    voxl-px4 service hangs at startup sometimes with SDK 1.1.2
    2347
    • A
      Aaky
      Hello community,
      I have been using VOXL2 with SDK 1.1.2 with latest PX4 1.14 firmware on top. While this has been significant upgrade since last SDK and PX4 firmware version, I am experiencing strange problem with my voxl-px4 startup service. This service starts on boot but GPS LED (Holybro M8N) dosent' blink sometimes and even GCS dosent get connected to firmware. This then needs manual intervention like ssh into voxl and then perform "systemctl restart voxl-px4" or in worst case hard reboot since service restart also goes into same loop of not starting PX4 correctly.
      If you are lucky, sometimes service starts correctly and everything is fine.
      Please find logs below and help me ahead to debug this problem.
      voxl2:~$ /usr/bin/voxl-px4
      Found DSP signature file
      [INFO] Daemon mode enabled
      GPS=AUTODETECT
      RC=M0065_SBUS
      ESC=VOXL2_IO_PWM_ESC
      POWER MANAGER=VOXLPM
      DISTANCE SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: AUTODETECT
      RC: M0065_SBUS
      ESC: VOXL2_IO_PWM_ESC
      POWER MANAGER: VOXLPM
      DISTANCE SENSOR: NONE
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [parameters] BSON document size 2650 bytes, decoded 2650 bytes (INT32:47, FLOAT:75)
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI: >>> ICM42688P this: 3176ec20
      INFO  [qshell] qshell return value timestamp: 174626437, local time: 174631744
      INFO  [muorb] SLPI: Register interrupt b21d31a4 e61fedec 3176ec20
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 174670478, local time: 174674102
      INFO  [qshell] qshell return value timestamp: 174713285, local time: 174716440
      ERROR [qshell] Command failed
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 174743444, local time: 174747090
      INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
      INFO  [qshell] qshell return value timestamp: 174786779, local time: 174788641
      Looking for ncp5623c RGB LED
      INFO  [muorb] SLPI: GPS UART baudrate set to 115200
      INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
      INFO  [muorb] SLPI:  address 0x38
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 174824162, local time: 174825291
      INFO  [qshell] Send cmd: 'pca9685_pwm_out start -a 0x40 -b 4'
      INFO  [muorb] SLPI: qshell gotten: pca9685_pwm_out start -a 0x40 -b 4
      INFO  [muorb] SLPI:   arg0 = 'pca9685_pwm_out'
      INFO  [muorb] SLPI:   arg2 = '-a'
      INFO  [muorb] SLPI:   arg3 = '0x40'
      INFO  [muorb] SLPI:   arg4 = '-b'
      INFO  [muorb] SLPI:   arg5 = '4'
      INFO  [muorb] SLPI: *** I2C Device ID 0x694021 6897697
      INFO  [muorb] SLPI: running on I2C bus 4 address 0x40
      INFO  [muorb] SLPI: Ok executing command: pca9685_pwm_out start -a 0x40 -b 4
      INFO  [qshell] qshell return value timestamp: 175125498, local time: 175128045
      INFO  [muorb] SLPI: PCA9685 PWM frequency: target=50.00 real=50.03
      Starting VOXL IO for PWM ESC with SBUS RC
      INFO  [qshell] Send cmd: 'voxl2_io start'
      INFO  [muorb] SLPI: qshell gotten: voxl2_io start
      INFO  [muorb] SLPI:   arg0 = 'voxl2_io'
      INFO  [uORB] Marking DeviceNode(actuator_outputs) as advertised in process_remote_topic
      INFO  [muorb] SLPI: Opened UART connection to M0065 device on port 7
      INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
      INFO  [muorb] SLPI: u-blox protocol version: 18.00
      INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
      INFO  [uORB] Advertising remote topic sensor_gps
      M0065 SBUS RC driver already started with PWM ESC start
      INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
      Eric KatzfeyE 3 Replies Last reply Reply Quote 0
        Eric Katzfey ModalAI Team @Aaky
        @Aaky Can you provide the output of dmesg after a failure? This will help us to debug the issue.
          @Aaky How often do you see it fail to start properly?
            @Aaky If you comment out the qshell gps start command in /usr/bin/voxl-px4-start does it prevent the failure from happening?
            • A
              Aaky @Eric Katzfey
              Here's output of dmesg when this happens:
              Link to download dmesg logs : https://drive.google.com/file/d/143QVl4bhNdHPD0i8ACgGWLt7COsrljcy/view?usp=sharing
              I see this happening more often, say 5 out of 10 times.
              if i comment qshell gps start from /usr/bin/voxl-px4-start stillresult is similar, sometimes it starts sometimes it dosent.
