  3. Forcing Voxl flight into fastboot
13 Posts 3 Posters 1.5k Views 2 Watching
    @Jayden-Smith It looks like you were successful in forcing it into fastboot. It is now waiting for it to boot back to adb which it won't be able to do if the fastboot switch is still on.
    At this point I would remove power and usb, turn off the switch, and re-connect power and usb
    Jayden SmithJ Offline
    Jayden Smith
    @tom Alright, thanks. It hasn't changed yet. At this point what should I expect?
    • Jayden SmithJ Jayden Smith
      @Jayden-Smith What do you see with lsusb? I'm wondering what mode it's enumerating into
      Jayden SmithJ 1 Reply Last reply
        Jayden Smith
        @tom This is what I see with lsusb. The Voxl shows up as Qualcomm. Inc.
          @Jayden-Smith Can you post a picture of your setup including any switches you have set?
            Jayden Smith
            tomT VinnyV 2 Replies Last reply
              @Jayden-Smith Can you try removing the add-on board and see if the board boots into the same mode when queried via. lsusb?
                Jayden Smith
                wrote on last edited by Jayden Smith
                #9
                @tom Hey, yes it boots into the same modeScreenshot from 2024-03-11 16-56-58.png
                  @Jayden-Smith The mode that it is booting into is called "EDL" (Emergency Download Mode) and unfortunately the only way to recover the board is using a tool that requires a special license from Qualcomm. The best path forward will be for you to submit an RMA for this board: https://www.modalai.com/pages/rma
                    Hi @Jayden-Smith
                    Please do not power on any circuits board while they are in or on an ESD bag.
                    Doing so can cause permanent damage.
                      Jayden Smith
                      @tom Alright. Thanks!
                      • VinnyV Vinny
                        Hi @Jayden-Smith
                        Jayden Smith
                        #13
                        @Vinny Oh, thanks for the advice!
