  3. Sentinel ESC blue leds don't remain solid or flash
starling
13 Posts 3 Posters 2.3k Views 2 Watching
  • I iparra
    Apparently everything is working fine but rotors won't start. After inspecting the starling I noticed the ESC leds are not solid or flashing as they are supposed to be. They flash a couple of times during power up but then remain off.
    I'm not sure if this has anything to do with it but I detected it after installing voxl-mapper package.
    What kind of checks can I perform?
    @iparra , Can you please let us know which version of the SDK you are using?
    Also, were you able to spin up motors during previous tests and now you are not able to?
    You can do a quick check of the ESCs using the following commands:
    #stop px4
    systemctl stop voxl-px4
    #run ESC scanner
    ./voxl-esc-scan.py
    This tool will attempt to detect ESCs and will let you know if it can detect all 4 ESC channels. You can also verify the params:
    ./voxl-esc-verify-params.py
    Alex KushleyevA I 2 Replies Last reply
      #stop px4
      #run ESC scanner
      ./voxl-esc-scan.py
      also, if you use one of our latest px4 packages (http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.69-202402061301_arm64.deb), you can check PX4's ESC initialization status:
      #run px4 in foreground and grep for VOXL_ESC:
      voxl-px4 -d | grep VOXL_ESC
      INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
      INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
      INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
      INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
      INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 0
      INFO  [muorb] SLPI: VOXL_ESC: 	Board Type : 37: ModalAi 4-in-1 ESC (M0134-1)
      INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900480024
      INFO  [muorb] SLPI: VOXL_ESC: 	Firmware   : version   39, hash eb6fb500
      INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : version  183, hash b4fa2cf8
      INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1646us
      INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 1
      INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D004D
      INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 621us
      INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 2
      INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900500042
      INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : versiINFO  [qshell] Send cmd: 'voxl_esc start'
      INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1120us
      INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 3
      INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D0050
      INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 617us
      INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 1
      INFO  [muorb] SLPI: VOXL_ESC: All ESCs successfully detected
      If all goes well, you should see messages similar to above. If you don't see any VOXL_ESC messages, you are probably using an older PX4 package.
        #stop px4
        #run ESC scanner
        ./voxl-esc-scan.py
        I Offline
        I Offline
        iparra
        @Alex-Kushleyev Hi, The drone was working as expected. Then, we installed from package voxl-mapper and performed some tests without the rotors for a week, just holding the drone. When we were confortable with the voxl-mapping we tried to perform some tests on the maps and the paths created and then we realized It didn't work.
        The outputs:
        voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-scan.py
        [GCC 8.4.0]
        dpkg-query: no packages found matching voxl-esc-board-detect.py
        dpkg-query: no packages found matching voxl-esc-calibrate.py
        dpkg-query: no packages found matching voxl-esc-led.py
        dpkg-query: no packages found matching voxl-esc-neopixel-test.py
        dpkg-query: no packages found matching voxl-esc-scan.py
        dpkg-query: no packages found matching voxl-esc-spin-helper.sh
        dpkg-query: no packages found matching voxl-esc-spin-sine.py
        dpkg-query: no packages found matching voxl-esc-spin-step.py
        dpkg-query: no packages found matching voxl-esc-spin.py
        dpkg-query: no packages found matching voxl-esc-tools-bin
        dpkg-query: no packages found matching voxl-esc-upload-firmware-all.sh
        dpkg-query: no packages found matching voxl-esc-upload-firmware.py
        dpkg-query: no packages found matching voxl-esc-upload-params.py
        dpkg-query: no packages found matching voxl-esc-verify-params.py
        dpkg-query: no packages found matching voxl_esc_setup_paths.py
        dpkg-query: no packages found matching voxl_serial.py
        VOXL Platform: M0054
        WARNING: Received data from SLPI for unrecognized topic aggregation, discarding data
        WARNING: Received 99 bytes of data from SLPI while SLPI uart not in use (topic aggregation)
        WARNING: Received 92 bytes of data from SLPI while SLPI uart not in use (topic aggregation)
        WARNING: Received 286 bytes of data from SLPI while SLPI uart not in use (topic aggregation)
        terminate called after throwing an instance of 'qmi_error'
        what(): qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi service error (-2)
        Aborted
        voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-verify-params.py
        [GCC 8.4.0]
        INFO: Success! Params in all ESCs are valid and identical.
