  3. No Odometry in QGC through MAVLink
7 Posts 2 Posters 1.5k Views
  • S Offline
    S Offline
    SMRazaRizvi
    wrote on last edited by SMRazaRizvi
    Problem: My Sentinel drone with VOXL SDK 1.0, drifts when I take off. It drifts a lot when I take off in Manual mode, and when I take off in Position mode, it drifts with a blow of wind.
    One of the problems I noticed is that I cannot see Odometry messages inside the MAVLink Inspector, and the frequency of LOCAL_POSITION_NED is also 1.0 Hz.
    How can I enable Odometry and also increase the frequency of LOCAL_POSITION_NED ?
    S 1 Reply Last reply
    • S SMRazaRizvi
      S Offline
      S Offline
      SMRazaRizvi
      @SMRazaRizvi @Moderator ?
      • S SMRazaRizvi
        Jetson NanoJ Offline
        Jetson Nano
        Veteran
        @SMRazaRizvi Make sure your vio is running, and there are certain parameters that needs to be enabled in QGC for it to hold position, check whether you have done it
        • Jetson NanoJ Jetson Nano
          S Offline
          S Offline
          SMRazaRizvi
          @Jetson-Nano Can you please mention those parameters here, and their correct values?
          • S SMRazaRizvi
            Jetson Nano
            Veteran
            @SMRazaRizvi Sorry for the delayed response
            for PX4 version 1.14 the paramters are https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/EKF2_helpers/indoor_vio.params
            for PX4 version 1.12 the paramters are https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.12/ekf2_indoor_vio.params
              S Offline
              S Offline
              SMRazaRizvi
              @Jetson-Nano
              Thank you for your response.
              But these are the parameters for indoor, I am testing outdoors.
              I tried
              Link Preview Image
              params/v1.14/EKF2_helpers/outdoor_gps_baro.params · master · voxl / VOXL SDK / Utilities / voxl-px4-params · GitLab
              PX4 parameter files for use on VOXL2 and Flight Core
              favicon
              GitLab (gitlab.com)
              Link Preview Image
              params/v1.14/platforms/Sentinel_V1.params · master · voxl / VOXL SDK / Utilities / voxl-px4-params · GitLab
              favicon
              GitLab (gitlab.com)
              But still same issue.
              • S SMRazaRizvi
                @Jetson-Nano
                I tried
                Link Preview Image
                favicon
                GitLab (gitlab.com)
                Link Preview Image
                favicon
                GitLab (gitlab.com)
                Jetson Nano
                Veteran
                @SMRazaRizvi You have to setup GPS and make EKF Aid mask use GPS, and I don't think using GPS will give you odometry data, you might get some sort of global position which helps you hold position and navigate
