Unable to retrieve full set of parameters Voxl2 -> QgroundControl
Hello guys,
I just reinstalled from scratch the SDK and the operating system of my voxl2 (from flashing the firmware to SDK 1.2). I can access the voxl2 portal, seeing cameras and similar. However, when I try to configure my UAV using QGroundControl, it is very slow to download the parameter list (20% of package loss rate). However, when it finished I had the error: Unable to retrieve the full set of parameters.
Sadly, in this state, I cannot access the configuration options of Qground (ie. RC configuration, flight mode and similar).
Where I am wrong? Before reinstalling everything, Qground was working!Thanks,
Hello guys,
@jocacace13 It sounds like you have a weak network connection between voxl2 and your host machine.
@tom Thanks for the reply. I thought the same at the start. I also tried connecting with the ethernet cable, and the results were the same. Do you mind if any other issues can cause the same behaviour?
