  2. VOXL SDK and Software
  3. adb is not working, (No ADB device detected)
12 Posts 3 Posters 3.8k Views 3 Watching
  • A Offline
    Alex123
    wrote on last edited by Alex123
    I've done all the connections as mentioned on the website.
    But as I'm connecting the VOXL core board to HOST-PC(Ubuntu) using USB it's not showing any ADB device.
    It was detected previously, but now it isn't showing any device.
    Any help or direction on what to check next is greatly appreciated.
    Thank you..
      Hi Alex,
      It doesn't look like the PCB is placed on an ESD sensitive surface? It is an exposed PCB so you still need to be careful with exposure to ESD
      It's most likely the flash was corrupted in some way. Can you please try the Unbrick procedure found here? https://docs.modalai.com/unbrick-voxl/
      A 1 Reply Last reply
      • Chad SweetC Chad Sweet
        Hi Alex,
        Alex123
        @Chad-Sweet Yes, I'm taking care about ESD sensitive surface.
        I've tried unbrick procedure but it's not showing any ADB device on my screen.
        Thanks.
        • modaltbM Offline
          modaltbM Offline
          modaltb
          Hi @Alex123 ,
          A few more items to try.
          • When you apply power, does the LED quickly flash green? The LED is called out here
          • What are you using to plug into the power module? I see in the picture above you have the power module but can't see what type of power supply you are using. The VOXL has a hefty inrush current, I've seen sometimes when using an incorrectly spec'd supply that there can be intermittent ADB connections
          • Have you tried a different USB cable and port (I'm sure you have, but have to ask 😉 )
          • modaltbM modaltb
            Hi @Alex123 ,
            Alex123
            @modaltb
            I've tried the items you are listed.
            • The LED is blinking when I'm applying the power(flash green).
            • I'm using the standard power adapter which I've received with the complete VOXL kit. (5V 4A)
            • And of course, I've tried with different USB cables as well.
            After all, it's not showing any ADB device on my screen.
            • modaltbM Offline
              modaltbM Offline
              modaltb
              Hi @Alex123 ,
              Sorry for the repetitive questions, but we're trying to eliminate problems we've seen due to wrong power supplies and ADB.
              Our standard power 5V supply is rated for 6A (as a 4A power supply may not support inrush currents of the VOXL) and can lead to problems like this....
              Can you please verify if you are using the standard power supply?
              https://www.modalai.com/products/voxl-acc-ps?variant=32029899849779
              Here's the real datasheet:
              https://www.digikey.com/product-detail/en/globtek-inc/WR9QA6000LCP-N-R6B/1939-1845-ND/9837910
              A 3 Replies Last reply
              • modaltbM modaltb
                Hi @Alex123 ,
                Alex123
                @modaltb
                I'm sorry, it was by mistake. I'm using 5V, 6A power supply.
                • modaltbM modaltb
                  Hi @Alex123 ,
                  Alex123
                  @modaltb
                  If it happens (5V, 4A), is there any possibility of hardware damage?
                  Can I overcome this problem by giving the correct power supply?
                  • modaltbM modaltb
                    Hi @Alex123 ,
                    Alex123
                    @modaltb
                    I've connected the current meter in series to check the current at 24V.
                    I've used Power Module v3 to power-up the board.
                    I've observed the following current rating at 24 volts. (see the image)
                    Is that much of current consumption at 24V ok?
                    • modaltbM Offline
                      modaltbM Offline
                      modaltb
                      Hi @Alex123 ,
                      46mA is a bit low... OK so now that we've sorted out the power supply, I believe we'll ask to have this one sent in and we can evaluate it unfortunately.
                      I've just email you an RMA request form to the email associated to this forum account, if you could fill this out we'll start the process.
                      • modaltbM modaltb
                        Hi @Alex123 ,
                        Alex123
                        #11
                        @modaltb
                        Ok.
                        • modaltbM Offline
                          modaltbM Offline
                          modaltb
                          @Alex123 I just realized right now when I was powering up my m500 that I said to use 24VDC in an email.... this is OK for that power module, but the max is 25.2VDC, so no problem dropping it to say 16VDC! 😉
