  3. Communication through J18
23 Posts 5 Posters 6.6k Views 2 Watching
    @Filip-Slezak-0 Oh, sorry, got confused by your VOXL2 mini question. That m0078 board only gives you USB, not a UART. And that other link goes to some PWM breakout board for flight core. Not sure how that one fits in with VOXL2 at all.
    Filip Slezak 0F Offline
    Filip Slezak 0
    @Eric-Katzfey No worries, and yes that's it. How would you recommend I communicate with that external Teensy board? Can't seem to find easily accessible pins for that.
    • Filip Slezak 0F Filip Slezak 0
      @Filip-Slezak-0 I would go with that expansion board I pointed out and use UART.
      Filip Slezak 0F 1 Reply Last reply
        Filip Slezak 0
        @Eric-Katzfey Sorry for the late reply. Unfortunately, I don't see how that could work for us, we already have the m0078 on there and the J2 goes to the wifi dongle, what am I missing in what you're suggesting?
          @Filip-Slezak-0 The board I am suggesting has USB and UART.
            Filip Slezak 0
            @Eric-Katzfey So you're thinking switch out the boards, use the UART for the wifi dongle and communicate over USB with the microcontroller?
              @Filip-Slezak-0 No, keep using USB for the WiFi dongle and use the UART to communicate with the Teensy.
                Filip Slezak 0
                @Eric-Katzfey Got it, this is getting clearer. Is it safe to use the Teensy's 3.3V pins? According to this, the Voxl2 comm pins are at 1.8V even though its GPIOs are at 3.3V https://docs.modalai.com/voxl2-linux-user-guide/#devttyhs1---b2b-connector-uart
                  @Filip-Slezak-0 Yes, should be fine. We use that UART to connect with our external flight core boards that have 3.3V rx / tx.
                    Filip Slezak 0
                    @Eric-Katzfey Thanks Eric, got it working easily after that using a classic pyserial script. Great help!
                    • Filip Slezak 0F Offline
                      Filip Slezak 0
                      @Eric-Katzfey Hi again, can we expose another UART port for programming on the Voxl2?
                        Filip Slezak 0
                        @Filip-Slezak-0 Thinking about ttyHS2 or ttyHS3 maybe shown here https://docs.modalai.com/voxl2-linux-user-guide/#uarts
                        modaltbM 1 Reply Last reply
                          modaltbM Offline
                          modaltbM Offline
                          modaltb
                          @Filip-Slezak-0 please see here: https://docs.modalai.com/voxl2-linux-user-guide/#apps-proc, we have ttySH2/ttyHS3 routed to the B2B connectors, but you need a carrier board to pick them up...
                          For example, ttyHS2 goes to our M0090 - 5G Add-On Board J9 Pins 2/3 (Tx/Rx)
                          • modaltbM modaltb
                            Filip Slezak 0
                            @modaltb Hey, thanks for the quick reply. Unfortunately, none of these work for us since it seems exposing one port prevents us from accessing another (I also can't find a ref to buy the M0130).
                            We found a workaround by having a USB hub on the m0125 instead of going over the native uart.
