  2. VOXL Dev Drones
  3. Sentinel
  4. Sentinel Drone (VOXL2) initialize error
Scheduled Pinned Locked Moved Sentinel
8 Posts 2 Posters 991 Views 1 Watching
  • I Offline
    I Offline
    inha_baek
    Hello.
    We recently conducted tests on your SENTINEL drones and encountered some issues with one of the units. The issues are as follows.
    • When the main power source (Platform Battery) connected with the drone, only the VOXL2 modules light turned on, but other devicess led lights remained inactive.
    • We tried to connect the VOXL2s system with a USB C-type connector, theres no linking from the VOXL2 module.
    • We followed your provided instructions, attempting to connect it to an UBUNTU PC and using the terminal command "adb devices", but no detection for VOXL2 was registered.
    We kindly request your prompt assistance in resolving this issue. Your immediate attention to this matter would be greatly appreciated.
    Thanks.
    • I inha_baek
      Hello.
      Thanks.
      @inha_baek What do you see with lsusb on your Ubuntu machine with the USB connected + sentinel powered?
      I 1 Reply Last reply
        I Offline
        I Offline
        inha_baek
        Here is Ubuntu machine`s screenshot. Left one is normal (one of the units that successfully finished initial setting), and a right one is abnormal.
        • I inha_baek
          @inha_baek It appears as thought the voxl2 has entered in to "QDL mode" which means that you will have to follow the unbricking process in order to bring it back to a working state:
          https://docs.modalai.com/voxl2-unbricking/#unbricking-your-voxl-2
            I Offline
            I Offline
            inha_baek
            Thanks for reply.
            With your recommendation, we followed that guide (https://docs.modalai.com/voxl2-unbricking/#unbricking-your-voxl-2).
            But in Initiate Flash step, we saw this lines in host pc`s terminal.
            Please check this.
            • I inha_baek
              Thanks for reply.
              Please check this.
              @inha_baek Do you have the SW2 switch flipped and did you use sudo?
              Sometime it takes a power cycle and retry to get it going.
                I Offline
                I Offline
                inha_baek
                Of course we did with SW switch flipped and 'sudo'.
                Also we retried a lot of times.
                And we got same result in every tries.
                • I inha_baek
                  @inha_baek If QDL still isn't working I would look into an RMA: https://www.modalai.com/pages/rma
