  3. M0040 Time of Flight sensor FPS
image-sensor
29 Posts 3 Posters 8.6k Views 2 Watching
    @Darshit-Desai the error is here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp#L561
    But you can't just modify the check condition. In order to switch to a higher FPS than 15Hz, the sensor needs to use a medium or short range mode (currently long range mode). So a few other things need to change.
    So do you want me to use dev version or sdk 1.1.2 version as starting point? It may be easier for you, since everything will remain the same (no other changes in camera server).
    this change will (eventually) make it to dev anyway, i could go directly to dev (in fact it will be simpler for me), but i am offering you a choice 🙂
    Darshit DesaiD Offline
    Darshit Desai
    @Alex-Kushleyev Presently I only require a bump in the FPS, so I suggest you do changes by taking sdk1.1.2 as the base. If you use the dev version there might be unaccounted bugs which I don't want in my build
      @Darshit-Desai , yes that is exactly my thought. i will use sdk1.1.2 as the base.
        @Darshit-Desai , to my own surprise, this was quick. I was able to test at 30, 45 and 60fps all of which will use the short range mode of the sensor. I have done minimal testing, but the depth, confidence and Ir images look good in voxl-portal
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/tree/sdk1.1.2-add-tof-fps-options
        Just build voxl camera server from this branch, make package, install package on voxl2 and update your fps parameter from 15 to either 30, 45, 60 in voxl-camera-server.conf
        Let me know how it goes!
          Darshit Desai
          @Alex-Kushleyev Thank you I am trying this out right now, Which option should I choose here for repo version
          Also when I do git branch after cloning the repo it only shows master branch I had to manually write the branch name
            @Darshit-Desai ,
            git branch -a shows all the branches
            for installing deps, use sdk-1.1 since we based this branch off sdk-1.1.2
              @Darshit-Desai ,
              Darshit Desai
              #19
              @Alex-Kushleyev Thanks it worked it shows point cloud at 30 FPS when I set it to 30 in .conf file
              I will try it out with other services like mpatoros2, tfliteserver in tandem see if there is a drop in frame rate or performance
                Darshit Desai
                #20
                @Alex-Kushleyev right now the FPS values need to be a multiple of 15 for some reason because I tried 35, and 20 FPS and the camera server refuses to start
                  @Darshit-Desai , i will double check the available FPS. Not all arbitrary FPS are possible.
                    If you run “voxl-camera-server -d 0”, you will see a lot of debug messages including all possible tof modes. If you see something you want to try, you can modify the code. Mode9 is long range and mode5 is short range.
                      Darshit Desai
                      @Alex-Kushleyev I dont see mode descriptions when I try this
                      voxl2:/etc/modalai$ voxl-camera-server -d 0
                      detected system image 1.7.1
                      using new imx214 defaults
                      configuration for 3 cameras:
                      cam #0
                          sensor type:         pmd-tof
                          isEnabled:           1
                          camId:               0
                          camId2:              -1
                          fps:                 20
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           224
                          pre_height:          1557
                          en_raw_preview:      1
                          en_small_video:      0
                          small_video_width:   -1
                          small_video_height:  -1
                          en_large_video:      0
                          large_video_width:   -1
                          large_video_height:  -1
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             off
                          standby_enabled:     0
                          decimator:           5
                          independent_exposure:0
                      cam #1
                          sensor type:         imx214
                          isEnabled:           1
                          camId:               1
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          0
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      0
                          en_small_video:      1
                          small_video_width:   1024
                          small_video_height:  768
                          en_large_video:      1
                          large_video_width:   4208
                          large_video_height:  3120
                          en_snapshot:         1
                          snap_width:          4208
                          snap_height:         3120
                          ae_mode:             isp
                          standby_enabled:     0
                          decimator:           1
                      cam #2
                          sensor type:         ov7251
                          isEnabled:           1
                          camId:               2
                          camId2:              -1
                          fps:                 30
                          en_rotate:           0
                          en_rotate2:          0
                          en_preview:          1
                          pre_width:           640
                          pre_height:          480
                          en_raw_preview:      1
                          en_small_video:      0
                          en_large_video:      0
                          en_snapshot:         0
                          snap_width:          -1