        • I Offline
          I Offline
          iparra
          Output of the initialization status
          voxl2:/usr/share/modalai/voxl-esc-tools$ voxl-px4 -d | grep VOXL_ESC
          ESC=VOXL_ESC
          ESC: VOXL_ESC
          Versions of all the packages (I'm not sure about the SDK version)
          voxl2:/usr/share/modalai/voxl-esc-tools$ dpkg -l | grep voxl
          ii libvoxl-cci-direct 0.2.1 arm64 Library for CCI direct interface
          ii libvoxl-cutils 0.1.1 arm64 ModalAI's c utils
          ii mv-voxl 0.1-r0 arm64 mv version 0.1-r0
          ii royale-331-spectre-4-7 1.1.1 arm64 Royale/Spectre build for voxl platforms
          ii rtl8812au 5.6.4.2-git-r0 arm64 RTL8812au kernel driver (wifi) and supplemental files for enabling wifi on voxl2
          ii voxl-bind-spektrum 0.1.0 arm64 Utility to trigger Spektrum Bind
          ii voxl-camera-calibration 0.5.3 arm64 On-board camera calibration for VOXL
          ii voxl-camera-server 1.8.9 arm64 publishes camera frames over named pipe interface
          ii voxl-ceres-solver 2:1.14.0-10 arm64 ceres-solver for voxl
          ii voxl-configurator 0.4.8 arm64 tools to configure and test MPA
          ii voxl-cpu-monitor 0.4.7 arm64 publishes CPU Data over MPA pipe and provides fan tools
          ii voxl-docker-support 1.3.0 arm64 tools to improve the usability of docker on VOXL
          ii voxl-elrs 0.1.3 arm64 Tool to flash TX/RX with ELRS FW
          ii voxl-esc 1.3.7 arm64 Tools for ModalAI's VOXL ESC
          ii voxl-feature-tracker 0.3.2 arm64 track features on voxl
          ii voxl-flow-server 0.3.3 arm64 optical flow from feature tracker
          ii voxl-gphoto2-server 0.0.10 arm64 Gstreamer-based application to pull raw video frames from PTP cameras
          ii voxl-jpeg-turbo 2.1.3-5 arm64 libjpeg_turbo build for voxl
          ii voxl-lepton-server 1.2.0 arm64 Application to interface with flir lepton camera
          ii voxl-libgphoto2 0.0.4 arm64 Library to control digital cameras over USB
          ii voxl-libuvc 1.0.7 arm64 cross-platform library for USB video devices
          ii voxl-logger 0.3.5 arm64 misc tools for modal pipe architecture
          ii voxl-mapper 0.2.0 arm64 voxl-mapper
          ii voxl-mavcam-manager 0.5.3 arm64 ModalAI implementation of the Mavlink camera protocol
          ii voxl-mavlink 0.1.1 arm64 mavlink headers
          ii voxl-mavlink-server 1.3.2 arm64 MPA interface for mavlink over UART or UDP
          ii voxl-modem 1.0.8 arm64 VOXL Modem Utils
          ii voxl-mongoose 7.7.0-1 arm64 mongoose build for voxl
          ii voxl-mpa-to-ros 0.3.7 arm64 ROSNode converting MPA pipes
          ii voxl-mpa-tools 1.1.3 arm64 misc tools for modal pipe architecture
          ii voxl-neopixel-manager 0.0.3 arm64 background service to manage neopixel LEDs
          ii voxl-nlopt 2.5.0-4 arm64 nlopt
          ii voxl-opencv 4.5.5-2 arm64 opencv built for VOXL
          ii voxl-portal 0.6.3 arm64 Debug web interface for VOXL
          ii voxl-px4 1.14.0-2.0.63 arm64 ModalAI PX4 flight controller
          ii voxl-px4-imu-server 0.1.2 arm64 fetches imu data from PX4 running on QRB5165 DSP and publishes over MPA
          ii voxl-px4-params 0.3.3 arm64 Tool to help configure px4-parameters
          ii voxl-qvio-server 1.0.0 arm64 publishes QVIO data over named pipe interface
          ii voxl-remote-id 0.0.9 arm64 Remote ID broadcasting tool
          ii voxl-streamer 0.7.4 arm64 Gstreamer-based application to handle RTSP streaming
          ii voxl-suite 1.1.3 arm64 voxl-suite for QRB5165
          ii voxl-tag-detector 0.0.4 arm64 Detect apriltags for MPA
          ii voxl-tflite-server 0.3.1 arm64 client of voxl-camera-server that does deep learning
          ii voxl-utils 1.3.8 arm64 ModalAI common on-target utilities for VOXL
          ii voxl-uvc-server 0.1.6 arm64 libuvc application to handle UVC camera frame output to MPA
          ii voxl-vision-hub 1.7.3 arm64 main hub managing communication between VOXL MPA services and autopilots
          ii voxl-voxblox 1.1.5 arm64 voxblox library api
          ii voxl2-system-image 1.7.1-r0 arm64 Meta package that is used to track system image version for DEPENDS in debian packages
          ii voxl2-wlan 1.0-r0 arm64 Packages for voxl2 that enable wifi dongle compatibility
          • I iparra
            The outputs:
            [GCC 8.4.0]
            Aborted
            [GCC 8.4.0]
            @iparra , did you stop px4 before running the esc tools?
