    voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
    FAQs
    5745
    • 이광철이
      이광철
      Hello.
      I have voxl2 mini.
      The system and kernel versions are as follows.
      system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
      kernel: #1 SMP PREEMPT Thu Oct 26 04:23:26 UTC 2023 4.19.125
      hw version: M0104
      voxl-suite: 1.1.2
      I want to use j10 External UART in spi mode.
      I called the voxl_spi_init function as below.
      SPI_BUS = 14;
      if (voxl_spi_init(SPI_BUS, SPI_MODE_0, 12000000) < 0)
      return FALSE;
      The result is ERROR in voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
      The results of ls -al /dev/spi* are as follows:
      crw------- 1 root root 153, 0 Mar 2 2023 spidev0.0
      crw------- 1 root root 153, 1 Mar 2 2023 spidev3.0
      The result of voxl-gpio -r 67 are as follows:
      where is spidev14.0?
      Or what am I doing wrong?
      Thanks.
        Alex Kushleyev ModalAI Team @이광철
        @이광철 ,
        Make sure you are using correct spi device path.
        voxl2:/$ ls /dev/spidev*
        /dev/spidev0.0  /dev/spidev11.0  /dev/spidev14.0  /dev/spidev3.0
        • adminA
          admin admin
          Hi @이광철 ,
          We defaulted this interface to SPI starting in SDK 1.1.2.
          https://docs.modalai.com/voxl2-mini-linux-user-guide/#system-image-17
          https://docs.modalai.com/voxl2-voxl2-mini-system-image/#system-image-changelog
          It can be converted back to SPI with a kernel change and rebuild if you are able to try that.
          https://docs.modalai.com/voxl2-kernel-build-guide/
          Enable:
          https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi?ref_type=heads#L93
          Disable:
          https://gitlab.com/voxl-public/system-image-build/meta-voxl2-bsp/-/blob/qrb5165-ubun1.0-14.1a/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi?ref_type=heads#L98
          이광철이 1 Reply Last reply Reply Quote 0
          • 이광철이
            이광철 @admin
            @admin
            Do I need to change the kernel to use spi14 using the voxl_spi_init function?
            or
            Is this possible using voxl2_SDK_1.1.1?
              @이광철 yes, you have to to switch the kernel. you can try using the old kernel from sdk 1.1.1. You can test it before flashing permanently : https://docs.modalai.com/voxl2-kernel-build-guide/#test . I dont see any significant changes in 1.1.2 that may affect you, but you should test before overwriting your kernel
              • 이광철이
                이광철 @Alex Kushleyev
                Hi.
                I rebuilt the kernel referring to your advice.
                The modified contents are as follows.
                modify file: build_mount/lu.um.1.2.1/apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi
                /* M0104 - J10 - GPIO 40-44 */
                &qupv3_se14_spi {
                status = "ok";
                /* M0104 - J10 JST connector */
                &qupv3_se14_2uart {
                status = "ok";
                ./qrb5165-clean.sh
                ./qrb5165-build.sh -m M0104
                After building the kernel, ttyMSM0 was created in /dev.
                However, spidev14.0 is still not found.
                ls /dev/spidev*
                spidev0.0 spidev3.0
                I'm looking forward to your advice.
                Thanks.
                  @이광철 , you need to disable uart:
                  &qupv3_se14_2uart {
                  status = "disabled";
                  • 이광철이
                    이광철 @Alex Kushleyev
                    First of all thank you for your advice.
                    &qupv3_se14_spi {
                    status = "ok";
                    &qupv3_se14_2uart {
                    Modified as above.
                    After building the kernel, the contents of /dev are as follows.
                    Why doesn't spidev14.0 exist?