                          snap_height:         -1
                          ae_mode:             lme_msv
                          standby_enabled:     0
                          decimator:           1
                      DEBUG:   ----------- Number of cameras: 3
                      DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x007A, Sensor Id: 0x003D
                      DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0020, Sensor Id: 0x0214
                      DEBUG:   Cam idx: 2, Cam slot: 3, Slave Address: 0x00E2, Sensor Id: 0x7750
                      GPS server Connected
                      DEBUG:   Connected to cpu-monitor
                      DEBUG:   ------ voxl-camera-server: Starting 3 cameras
                      Starting Camera: tof (id #0)
                      DEBUG:   Checking Gain limits for Camera: tof
                      DEBUG:   cam ID 0 checking for fmt:   38  w:  224 h: 1557 o:   0
                      DEBUG:   i:  0 fmt: 34 w: 176 h: 144 o:0
                      DEBUG:   i:  4 fmt: 34 w: 176 h: 144 o:1
                      DEBUG:   i:  8 fmt: 35 w: 176 h: 144 o:0
                      DEBUG:   i: 12 fmt: 35 w: 176 h: 144 o:1
                      DEBUG:   i: 16 fmt: 33 w: 176 h: 144 o:0
                      DEBUG:   i: 20 fmt: 37 w: 224 h:1557 o:0
                      DEBUG:   i: 24 fmt: 38 w: 224 h:1557 o:0
                      DEBUG:   i: 28 fmt: 32 w: 224 h:1557 o:0
                      DEBUG:   i: 32 fmt: 36 w: 224 h:1557 o:0
                      VERBOSE: Successfully found configuration match for camera 0: 224x1557
                      DEBUG:   Converted gralloc flags 0x20900 to GBM flags 0x1400000
                      VERBOSE: Dumping GBM flags
                      DEBUG:   	Found flag GBM_BO_USAGE_HW_COMPOSER_QTI
                      VERBOSE: Opened GBM fd
                      VERBOSE: Created GBM device
                      DEBUG:   Allocated BO with width=224 height=1557 stride=336 aligned_w=336 aligned_h=1557 size=524288 flags=0x20900 format=GBM_FORMAT_RAW12
                      VERBOSE: Entered thread: cam0-request(tid: 3925)
                      DEBUG:   Started Camera: tof
                      Starting Camera: hires (id #1)
                      ERROR:   Invalid TOF framerate: 20, must be either 5 or 15
                      ERROR:   Failed to construct request settings for camera: tof
                      WARNING: Thread: tof request thread Received ESTOP
                      VERBOSE: Leaving tof request thr
                      ```ead
                        cam #0
                            isEnabled:           1
                            camId:               0
                            camId2:              -1
                            fps:                 20
                            en_rotate:           0
                            en_rotate2:          0
                            en_preview:          1
                            pre_width:           224
                            pre_height:          1557
                            en_raw_preview:      1
                            en_small_video:      0
                            en_large_video:      0
                            en_snapshot:         0
                            snap_width:          -1
                            snap_height:         -1
                            ae_mode:             off
                            standby_enabled:     0
                            decimator:           5
                        cam #1
                            sensor type:         imx214
                            isEnabled:           1
                            camId:               1
                            camId2:              -1
                            fps:                 30
                            en_rotate:           0
                            en_rotate2:          0
                            en_preview:          0
                            pre_width:           640
                            pre_height:          480
                            en_raw_preview:      0
                            en_small_video:      1
                            en_large_video:      1
                            en_snapshot:         1
                            snap_width:          4208
                            snap_height:         3120
                            ae_mode:             isp
                            standby_enabled:     0
                            decimator:           1
                        cam #2
                            sensor type:         ov7251
                            isEnabled:           1
                            camId:               2
                            camId2:              -1
                            fps:                 30
                            en_rotate:           0
                            en_rotate2:          0
                            en_preview:          1
                            pre_width:           640
                            pre_height:          480
                            en_raw_preview:      1
                            en_small_video:      0
                            en_large_video:      0
                            en_snapshot:         0
                            snap_width:          -1
                            snap_height:         -1
                            ae_mode:             lme_msv
                            standby_enabled:     0
                            decimator:           1
                        ```ead
                        Darshit Desai
                        #24
                        @Alex-Kushleyev I found where the code changes were done and technically all arbitrary frame rates should work if we remove the == comparison with a range based comparison, but before changing that is there a reason why it is kept discrete? Can this discrete values be made into multiples of 5?
