  3. Update fw and params causing NO ESC detected
esc
21 Posts 2 Posters 6.6k Views 1 Watching
  • W Will
    @Alex-Kushleyev , I've acquired four additional motors for testing with the commands below. Despite this, I continue to encounter a scenario where one of the motors abruptly stops, leading to the drone falling from the sky. Conversely, I've assessed the thermal conditions of the motors and found that they aren't excessively hot to the touch. The temperature increases when using a 1045 propeller, while with the current 9450 propeller, there is minimal heat.
    • ./voxl-esc-spin.py --power 100 --ramp-time 5.0 --timeout 5.5 --cmd-rate 1000 --enable-plot 1 --id 255 # without propeller
    • ./voxl-esc-spin.py --power 90 --ramp-time 5.0 --timeout 5.5 --cmd-rate 1000 --enable-plot 1 --id 255 # without propeller
    • ./voxl-esc-spin.py --power 60 --ramp-time 5.0 --timeout 5.5 --cmd-rate 1000 --enable-plot 1 --id 255 # with propeller
    • ./voxl-esc-spin.py --power 90 --ramp-time 5.0 --timeout 5.5 --cmd-rate 1000 --enable-plot 1 --id 255 # with propeller
    I encountered another issue with these commands where, at times, the plot isn't generated, and the RPM value appears incorrect. To resolve this, I have to use ctrl-c to stop and rerun it. I attempted lowering the power value to address this issue, but it seems to occur randomly.
    python voxl-esc-spin.py --power 10 --ramp-time 5.0 --timeout 5.5 --cmd-rate 1000 --enable-plot 1 --id 255
    Detected Python version : 3.10.9 (main, Mar 1 2023, 18:23:06) [GCC 11.2.0]
    INFO: All COM ports:
    /dev/ttyUSB0 : FT232R USB UART - FT232R USB UART
    INFO: UART Port Candidates:
    /dev/ttyUSB0
    INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 2000000
    INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 250000
    INFO: ESC(s) detected on port: /dev/ttyUSB0, baud rate: 250000
    Board : version 34: ModalAi 4-in-1 ESC (M0117-1)
    UID : 0x203034305743570C001A0038
    Firmware : version 39, hash 3d7ee4eb
    Bootloader : version 183, hash 25317f42
    UID        : 0x203034305743570C003D0050
    UID        : 0x203034305743570C003D0054
    UID        : 0x203034305743570C003D0056
    WARNING:
    from all persons.
    Type "Yes" to continue: Yes
    [0.009] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
    [0.009] (1) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
    [0.009] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
    [0.009] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
    [0.019] (0) RPM: 6, PWR: 0, VOLTAGE: 12.380V, TEMPERATURE: 37.20C, CURRENT: 0.000A
    [0.019] (1) RPM: 11, PWR: 0, VOLTAGE: 12.384V, TEMPERATURE: 36.43C, CURRENT: 0.000A
    [0.019] (2) RPM: 8, PWR: 0, VOLTAGE: 12.377V, TEMPERATURE: 36.43C, CURRENT: -0.032A
    [0.019] (3) RPM: 5, PWR: 0, VOLTAGE: 12.372V, TEMPERATURE: 37.04C, CURRENT: 0.024A
    [0.030] (0) RPM: 6, PWR: 0, VOLTAGE: 12.380V, TEMPERATURE: 37.20C, CURRENT: 0.000A
    [0.030] (1) RPM: 11, PWR: 0, VOLTAGE: 12.384V, TEMPERATURE: 36.43C, CURRENT: 0.000A
    [0.030] (2) RPM: 8, PWR: 0, VOLTAGE: 12.377V, TEMPERATURE: 36.43C, CURRENT: -0.032A