                    What am I doing wrong?
                    voxl2-mini:/dev$ ls spidev*
                    spidev0.0 spidev3.0
                    voxl2-mini:/dev$ ls tty*
                    tty tty10 tty13 tty16 tty19 tty21 tty24 tty27 tty3 tty32 tty35 tty38 tty40 tty43 tty46 tty49 tty51 tty54 tty57 tty6 tty62 tty8 ttyprintk
                    tty0 tty11 tty14 tty17 tty2 tty22 tty25 tty28 tty30 tty33 tty36 tty39 tty41 tty44 tty47 tty5 tty52 tty55 tty58 tty60 tty63 tty9
                    tty1 tty12 tty15 tty18 tty20 tty23 tty26 tty29 tty31 tty34 tty37 tty4 tty42 tty45 tty48 tty50 tty53 tty56 tty59 tty61 tty7 ttyMSM0
                      @이광철 , just to double check.. after building the kernel, did you install it to voxl2 mini?
                      If all else fails, you can test (without overwriting) the kernel from SDK 1.1.1 like this :
                      voxl2-mini_SDK_1.1.1/system-image$ adb reboot bootloader
                      voxl2-mini_SDK_1.1.1/system-image$ fastboot boot qti-ubuntu-robotics-image-m0104-boot.img
                      Sending 'boot.img' (17552 KB)                      OKAY [  0.509s]
                      Booting                                            OKAY [  0.033s]
                      Finished. Total time: 0.553s
                      then adb into the device and check spi port in /dev/
                      이광철이 2 Replies Last reply Reply Quote 0
                      • 이광철이
                        이광철 @Alex Kushleyev
                        Yes
                        I built the kernel and installed it on voxl2-mini.
                        The process is as follows.
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb reboot bootloader
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_a qti-ubuntu-robotics-image-m0104-boot.img
                        Sending 'boot_a' (20088 KB) OKAY [ 0.458s]
                        Writing 'boot_a' OKAY [ 0.026s]
                        Finished. Total time: 0.637s
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_b qti-ubuntu-robotics-image-m0104-boot.img
                        Sending 'boot_b' (20088 KB) OKAY [ 0.463s]
                        Writing 'boot_b' OKAY [ 0.032s]
                        Finished. Total time: 0.654s
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot reboot
                        Rebooting OKAY [ 0.001s]
                        Finished. Total time: 0.006s
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb wait-for-device
                        C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb shell
                        kernel: #1 SMP PREEMPT Wed Mar 27 02:44:30 UTC 2024 4.19.125
                        hw version: M0104
                        voxl-suite: 1.1.2
                        no current network connection
                        • 이광철이
                          이광철 @Alex Kushleyev
                          I downloaded voxl2-mini_SDK_1.1.1.tar.gz from https://developer.modalai.com/asset/eula-download/141
                          It was tested as follows.
                          C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot boot qti-ubuntu-robotics-image-m0104-boot.img
                          Sending 'boot.img' (17548 KB) OKAY [ 0.382s]
                          Booting OKAY [ 0.034s]
                          Finished. Total time: 0.471s
                          hw version: M0104
                          voxl-suite: 1.1.2
                          spidev14.0 still does not exist.
                          There is something strange.
                          Why voxl-suite: 1.1.2?
                          voxl-suite: 1.1.1 Isn't that correct?
                            @이광철 , if you update just the kernel (or boot using a temporary one), the rest of the file system is unaffected, so voxl suite will remain the same. You can look at the kernel build dates to see the difference (it is also printed when you start adb shell).
                            I am not sure why spi is not showing up, will need to ask @admin
                              Maybe the change spi ->uart was actually made before sdk 1.1.1. We will need to double check that.
                                I confirmed that kernel from SDK 1.1.1 does not have the spi mapped. So i tried the kernel from SDK 1.0.0 and it does. In this case my board has SDK 1.1.1 installed, but i am booting into kernel from SDK 1.0.0.
                                voxl2/builds/voxl2-mini_SDK_1.0.0/system-image$ adb reboot bootloader
                                voxl2/builds/voxl2-mini_SDK_1.0.0/system-image$ fastboot boot qti-ubuntu-robotics-image-m0104-boot.img
                                Sending 'boot.img' (17552 KB)                      OKAY [  0.508s]
                                Finished. Total time: 0.573s
                                adb shell
                                kernel:       #1 SMP PREEMPT Fri May 19 22:53:15 UTC 2023 4.19.125
                                hw version:   M0104
                                voxl-suite:   1.1.1
                                voxl2-mini:/$ ls /dev/spidev*
                                Now, i am not sure why your manual kernel build did not work. if you still cannot get it to work, let us know, we can build it with spi enabled and test it for you.