              Let me know further steps.
                @Aaky What drone are you using? Is it a custom drone? In your first post you included the output from px4. But it doesn't look complete. Are you sure that is the complete log? If so, does it look like that every time?
                • A
                  Aaky @Eric Katzfey
                  @Eric-Katzfey Yes Eric its custom drone and the logs are actually complete posted in first post. Still if possible I will see if I can provide you with more logs. Any idea from these logs about the problem?
                    @Aaky There's only one log in the first message and it doesn't look complete. The command timed out and Command failed messages seem to be related to the attempt to start the voxl2_io driver. Can you comment that part out so that it skips trying to start the voxl2_io driver and see if it comes up then?
                    • A
                      Aaky @Eric Katzfey
                      @Eric-Katzfey Actually this driver failing happens very randomly, not always and also not because of any one particular driver in general. For example check one more dmesg and reset voxl-px4 log where voxl2_io driver spawned up correcly but still GPS LED wasn't blinking red and neither px4 got connected to GCS.
                      voxl-px4-logs : https://drive.google.com/file/d/1PHqQLldXs5XFKhHvenWqy-0nDLUOfbDB/view?usp=sharing
                      dmesg logs: https://drive.google.com/file/d/1ZOK7-ypm_9BfgbE4khD2NLKFdTecTHXD/view?usp=sharing
                      Let me know any hints to further debug this issue.
                      Alex KushleyevA Eric KatzfeyE 2 Replies Last reply Reply Quote 0
                        Alex Kushleyev ModalAI Team @Aaky
                        @Aaky , can you please confirm that you can reproduce the issue even with GPS driver completely disabled?
                        • A
                          Aaky @Alex Kushleyev
                          @Alex-Kushleyev Yes I confirm even if I disable GPS driver can reproduce this issue.
                            @Aaky Those 2 logs look normal except for the GPS taking a while to finally connect to the unit and advertise sensor_gps topic. But nothing to indicate there was any crash. So the GPS LED wasn't illuminated at all? Or was a different color? And PX4 not connecting to GCS doesn't necessarily mean that PX4 is having any problems.
                            • A
                              Aaky @Eric Katzfey
                              @Eric-Katzfey Yes PX4 dosent crash but dosent get connected to QGC inspite of having good connectivity (I have been performing ping tests). GPS LED dosent blink at all when this particular scenario occurs. As I have told before this is very random occuring problem.
                                @Aaky I'm having trouble following your comments. You say that px4 does not crash. But in the first log you posted it stops only partially through the startup script without any error indications. In that case is PX4 still running? If so, it seems like it is stuck somehow. If not, perhaps something is killing the px4 process. When this happens, adb into the voxl2 and look at voxl-inspect-services. Does it show voxl-px4 enabled and running? You say you are running this on a custom drone. Do you also have a reference drone from ModalAI? If so, does everything work fine on that drone? That is the main purpose that we sell those reference drones. It allows you to see everything working so that when you build a custom drone and something doesn't work you can compare against the reference drone.
                                • A
                                  Aaky @Eric Katzfey
                                  @Eric-Katzfey Hi Eric, My apologies for the confusion.
                                  I will correct my statement, PX4 never crashes, it just gets stuck which means the service is always running but never connects to QGC. On our custom drone post power boot up whenever we see GPS LED isn't blinking at all (neither red nor green) we come to know PX4 service is stuck somewhere. At this point if I ssh into VOXL2 and check voxl-inspect-services, I can see vozl-px4 service is definately running but GPS LED isn't blinking and also PX4 isn't connecting to QGC. These are the observations. Then if I do systemctl restart vozl-px4 , then sometimes problem gets solved and PX4 starts without getting stuck anywhere. I clarify once again, PX4 never crashes but just gets stuck somewhere. All all the logs starting from my first post involves the issue which I have described in this comment.
                                  I am very old customer of ModalAI and have been working since voxl1 on multiple custom drones so I definitely understand the underlying architecture Eric. 🙂
                                  I hope this comment clarifies the confusion.
                                    @Aaky Okay, this isn't anything we have encountered before. I'm not sure what could make PX4 get stuck like that. When it is in the stuck condition what does CPU utilization look like?
                                    • A
                                      Aaky @Eric Katzfey
                                      @Eric-Katzfey Here's screenshot of cpu utilization when this happpens. Everything looks normal.
                                        @Aaky Well, unfortunately it isn't obvious what is going wrong. You will have to start by disabling everything and when px4 comes up reliably start enabling things to find out the culprit.