    [0.030] (3) RPM: 5, PWR: 0, VOLTAGE: 12.372V, TEMPERATURE: 37.04C, CURRENT: 0.024A
    [0.039] (0) RPM: 6, PWR: 0, VOLTAGE: 12.380V, TEMPERATURE: 37.20C, CURRENT: 0.000A
    [0.039] (1) RPM: 11, PWR: 0, VOLTAGE: 12.384V, TEMPERATURE: 36.43C, CURRENT: 0.000A
    [0.039] (2) RPM: 8, PWR: 0, VOLTAGE: 12.377V, TEMPERATURE: 36.43C, CURRENT: -0.032A
    [0.039] (3) RPM: 5, PWR: 0, VOLTAGE: 12.372V, TEMPERATURE: 37.04C, CURRENT: 0.024A
    [0.050] (0) RPM: 6, PWR: 0, VOLTAGE: 12.380V, TEMPERATURE: 37.20C, CURRENT: 0.000A
    [0.050] (1) RPM: 11, PWR: 0, VOLTAGE: 12.384V, TEMPERATURE: 36.43C, CURRENT: 0.000A
    [0.050] (2) RPM: 44, PWR: 0, VOLTAGE: 12.364V, TEMPERATURE: 36.43C, CURRENT: 0.176A
    [0.050] (3) RPM: 45, PWR: 0, VOLTAGE: 12.358V, TEMPERATURE: 37.02C, CURRENT: 0.200A
    [0.065] (0) RPM: 46, PWR: 0, VOLTAGE: 12.359V, TEMPERATURE: 37.22C, CURRENT: 0.328A
    [0.065] (1) RPM: 47, PWR: 0, VOLTAGE: 12.373V, TEMPERATURE: 36.38C, CURRENT: 0.216A
    [0.065] (2) RPM: 48, PWR: 0, VOLTAGE: 12.356V, TEMPERATURE: 36.46C, CURRENT: 0.224A
    [0.065] (3) RPM: 55, PWR: 0, VOLTAGE: 12.355V, TEMPERATURE: 36.93C, CURRENT: 0.360A
    [0.070] (0) RPM: 46, PWR: 0, VOLTAGE: 12.359V, TEMPERATURE: 37.22C, CURRENT: 0.328A
    [0.070] (1) RPM: 60, PWR: 0, VOLTAGE: 12.363V, TEMPERATURE: 36.29C, CURRENT: 0.440A
    [0.070] (2) RPM: 61, PWR: 0, VOLTAGE: 12.342V, TEMPERATURE: 36.48C, CURRENT: 0.328A
    [0.070] (3) RPM: 55, PWR: 0, VOLTAGE: 12.355V, TEMPERATURE: 36.93C, CURRENT: 0.360A
    [0.080] (0) RPM: 46, PWR: 0, VOLTAGE: 12.359V, TEMPERATURE: 37.22C, CURRENT: 0.328A
    [0.080] (1) RPM: 60, PWR: 0, VOLTAGE: 12.363V, TEMPERATURE: 36.29C, CURRENT: 0.440A
    [0.080] (2) RPM: 61, PWR: 0, VOLTAGE: 12.342V, TEMPERATURE: 36.48C, CURRENT: 0.328A
    [0.080] (3) RPM: 55, PWR: 0, VOLTAGE: 12.355V, TEMPERATURE: 36.93C, CURRENT: 0.360A
    [0.089] (0) RPM: 46, PWR: 0, VOLTAGE: 12.359V, TEMPERATURE: 37.22C, CURRENT: 0.328A
    [0.089] (1) RPM: 60, PWR: 0, VOLTAGE: 12.363V, TEMPERATURE: 36.29C, CURRENT: 0.440A
    [0.089] (2) RPM: 61, PWR: 0, VOLTAGE: 12.342V, TEMPERATURE: 36.48C, CURRENT: 0.328A
    [0.089] (3) RPM: 55, PWR: 0, VOLTAGE: 12.355V, TEMPERATURE: 36.93C, CURRENT: 0.360A
    [0.099] (0) RPM: 46, PWR: 0, VOLTAGE: 12.359V, TEMPERATURE: 37.22C, CURRENT: 0.328A
    [0.099] (1) RPM: 60, PWR: 0, VOLTAGE: 12.363V, TEMPERATURE: 36.29C, CURRENT: 0.440A
    [0.099] (2) RPM: 61, PWR: 0, VOLTAGE: 12.342V, TEMPERATURE: 36.48C, CURRENT: 0.328A
    [0.099] (3) RPM: 55, PWR: 0, VOLTAGE: 12.355V, TEMPERATURE: 36.93C, CURRENT: 0.360A
    [0.111] (0) RPM: 94, PWR: 0, VOLTAGE: 12.346V, TEMPERATURE: 37.25C, CURRENT: 0.288A
    [0.111] (1) RPM: 99, PWR: 0, VOLTAGE: 12.356V, TEMPERATURE: 36.35C, CURRENT: 0.360A
    [0.111] (2) RPM: 105, PWR: 0, VOLTAGE: 12.346V, TEMPERATURE: 36.45C, CURRENT: 0.360A
    [0.111] (3) RPM: 97, PWR: 0, VOLTAGE: 12.350V, TEMPERATURE: 36.99C, CURRENT: 0.424A
    [5.476] (1) RPM: 643, PWR: 0, VOLTAGE: 12.328V, TEMPERATURE: 36.42C, CURRENT: 0.616A
    [5.476] (2) RPM: 641, PWR: 0, VOLTAGE: 12.317V, TEMPERATURE: 36.55C, CURRENT: 0.568A
