  3. Extracting images from a rosbag and image format of hires_small_color mpa topic
7 Posts 2 Posters 1.2k Views 1 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    I am trying to extract images from a rosbag which i recorded for the following topic /hires_small_color - sensors_msg/msg/Image but when the script runs it shows that the image has only two topics, here's the example script, is the image of a specific encoding which is causing this, I checked by playing the rosbag there the image is showing as color image
    #!/usr/bin/env python
    # -*- coding: utf-8 -*-
    # Copyright 2016 Massachusetts Institute of Technology
    """Extract images from a rosbag.
    import os
    import argparse
    import cv2
    import rosbag
    from sensor_msgs.msg import Image
    from cv_bridge import CvBridge
    def main():
        """Extract a folder of images from a rosbag.
        parser = argparse.ArgumentParser(description="Extract images from a ROS bag.")
        parser.add_argument("bag_file", help="Input ROS bag.",  default="2023-09-30-00-07-26.bag")
        parser.add_argument("output_dir", help="Output directory.", default="output_images")
        parser.add_argument("image_topic", help="Image topic.", default="/voxl/hires_small_color")
        args = parser.parse_args()
        print ("Extract images from %s on topic %s into %s" % (args.bag_file,
                                                              args.image_topic, args.output_dir))
        bag = rosbag.Bag(args.bag_file, "r")
        bridge = CvBridge()
        count = 0
        for topic, msg, t in bag.read_messages(topics=[args.image_topic]):
            cv_img = bridge.imgmsg_to_cv2(msg, desired_encoding="passthrough")
            cv2.imwrite(os.path.join(args.output_dir, "frame%06i.png" % count), cv_img)
            print ("Wrote image %i" % count)
            count += 1
        bag.close()
        return
    if __name__ == '__main__':
        main()
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @Darshit-Desai said in Extracting images from a rosbag and image format of hires_small_color mpa topic:
      import cv2
      import rosbag
      def main():
      bridge = CvBridge()
      count = 0
          count += 1
      bag.close()
      return
      if name == 'main':
      main()
      @Darshit-Desai - I will look into this today and get an answer for you. The endpoint in which you are subscribing to is not an encoded frame but the raw image. Is this in a docker image by chance? I know that cv_bridge is not supported in c/c++ for ros1 on the voxl2 as it corrupts the version of opencv that we leverage on the board.
        import cv2
        import rosbag
        def main():
        bridge = CvBridge()
        count = 0
            count += 1
        bag.close()
        return
        if name == 'main':
        main()
        Darshit Desai
        @Zachary-Lowell-0 Actually I ran this code locally on my desktop after recording the hires_small_color topic in a rosbag. Also when trying to rosbag the hires_small_encoded or any other encoded topic it throws an error, that is why I had to record this format of the image.
          Zachary Lowell 0
          @Darshit-Desai I was able to save the images to a rosbag for the grey and color images and then use your script to view them via the code you attached. As for the encoded - there is a bug in the code that is publishing them as an image, when obviously an encoded h264 image is not an image. I will update the source code to reflect this rosmsg that is most likely a string or something.
            Darshit Desai
            @Zachary-Lowell-0 Actually the hires_small_grey works for me too, It is because it is a 3 channel image. But when I try to extract hires_small_color it shows invalid format. I checked in the documentation its a NV12 Format image and searched for code references to unpack such an image but wasn't able to find any
              Zachary Lowell 0
              The issue is with your reviewing code @Darshit-Desai - not the mpa-to-ros then. Since YUV is a 2 channel image, you need to use some opencv manipulation prior to saving the image:
                      bgr_img = cv2.cvtColor(cv_img, cv2.COLOR_YUV2BGR_UYVY)  # Replace with the correct YUV422 format code
                      cv2.imwrite(os.path.join(args.output_dir, "frame%06i.png" % count), bgr_img)
              Add the following above to your code and you will be able to save the color images as well.
                Darshit Desai
                @Zachary-Lowell-0 Yes that was my initial question, thanks it worked, although I didn't know NV12 means YUV format
