  3. m500 camera stream
m500 camera stream
5 Posts 2 Posters 1.1k Views 1 Watching
  • Syed OmairS Offline
    Syed OmairS Offline
    Syed Omair
    can someone tell me how I can stream video from a different camera than the hi res camera ? like I want to be able to see all of these
    cameras
    I followed steps on this site but was only able to get hires
    Link Preview Image
    Page not found
    favicon
    thank you
    • Syed OmairS Syed Omair
      cameras
      Link Preview Image
      Page not found
      favicon
      thank you
      @Syed-Omair , you can display all the video streams using voxl-portal for debugging purposes (select the camera in the Cameras menu on the top. Is this what you are trying to achieve?
      Syed OmairS 1 Reply Last reply
        Syed OmairS Offline
        Syed OmairS Offline
        Syed Omair
        I apologize for being late. I am aware of the voxl-portal for debugging purposes but no that's not what I want for now. like I want to be able to read the data frame by frame using a python script which reads from a rtsp "live" link. I think its just configuring the voxl-streamer server to something else ? idk I am lost on what to do her
        two more questions
        1. is there a way for me to also in real time read the point cloud data ? I can view one the being generated in the voxl-portal section "pointcloud" but I want to read the actual pointcloud dataset in real time so I can do some other visualizations with it.
        2. I would love if you could let me know how i can read quaternion data in real time as well..
        Thank you
          two more questions
          Thank you
          @Syed-Omair
          You can use voxl-streamer to create an rtsp stream of any of the camera images that you are either coming directly from cameras or images that are output from algorithms like qvio or dfs. You can also use voxl-streamer to serve a h264/h265 stream that has already been encoded. Here are some examples:
          #examples of images that are not h264/h265 which will be encoded by voxl-streamer
          voxl-streamer -i qvio_overlay
          voxl-streamer -i dfs_disparity
          voxl-streamer -i stereo
          voxl-streamer -i tracking
          #example of streamer a stream that is already encoded as it comes from camera server (this stream has to be enabled in `voxl-camera-server.conf`
          voxl-streamer -i hires_large_encoded
          So, you can just use voxl-inspect-cam -a to see what camera streams are available and just start voxl-streamer (in foreground for testing) with -i argument and provide the stream name. You can also check the help description by running:
          voxl-streamer -h
          It tells you how to change rtsp port and how to run multiple instances using --standalone option.
            @Syed-Omair
            voxl-streamer -h
            you can see how the point cloud data is received in our voxl-mpa-tools :
            https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/tools/voxl-inspect-points.c . This is a very simple example, but you can use it to make your own application.
            this example shows how you can inspect 6DOF pose : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/tools/voxl-inspect-pose.c (i believe you need voxl vision hub running for that)
