    VOXL2 flash error
    1068
    • Hyunsoo Kim 0H
      Hyunsoo Kim 0
      While flashing the voxl2 I am getting this error. Do you guys have any recommendation?
      [WARNING] This system image flash is intended only for the following
                platform: VOXL2 (m0054)
                Make sure that the device that will be flashed is correct.
                Flashing a device with an incorrect system image will lead
                the device to be stuck in fastboot.
      Would you like to continue with the VOXL2 (m0054) system image flash?
      1) Yes
      2) No
      #? 1
      [INFO] checking partition system::0xD3B5D7000
      [INFO] {system::0xD3B5D7000} partition returned size {0x1A435F3000}, expected {0xD3B5D7000}
      [WARNING] Partition layout was found to be incorrect, this requires
                flashing the full partition table. Flashing the partition
                table will also flash every partition causing all data on
                the device to be lost.
      When doing a full flash, make sure to backup any important files
      Would you like to continue with the full wipe/flash now?
      1) Yes
      2) No
      #? 1
      [INFO] Found all required files
      Flashing: modalai_conf | m0054-conf-fs.ext4
      [--------------------------------------------------------        ]( 88%)
      [ERROR] Failed to flash partition: modalai_conf
      target reported max download size of 805306368 bytes
      sending 'modalai_conf' (5176 KB)...
      FAILED (remote: Error: Last flash failed : Volume Full)
      finished. total time: 0.000s
        tom admin @Hyunsoo Kim 0
        @Hyunsoo-Kim-0 Can you post a picture of your hardware setup so we can confirm you're flashing the correct image?
        Nathan Sullivan 0N 2 Replies Last reply Reply Quote 0
        • Nathan Sullivan 0N
          Nathan Sullivan 0 @tom
          @tom I'm having the exact same message, host system is Ubuntu 23.10 x86_64, there's enough space on the local machine; screenshot of error and picture of board attached.
            @tom FYI 1.1.3-1 can be installed with no problems, board was previously on 1.1.2.
              tom admin @Nathan Sullivan 0
              @Nathan-Sullivan-0 Interesting... can you try forcing the board into fastboot using the button https://docs.modalai.com/voxl2-voxl2-mini-system-image/#force-voxl-2-into-fastboot
              then flashing and see if that changes anything? (make sure to select M0054-1 when prompted as your board has a QRB5165)
              Nathan Sullivan 0N 1 Reply Last reply Reply Quote 0
              • Hyunsoo Kim 0H
                Hyunsoo Kim 0
                I figured this out.. instead of flashing by sdk 1.2, first tried with 1.1.3. and then updated to sdk 1.2.
                I hope this helps you
                  @tom Sorry, I've been out on a job OCONUS for the past two weeks. I tried the fastboot force, and that seemed to work - thank you!
                    @Nathan-Sullivan-0 Great! Thanks for the update