    [5.476] (3) RPM: 642, PWR: 0, VOLTAGE: 12.322V, TEMPERATURE: 37.07C, CURRENT: 0.640A
    Finished!
    [1701745969.875759] TX=1271, RX=435 packets, RX CRC ERRORS=50
    Average RPMs: 643.00 643.00 641.00 642.00
    Average RPM deviation between ESCs : 2.00
    False
    ^CTraceback (most recent call last):
    File "/home/will/projects/voxl-esc/voxl-esc-tools/voxl-esc-spin.py", line 370, in <module>
    fig = make_subplots(rows=5, cols=1, start_cell="top-left")
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/subplots.py", line 304, in make_subplots
    return _sub.make_subplots(
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/_subplots.py", line 879, in make_subplots
    figure = go.Figure()
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/graph_objs/_figure.py", line 629, in init
    super(Figure, self).init(data, layout, frames, skip_invalid, **kwargs)
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/basedatatypes.py", line 577, in init
    from plotly.offline.offline import _get_jconfig
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/offline/init.py", line 6, in <module>
    from .offline import (
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/offline/offline.py", line 11, in <module>
    from plotly import tools
    File "<frozen importlib._bootstrap>", line 1075, in _handle_fromlist
    File "/home/will/anaconda3/lib/python3.10/site-packages/_plotly_utils/importers.py", line 29, in getattr
    return importlib.import_module(rel_import, parent_name)
    File "/home/will/anaconda3/lib/python3.10/importlib/init.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
    File "/home/will/anaconda3/lib/python3.10/site-packages/plotly/tools.py", line 64, in <module>
    ipython_core_display = optional_imports.get_module("IPython.core.display")
    File "/home/will/anaconda3/lib/python3.10/site-packages/_plotly_utils/optional_imports.py", line 28, in get_module
    return import_module(name)
    File "/home/will/anaconda3/lib/python3.10/site-packages/IPython/init.py", line 52, in <module>
    from .core.application import Application
    File "/home/will/anaconda3/lib/python3.10/site-packages/IPython/core/application.py", line 26, in <module>
    from IPython.core import release, crashhandler
    File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
    ^C
    Thanks you.
    #12
    @Will , also can you please see if you can reproduce the issue without propellers using the following command:
    ./voxl-esc-spin.py --id 255 --power 30 --timeout 180
    (or try longer durations)
    If this does not reproduce the issue, --power 50 with propellers.. I am just trying to see if this is related to rpm control or power usage or something else..
    By the way, I noticed in your picture at the very top of this post that you have two wires soldered to the UART connector. Are you using those wires to connect to USB adapter (and also flight controller?). Please note that you should also connect GND between the ESC and the other device (USB adapter), otherwise the signal may not be grounded properly and can result in communication errors.
