  2. Questions by Product
  3. voxlmpa2ros not working starling with sdk version 1.1.2
Scheduled Pinned Locked Moved Questions by Product
8 Posts 2 Posters 1.6k Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    Voxl mpa to ros fails to launch on the starling drone with ros melodic.
    voxl2:~$ source ros_env.sh
    ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
    VOXL IP is:  192.168.50.23
    ROS_IP is:  192.168.50.23
    ROS_HOSTNAME is:  192.168.50.23
    ROS_MASTER_URI is:  http://localhost:11311
    voxl2:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/84adc3a4-bfe2-11ee-a05b-00c0cab3a2b6/roslaunch-m0054-3291.log
    Checking log directory for disk usage. This may take a while.
    Press Ctrl-C to interrupt
    Done checking log file disk usage. Usage is <1GB.
    started roslaunch server http://192.168.50.23:44943/
    SUMMARY
    PARAMETERS
     * /rosdistro: melodic
     * /rosversion: 1.14.13
    NODES
        voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
    auto-starting new master
    process[master]: started with pid [3305]
    ROS_MASTER_URI=http://localhost:11311
    setting /run_id to 84adc3a4-bfe2-11ee-a05b-00c0cab3a2b6
    process[rosout-1]: started with pid [3316]
    started core service [/rosout]
    /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node: error while loading shared libraries: libimage_transport.so: cannot open shared object file: No such file or directory
    failed to start local process: /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/84adc3a4-bfe2-11ee-a05b-00c0cab3a2b6/voxl_mpa_to_ros_node-2.log
    local launch of voxl_mpa_to_ros/voxl_mpa_to_ros_node failed
    [voxl_mpa_to_ros_node-2] process has died [pid -1, exit code 127, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/84adc3a4-bfe2-11ee-a05b-00c0cab3a2b6/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/84adc3a4-bfe2-11ee-a05b-00c0cab3a2b6/voxl_mpa_to_ros_node-2*.log
    voxl2 details:
    voxl2:~$ voxl-version
    system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.1.2
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2024-01-29 20:29:28
    List:
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0
    	qrb5165-imu-server          1.0.1
    	qrb5165-rangefinder-server  0.1.1
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3
    	qrb5165-tflite              2.8.0-2
    	voxl-bind-spektrum          0.1.0
    	voxl-camera-calibration     0.5.3
    	voxl-camera-server          1.8.9
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.7
    	voxl-feature-tracker        0.3.2
    	voxl-flow-server            0.3.3
    	voxl-gphoto2-server         0.0.10
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-libgphoto2             0.0.4
    	voxl-libuvc                 1.0.7
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.2
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-tools              1.1.3
    	voxl-neopixel-manager       0.0.3
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.3
    	voxl-px4                    1.14.0-2.0.63
    	voxl-px4-imu-server         0.1.2
    	voxl-px4-params             0.3.3
    	voxl-qvio-server            1.0.0
    	voxl-remote-id              0.0.9
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.2
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.2
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.3
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
      SUMMARY
      PARAMETERS
      NODES
      voxl2 details:
      hw version:   M0054
      voxl-suite:   1.1.2
      Packages:
      List:
      	libmodal-cv                 0.4.0
      	libmodal-json               0.4.3
      	libmodal-pipe               2.9.2
      	libqrb5165-io               0.4.2
      	mv-voxl                     0.1-r0
      	qrb5165-bind                0.1-r0
      	voxl-elrs                   0.1.3
      	voxl-esc                    1.3.7
      	voxl-libuvc                 1.0.7
      	voxl-logger                 0.3.5
      	voxl-mavlink                0.1.1
      	voxl-modem                  1.0.8
      	voxl-opencv                 4.5.5-2
      	voxl-portal                 0.6.3
      	voxl-streamer               0.7.4
      	voxl-suite                  1.1.2
      	voxl-utils                  1.3.3
      	voxl2-wlan                  1.0-r0
      Darshit Desai
      I tried using downgraded versions of sdk from 1.1.2 to 1.0.0 and all of them have this same error
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        @Darshit-Desai - ros melodic is ros1, not ros2. If you are using ros melodic - you will need to install the lib image transport package. You can do that via the following:
        sudo apt-get install ros-melodic-image-transport-plugins
        Darshit DesaiD 2 Replies Last reply
          Darshit Desai
          @Zachary-Lowell-0 Thank you I will try that out, I also tried to install ros2 but while building voxl-mpa-to-ros-2 in the emulator it shows this error. I have made a separate issue here,
          Link Preview Image
          VOXL2 mpatoros2 build
          I have been following instructions of building mpatoros2 for voxl2 starling using the emulator but everytime I try to build it it shows some error related to...
          favicon
          ModalAI Forum (forum.modalai.com)
            Darshit Desai
            @Zachary-Lowell-0 said in voxlmpa2ros not working starling with sdk version 1.1.2:
            Also I get this error when I try to install image transport
            This error comes up in all versions of sdk starting from sdk v1.0.0 to 1.1.2
              Darshit Desai
              @Zachary-Lowell-0 anything more which I can do here?
                Zachary Lowell 0
                It most likely requires more than just the plugins then - please run sudo apt-get install ros-melodic-image-transport*
                and then rerun.
                  and then rerun.
                  Darshit Desai
                  @Zachary-Lowell-0 Ok got it this worked. Thanks