            maybe you need to disable px4 and reboot if that does not help:
            systemct disable voxl-px4
            reboot
            to re-enable px4 later:
            systemct enable voxl-px4
            reboot
            I 1 Reply Last reply
              reboot
              reboot
              I Offline
              I Offline
              iparra
              @Alex-Kushleyev I upgraded with apt and repeated the tests
              [GCC 8.4.0]
              Found voxl-esc tools bin version: 1.6
              INFO: ESC Information:
              INFO: ---------------------
              Board : version 37: ModalAi 4-in-1 ESC (M0134-1)
              UID : 0x203330385246571800240035
              Firmware : version 39, hash 3d7ee4eb
                  UID        : 0x20333038524657180025004D
                  UID        : 0x203330385246571800230029
                  UID        : 0x203330385246571800240021
              Found DSP signature file
              [INFO] Disabling daemon mode
              GPS=MRO_M10136A
              RC=CRSF_RAW
              ESC=VOXL_ESC
              POWER MANAGER=VOXLPM
              DISTANCE SENSOR=NONE
              OSD=DISABLE
              DAEMON_MODE=DISABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
              INFO [px4] assuming working directory is rootfs, no symlinks needed.
              INFO [muorb] Got muorb init command
              INFO [muorb] muorb protobuf initalize method succeeded
              INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
              ERROR [muorb] Test timed out waiting for response
              INFO [parameters] Starting param sync THREAD
              | ___ \ \ \ / / / |
              | |/ / \ V / / /| |
              | __/ / \ / /
              | | / /^\ \ ___ |
              _| / / |_/
              px4 starting.
              INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
              GPS: MRO_M10136A
              RC: CRSF_RAW
              ESC: VOXL_ESC
              POWER MANAGER: VOXLPM
              DISTANCE SENSOR: NONE
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO [param] selected parameter default file /data/px4/param/parameters
              ERROR [parameters] Timeout waiting for parameter_client_reset_response
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT1_CAPACITY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT1_N_CELLS
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT1_R_INTERNAL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT1_V_CHARGED
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT1_V_EMPTY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for BAT_CRIT_THR
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_ACC0_ID
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_ACC0_PRIO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_ACC0_XOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_ACC0_YOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_ACC0_ZOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO0_ID
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO0_PRIO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO0_XOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO0_YOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO0_ZOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_ID
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_PRIO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_ROT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_XODIAG
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_XOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_XSCALE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_YODIAG
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_YOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_YSCALE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_ZODIAG
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_ZOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_MAG0_ZSCALE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR0_PX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR0_PY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR1_PX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR1_PY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR2_KM
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR2_PX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR2_PY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR3_KM
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR3_PX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR3_PY
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CA_ROTOR_COUNT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CBRK_SUPPLY_CHK
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_ARM_SDCARD
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_CPU_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_LAND
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_PRFLT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_FLIGHT_UUID
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_FLTMODE1
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_FLTMODE4
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_FLTMODE6
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_OF_LOSS_T
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_SPOOLUP_TIME
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_ABL_LIM
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_EV_QMIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_GPS_CTRL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_HGT_REF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_IMU_POS_X
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_IMU_POS_Y
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_IMU_POS_Z
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_MAG_TYPE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_RNG_CTRL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for GPS_UBX_DYNMODEL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for IMU_ACCEL_CUTOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for IMU_DGYRO_CUTOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for IMU_GYRO_CUTOFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for IMU_GYRO_DNF_EN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for IMU_GYRO_RATEMAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for LNDMC_ROT_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for LNDMC_TRIG_TIME
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for LND_FLIGHT_T_LO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MAV_TYPE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_PITCHRATE_D
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_PITCHRATE_I
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_PITCHRATE_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_PITCHRATE_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_PITCH_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_ROLLRATE_D
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_ROLLRATE_I