                                • 이광철이
                                  이광철 @Alex Kushleyev
                                  I downloaded voxl2-mini_SDK_1.0.0.tar.gz from https://developer.modalai.com/asset/eula-download/127
                                  Sending 'boot_a' (17552 KB) OKAY [ 0.399s]
                                  Writing 'boot_a' OKAY [ 0.023s]
                                  Finished. Total time: 0.565s
                                  Sending 'boot_b' (17552 KB) OKAY [ 0.397s]
                                  Writing 'boot_b' OKAY [ 0.019s]
                                  Finished. Total time: 0.561s
                                  Rebooting OKAY [ 0.000s]
                                  Finished. Total time: 0.005s
                                  hw version: M0104
                                  voxl-suite: 1.1.2
                                  voxl2-mini:/dev$ ls spi*
                                  spidev0.0 spidev11.0 spidev14.0 spidev3.0
                                  OK!
                                  The spidev14.0 file exists.
                                  I tested it as below:
                                  voxl2-mini:/dev$ qrb5165io-spi-test -d 0
                                  failed to ping icm42688p IMU
                                  voxl2-mini:/dev$ qrb5165io-spi-test -d 11
                                  voxl2-mini:/dev$ qrb5165io-spi-test -d 3
                                  [INFO] success! ICM42688 Detected
                                  voxl2-mini:/dev$ qrb5165io-spi-test -d 14
                                  There is no response to the qrb5165io-spi-test -d 14 command.
                                  is this right?
                                  Is spidev14.0 not working?
                                    @이광철 , do you have anything connected to spidev14.0 ? You need a device connected to the spi port.
                                    If you look at the source code for this test app, it simply tries to ping a specific IMU device, which happens to be installed on board on SPI3 (ICM42688 IMU) : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/apps/examples/qrb5165io-spi-test.c
                                    So, you should connect your desired device to J10 and modify the example to communicate with your device.
                                    Also, based on this documentation, https://docs.modalai.com/voxl2-mini-connectors/#j10-pin-out-spi-mode-gpio_67--low-kernel-rebuild-required-to-use, you need to set the GPIO before using:
                                    voxl-gpio -w 67 1
                                    I hope that helps
                                    Alex KushleyevA 이광철이 2 Replies Last reply Reply Quote 0
                                      Another quick tip for testing SPI stuff. I found this useful:
                                      https://github.com/rm-hull/spidev-test/blob/master/spidev_test.c
                                      You can download this file to VOXL2, build it using
                                      gcc -O2 spidev_test.c -o spidev_test
                                      and then you can actually query the IMU on spi 3:
                                      voxl2-mini:~$ ./spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
                                      spi mode: 0x0
                                      bits per word: 8
                                      max speed: 500000 Hz (500 KHz)
                                      RX | 00 00 00 47 ...
                                      and from here we know that 0x47 is actually the value WHOAMI register of ICM42688 IMU 🙂
                                      The data i am sending to the device is 4 bytes used to query the imu, as done here . the value 0xF5 = 0x75 | 0x80 which tells the IMU to send back the value of register 0x75
                                      • 이광철이
                                        이광철 @Alex Kushleyev
                                        I will connect my spi device and let you know the results after testing.
                                        Thanks for your help.
                                        • 이광철이
                                          이광철 @Alex Kushleyev
                                          Hi.
                                          I tested it by connecting my spi device to j10.
                                          This spi device is working normally in voxl2.
                                          My program for testing also operates normally with this spi device in voxl2.
                                          However, when I test the spi device and test program on voxl mini, there is no response to the voxl_spi_write function.
                                          Also, the test below is the same as before.
                                          I need your help and thanks in advance.
                                          • 이광철이
                                            이광철 @Alex Kushleyev
                                            I tested according to your advice.
                                            This is the result of testing on my mini.
                                            voxl2-mini:~$ cd /usr/bin
                                            voxl2-mini:/usr/bin$ spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
                                            spi mode: 0x0
                                            bits per word: 8
                                            can't send spi message: Invalid argument
                                            Aborted