    Additionally.. are you able to share the exact motor and propeller part number? Maybe i can test it. Thanks!
    W 1 Reply Last reply
      W Offline
      W Offline
      Will
      wrote on last edited by Will
      #13
      @Alex-Kushleyev , here are some updates :
      I am curious if you increase the baud rate in your ESC params to 921600, whether this issue goes away.
      Yes, after increasing baud rate to 921600 or more, the plot issue goes away.
      does the same motor stop spinning ever time, or does the motor ID which fails changes from time to time?
      No, it's not the same motor that consistently stops spinning; rather, it's each motor ID that experiences a failure
      can you please inspect the motor cables (3 per motor) and make sure they are not damaged or cut, especially around / under zip ties that hold the cables to the arms (please check all the way from motors to the ESC). Also, if there are bullet connectors, make sure they are fully isolated and there is no exposed metal connector that could make contact with anything
      Upon visual inspection, no damage or cuts are apparent. However, I will have our hardware guy to conduct a more in-depth diagnosis.
      make sure that no camera flex cables are touching the ESC (sometimes camera flex cables can have exposed edge, so if it makes contact with ESC components, it can affect the performance or cause motor stall.
      Yes, we have applied tape on camera flex to prevent electronic shorts.
      No, I had previously removed those two soldered wires when I obtained a compatible connector for connecting to the USB adapter.
      I've conducted tests with two types of motors. The first is the Sunnysky x2212 (KV980), which you can find more information about here: https://sunnyskyusa.com/products/sunnysky-x2212-brushless-motors.
      The second motor is the Dongxingwei D2216 (810KV), and additional details can be found at http://www.dongxingwei.com/detail_d2216.html.
      Here is an image showing the propellers used, which are 9450 and 1045:
      No, I can't reproduce it without propellers. The following is where I use D2216 motor with 1045 propeller to reproduce the issue, thanks.
      python voxl-esc-spin.py --id 255 --power 100 --timeout 180 --enable-plot 1
      /dev/ttyUSB0
      INFO: Scanning for ESC firmware: /dev/ttyUSB0, baud: 921600
      INFO: ESC(s) detected on port: /dev/ttyUSB0, baud rate: 921600
      WARNING:
      from all persons.
      [0.000] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.000] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.000] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.011] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.011] (1) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.011] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.011] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.021] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.021] (1) RPM: 0, PWR: 0, VOLTAGE: 12.681V, TEMPERATURE: 34.95C, CURRENT: -0.008A
      [0.021] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.021] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.031] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [0.031] (1) RPM: 0, PWR: 0, VOLTAGE: 12.681V, TEMPERATURE: 34.95C, CURRENT: -0.008A
      [0.031] (2) RPM: 9, PWR: 0, VOLTAGE: 12.672V, TEMPERATURE: 34.39C, CURRENT: -0.056A
      [0.031] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
      [179.990] (0) RPM: 865, PWR: 0, VOLTAGE: 11.095V, TEMPERATURE: 46.73C, CURRENT: 0.520A
      [179.990] (1) RPM: 875, PWR: 0, VOLTAGE: 11.096V, TEMPERATURE: 45.66C, CURRENT: 0.456A
      [179.990] (2) RPM: 6658, PWR: 100, VOLTAGE: 11.094V, TEMPERATURE: 46.91C, CURRENT: 8.672A
      [179.990] (3) RPM: 6686, PWR: 100, VOLTAGE: 11.091V, TEMPERATURE: 44.31C, CURRENT: 9.088A
      Finished!
      [1701932726.226422] TX=18008, RX=18005 packets, RX CRC ERRORS=0
      Average RPMs: 733.55 721.26 6645.88 6680.47
      Average RPM deviation between ESCs : 5959.22
      False
      • W Will
        /dev/ttyUSB0
        WARNING:
        from all persons.
        Finished!
        False
        #14
        @Will thank you for providing valuable information.