                        if(configInfo.fps != 5 && configInfo.fps != 15 && configInfo.fps != 30 && configInfo.fps != 45 && configInfo.fps != 60) {
                                    M_ERROR("Invalid TOF framerate: %d, must be either 5 or 15\n", configInfo.fps);
                                    return -1;
                        Because the settings selection for long_range or short_range is just a simple if else condition
                                      return -1;
                          @Darshit-Desai ,
                          First set the framerate to one that is currently supported, then run voxl-camera-server -d 0. Then you will see the possible tof modes.
                          The tof sensor does not support arbitrary fps
                            @Darshit-Desai ,
                            Darshit Desai
                            @Alex-Kushleyev I got it about the debug command.
                            On the topic of arbitrary fps, the sensor supports only 5, 15, 30, 45 and 60 according to the above code snippet. Nothing in the middle not even fps with multiples of 10 or 5. (Like 20, 25, 40, 50, 55)
                              #27
                              @Darshit-Desai , this check i added quickly just to allow additional rates other than 5 and 15 originally supported.
                              Based on the output of the supported use cases (from voxl-camera-server -d 0 | grep usecase), here are all the supported modes:
                              Long Range: 5, 10, 15, 20, 30
                              Short Range: 15, 30, 45, 60
                              Based on this information, you can experiment with the short / long range and desired FPS by modifying the camera server code directly (including logic for checking fps and setting long/short range). In future we will most likely add a param for selecting the range mode.
                              Just to clarify, the use case information that lists range mode and fps is printed from the low level TOF driver, but the fps checks that you are referring to are in camera server high level code.
                                Darshit Desai
                                @Alex-Kushleyev So I got it how to check the long range and short range modes, the last commit on the code shows that you only changed the if condition and the LONG_RANGE & SHORT_RANGE settings. For multiple FPS rates can I just edit the code to add something like this,
                                        setExposure = 2259763;
                                        setGain     = 200;
                                        if(configInfo.fps != 5 && configInfo.fps != 15) {
                                        if(configInfo.fps != 5 && configInfo.fps != 15 && configInfo.fps != 30 && configInfo.fps != 45 && configInfo.fps != 60 && configInfo.fps != 10 && configInfo.fps != 20) {
                                            M_ERROR("Invalid TOF framerate: %d, must be either 5, 10, 15, 20, 30, 45, 60 \n", configInfo.fps);
                                            return -1;
                                        initializationData.numDataTypes  = 1;
                                        initializationData.pListener     = this;
                                        initializationData.frameRate     = configInfo.fps;
                                        initializationData.range         = RoyaleDistanceRange::LONG_RANGE;
                                        //Change the below condition according to testing
                                        if (configInfo.fps <= 15) {
                                            M_DEBUG("Selecting TOF Long Rage setting\n");
                                        else {
                                            initializationData.range         = RoyaleDistanceRange::SHORT_RANGE;
                                            M_DEBUG("Selecting TOF Short Rage setting\n");
                                        #ifdef APQ8096
                                            VCU_silent(
                                          setGain     = 200;
                                              return -1;
                                          else {
                                          #ifdef APQ8096
                                              VCU_silent(
                                  @Darshit-Desai , yes, feel free to modify the code as you need for right now for your own testing. Once i have a chance, i will make the mode selection (long / short) and FPS more flexible.
                                  I hope this unblocked your work and you can move forward.
