything to ensure camera MIPIs were connected properly and in the corresponding J6 and J7 connectors where hi-res and tracking flex are indeed on J7 and the front stereo/interposer is on J6.
                voxl2:/$ ls /usr/lib/camera/sensormodule
                voxl2:/$ voxl-camera-server -l
                an existing instance of voxl-camera-server found, attempting to stop it
                DEBUG: ----------- Number of cameras: 3
                DEBUG: Cam idx: 1, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                DEBUG: Cam idx: 2, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                DEBUG: Number of cameras: 3
                Now fore camera config #04 with Hi-Res and Tracking immediately after these tests I will paste the same commands:
                DEBUG: ----------- Number of cameras: 2
                DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                DEBUG: Cam idx: 1, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                DEBUG: Number of cameras: 2
                As per the Voxl portal, I can see both tracking and hi res working in this config 04, but in camera config 03 I can see only the Hires and stereo showing up.
                A 1 Reply Last reply 7 May 2024, 13:54 Reply Quote 0
                • A
                  @Gary-Holmgren,
                  Based on your results, the tracking camera is found in both cases (cam slot 2). It looks like one of the stereo cameras is not detected in camera configuration 03.
                  Are you using the dual flex extension (30cm)?
                  Maybe try to swap out flex cables?
                  1 out of 7