        Can you please confirm (again) that after changing baud rate to higher (form 250k to 921600 or higher, you were not able to reproduce the issue even a single time? **correction, I see now that only the plot issue is solved by increasing the baud rate, but the motor issue remains, correct?
        Also, i have noticed that in your last plot, it happened twice, with offset of about 90 seconds - have you noticed this before?
        I am performing tests to try to reproduce the issue..
          @Will , i still have not been able to reproduce the issue but I may have found a very rare condition that may be happening in your case. I am going to share a firmware update soon and ask you to test it if possible. thank you
            W Offline
            W Offline
            Will
            @Alex-Kushleyev , Sure, I'll conduct testing once the updated firmware is available. By the way, where I can download the source code to build the ESC firmware?
            Here's a test plot without the propeller for your reference, no issues were identified. Thank you.
            • W Will
              @Will , the source code for the ESC firmware is not available, it is a closed-source project.
              I have made a small change that will hopefully fix your issue. The reason why I say "hopefully" is because i am not able to reproduce your exact issue, but i was able to reproduce a small glitch, which is now fixed in the test firmware. In my case the motor did not stop during the glitch, but it had a jerk. Perhaps with different test conditions, the result could be different, like in your case, when the motor would stop completely.
              The test firmware is located here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/desync-bug-fix/voxl-esc-tools/firmware/test ( you can find the correct one for your M0117-1 board). The firmware is based off V39_RC6, which is what you have been using before.
              Please try it using the same tests that you have been running and if you are not able to reproduce the issue on the bench, you should test in flight as well.
              In ether case (whether the issue is fixed or not), please let me know, as I am actively working on trying to resolve it.
              Thank you!!
                Thank you!!
                W Offline
                W Offline
                Will
                @Alex-Kushleyev , I've conducted tests on firmware version modalai_esc_firmware_m0117_1_v0_39_bugfix1_14e444b3.bin, and I didn't observe any issues with the stop spinning function. However, there seems to be an unusual burst of current at the beginning. Could you please assist in investigating this matter? Thank you :
                • Test round 1 :
                Zoom in the current plot:
                • Test round 2 :
                  python voxl-esc-spin.py --id 255 --power 100 --ramp-time 2 --timeout 180 --enable-plot 1
                • W Will
                  • Test round 1 :
                  • Test round 2 :
                  @Will , Thank you for testing the firmware update. The current spike at the beginning looks normal - this is due to motor quickly accelerating after the initial spin-up stage. The ramp time of your test is 2 seconds, but the initial spin-up time is about 1.5 seconds (it is in ESC params). The test script does not account for the spin-up time.. So, after 1.5 seconds of spin-up, the commanded power will jump to like 75% and then will have about 0.5 seconds to go to 100%, which will draw a lot of current until the final (steady-state) speed is reached. If you would like, you can set the ramp time to 5 seconds and it will be much smoother if you prefer. Does that make sense to you?
                  I am curious, how many successful 180 second tests have you done with the bugfix firmware? Also, before the firmware update, did every test result in a failure, or was it rare?
                  By the way, a small tip - if you use latest voxl-esc tools from dev branch, the plots now have the x-axis synchronized, so if you zoom in on one plot, the other plots also zoom to the same x range, so it is easier to look at the plots.
                    W Offline
                    W Offline
                    Will
                    @Alex-Kushleyev , Using 180-second tests, the x2212 motor consistently failed under full power. In contrast, the d2216 motor passed once with a 9450 propeller, but no attempt was made with a 1045 propeller. Today, I conducted a test pairing the x2212 motor with a 1045 propeller, which I consider the most challenging condition. Surprisingly, it passed twice consecutively, instilling confidence in me. I plan to proceed with the field test using this fw version, thanks for your help.
                    • W Will
                      @Will , this is great to hear! Thank you for your patience as we are resolving this issue. It does sound like you are ready for flight testing.
                      Meanwhile we will continue testing of the fix and will release an official firmware update to resolve the issue soon (probably this week). However, you don't need to wait for it, the test firmware you already have should be sufficient.
                      If you run into any other ESC-related issues, please let us know!