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_ROLLRATE_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_ROLLRATE_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_ROLL_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_YAWRATE_I
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_YAWRATE_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MC_YAWRATE_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_ACC_HOR_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_ACC_UP_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_JERK_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_LAND_SPEED
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_THR_HOVER
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_THR_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_THR_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_TILTMAX_AIR
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_TKO_RAMP_T
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_VEL_MANUAL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_CRUISE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_MAN_EXPO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_D_ACC
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_I_ACC
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_P_ACC
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_YAW_EXPO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_MAN_EXPO
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_P
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_DN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_UP
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_P_ACC
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_V_AUTO_DN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_V_AUTO_UP
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for NAV_ACC_RAD
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC12_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC12_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC12_TRIM
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MAX
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MIN
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_CHAN_CNT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_FLTMODE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_KILL_SW
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_PITCH
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_ROLL
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_THROTTLE
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_YAW
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RTL_DESCEND_ALT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RTL_RETURN_ALT
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SENS_BOARD_X_OFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SENS_BOARD_Y_OFF
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_AUTOSTART
              ERROR [parameters] Timeout waiting for parameter_client_set_value_response for THR_MDL_FAC
              INFO [parameters] BSON document size 2888 bytes, decoded 2888 bytes (INT32:33, FLOAT:99)
              INFO [logger] logger started (mode=all)
              INFO [qshell] Send cmd: 'icm42688p start -s'
              ERROR [qshell] Command failed
              INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
              INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
              INFO [qshell] Send cmd: 'gps start'
              Looking for ncp5623c RGB LED
              INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
              Starting CRSF RC driver
              INFO [qshell] Send cmd: 'crsf_rc start -d 7'
              INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
              INFO [qshell] Send cmd: 'sensors start'
              INFO [qshell] Send cmd: 'ekf2 start'
              INFO [qshell] Send cmd: 'mc_pos_control start'
              • I iparra
                [GCC 8.4.0]
                GPS=MRO_M10136A
                RC=CRSF_RAW
                ESC=VOXL_ESC
                OSD=DISABLE
                DAEMON_MODE=DISABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                | ___ \ \ \ / / / |
                | |/ / \ V / / /| |
                | __/ / \ / /
                | | / /^\ \ ___ |
                _| / / |_/
                px4 starting.
                GPS: MRO_M10136A
                RC: CRSF_RAW
                ESC: VOXL_ESC
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                @iparra,
                Sometimes after running voxl-esc tools you need to reboot volx2 before you can run PX4 again. Can you please try that and check the PX4 log for VOXL_ESC messages?
                Based on the output of voxl-esc scan, your ESCs are all detected, so there is no issue in communication there.
                Another thing to try is the actuator test in QGC, which can let you spin up motors one by one (make sure to remove propellers before testing for safety)
                  @iparra,
                  I Offline
                  I Offline
                  iparra
                  @Alex-Kushleyev Using QGC seems that we have lost some configuration of the rotors. It says "One or more actuator still needs to be assigned an output"
                  I attached a screen capture
                  • I iparra
                    Yes, it looks like your params for VOXL ESC have been wiped.
                    If you take a look at this document : https://docs.modalai.com/voxl-px4-files/ , it points you here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params and specifically for Sentinel here are the params you can load using QGC :
                    https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/Sentinel_V1.params?ref_type=heads
                    You can try just setting the VOXL ESC motor mapping and verify it using actuator test, but if those params got wiped for some reason, it is possible that other params also got wiped, so it may be best to restore the default Sentinel params.
                      I Offline
                      I Offline
                      iparra
                      @Alex-Kushleyev Thank you Alex, we have a Starling with Voxl 2 so I assume we need Starling_V2.params
                      We also read that there's a backup of the params on /etc/modalai/voxl-px4-set-default-parameters.config. We have checked and that file exists. We will try to restore the params and get back to you.
                      • I iparra
                        @iparra That file is not a backup of parameters. It is only used if there are no saved parameters and will just populate a few reasonable default values for certain VOXL2 parameters.
                          I Offline
                          I Offline
                          iparra
                          @Eric-Katzfey We loaded the default parameters with QGC and everything is back to normal.
                          Thank you for your help!
