    Support for Ubuntu 22.04
    • P
      Praveen
      It appears that voxl-cross is currently built on version Ubuntu 18.04, which has reached its end-of-life (EOL). I'm interested in knowing if there are any updated images available that are based on newer LTS versions. Thank you.
        Eric Katzfey ModalAI Team @Praveen
        @Praveen Can you please explain why you need that? Is the current voxl-cross creating some problems for you?
        P 1 Reply Last reply Reply Quote 0
        • P
          Praveen @Eric Katzfey
          Currently, there are no immediate issues, except for the acceptability metric. Given the toolchain is only available as a docker image, which is impacted by the recent End of Life status of Ubuntu 18.04.
          During my attempt to create the docker image using the provided recipe, I faced challenges due to the unavailability of certain proprietary binaries on the downloads page. For example, the required installation package, qrb5165-proprietary_0.0.4_arm64.deb, is not accessible. Instead, only an older version, qrb5165-proprietary_0.0.2_arm64.deb, is available.
          If you have any suggestions or solutions, I would greatly appreciate your input. Thank you.
            @Praveen We provide the docker image so that you do not have to build it. It is just a tool that is needed to build some of our software packages. As long as it is doing that then there is no need to update it.
