  3. VOXL2 flash error
VOXL2 flash error
8 Posts 3 Posters 1.7k Views 1 Watching
  • Hyunsoo Kim 0H Offline
    Hyunsoo Kim 0
    While flashing the voxl2 I am getting this error. Do you guys have any recommendation?
    [WARNING] This system image flash is intended only for the following
              platform: VOXL2 (m0054)
              Make sure that the device that will be flashed is correct.
              Flashing a device with an incorrect system image will lead
              the device to be stuck in fastboot.
    Would you like to continue with the VOXL2 (m0054) system image flash?
    1) Yes
    2) No
    #? 1
    [INFO] checking partition system::0xD3B5D7000
    [INFO] {system::0xD3B5D7000} partition returned size {0x1A435F3000}, expected {0xD3B5D7000}
    [WARNING] Partition layout was found to be incorrect, this requires
              flashing the full partition table. Flashing the partition
              table will also flash every partition causing all data on
              the device to be lost.
    When doing a full flash, make sure to backup any important files
    Would you like to continue with the full wipe/flash now?
    1) Yes
    2) No
    #? 1
    [INFO] Found all required files
    Flashing: modalai_conf | m0054-conf-fs.ext4
    [--------------------------------------------------------        ]( 88%)
    [ERROR] Failed to flash partition: modalai_conf
    target reported max download size of 805306368 bytes
    sending 'modalai_conf' (5176 KB)...
    FAILED (remote: Error: Last flash failed : Volume Full)
    finished. total time: 0.000s
    • Hyunsoo Kim 0H Hyunsoo Kim 0
      1) Yes
      2) No
      #? 1
      1) Yes
      2) No
      #? 1
      @Hyunsoo-Kim-0 Can you post a picture of your hardware setup so we can confirm you're flashing the correct image?
      Nathan Sullivan 0N 2 Replies Last reply
        Nathan Sullivan 0N Offline
        Nathan Sullivan 0
        @tom I'm having the exact same message, host system is Ubuntu 23.10 x86_64, there's enough space on the local machine; screenshot of error and picture of board attached.
          Nathan Sullivan 0
          @tom FYI 1.1.3-1 can be installed with no problems, board was previously on 1.1.2.
          • Nathan Sullivan 0N Nathan Sullivan 0
            @Nathan-Sullivan-0 Interesting... can you try forcing the board into fastboot using the button https://docs.modalai.com/voxl2-voxl2-mini-system-image/#force-voxl-2-into-fastboot
            then flashing and see if that changes anything? (make sure to select M0054-1 when prompted as your board has a QRB5165)
            Nathan Sullivan 0N 1 Reply Last reply
              Hyunsoo Kim 0
              I figured this out.. instead of flashing by sdk 1.2, first tried with 1.1.3. and then updated to sdk 1.2.
              I hope this helps you
                Nathan Sullivan 0
                @tom Sorry, I've been out on a job OCONUS for the past two weeks. I tried the fastboot force, and that seemed to work - thank you!
                  @Nathan-Sullivan-0 Great! Thanks for the update
