    Errors on build processing for voxl-vision-px4
    FAQs
    1467
    • S
      shlee853
      I got clone voxl-vision-px4 form git repository and switch to 0.6.8 commit version.
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ git clone https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-vision-px4.git
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git$ cd voxl-vision-px4/
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git submodule update --init --recursive
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git log
      commit eb4f400227a0c1b23e604cf76f4e22714f43f87f (HEAD -> master, origin/master, origin/HEAD)
      Author: Cliff Wong <cliff.wong@modalai.com>
      Date:   Wed May 12 23:53:18 2021 +0000
      Update README.md --ipk command name change
      commit 95234d71677faee8c95242921e285cfe93d9ce7f (tag: v0.8.1)
      Merge: b485c79 216badd
      Author: james <james@modalai.com>
      Date:   Tue Mar 2 13:53:35 2021 -0800
        Merge branch 'dev'
      commit 7b9f76c468045a023b35747deeef52e4f524b7de (tag: v0.6.8)
      Date:   Wed Oct 7 13:00:34 2020 -0700
          detect and warn when PX4 disconnects from uart
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ git reset --hard 7b9f76c468045a023b35747deeef52e4f524b7de
      HEAD is now at 7b9f76c detect and warn when PX4 disconnects from uart
      I tried to build source code but, there's some errors without any modification.
      Q1) I gave a command with 'stable' but, installer refered to 'dev'. is this correct?
      Q2) In the process, installation was don even though there're some errors. is it ok?
      swift@swift-HP-Pavilion-dv6-Notebook-PC:~/git/voxl-vision-px4$ voxl-docker -i voxl-emulator
      bash-4.3# ./install_build_deps.sh stable
      using development repository
      Downloading http://voxl-packages.modalai.com/dev/Packages.gz.
      **Updated source 'dev'**.
      No packages removed.
      qemu: Unsupported syscall: 219
      Installing libvoxl_io (0.5.4) on root.
      Downloading http://voxl-packages.modalai.com/dev/libvoxl_io_0.5.4_202105201932.ipk.
      Configuring libvoxl_io.
      Done installing libvoxl_io
      Installing modalai-vl (0.1.4) on root.
      Downloading http://voxl-packages.modalai.com/dev/modalai-vl_0.1.4_8x96.ipk.
      Configuring modalai-vl.
      /usr/lib/rfsa/adsp/port_mapping.xml does not exist, creating symlink
      /usr/lib/rfsa/adsp/eagle.xml does not exist, creating symlink
      /usr/lib/rfsa/adsp/imu_offset.xml does not exist, creating symlink
      /usr/lib/rfsa/adsp/fiducial_markers.xml does not exist, creating symlink
      /bin/chmod: cannot access '/dev/adsprpc-smd': No such file or directory
      Collected errors:
       * pkg_run_script: package "modalai-vl" postinst script returned status 1.
       * opkg_configure: modalai-vl.postinst returned 1.
      Installing imu_app (0.0.6) on root.
      Downloading http://voxl-packages.modalai.com/dev/imu_app_0.0.6.ipk.
      /usr/lib/rfsa/adsp/port_mapping.xml exists but is not a valid symlink, overwriting
      /usr/lib/rfsa/adsp/eagle.xml exists but is not a valid symlink, overwriting
      /usr/lib/rfsa/adsp/imu_offset.xml exists but is not a valid symlink, overwriting
      /usr/lib/rfsa/adsp/fiducial_markers.xml exists and is a valid symlink
      Configuring imu_app.
      Done installing imu_app
      Collected errors:
      the following packages were installed
      libvoxl_io - 0.5.4 - ModalAI library allowing apps processor access to accessory serial ports
      librc_math - 1.1.5 - Math and Linear Algebra Routines for Robotics
      libmodal_pipe - 2.0.6 - Interface for services to communicate over posix named pipes
      modalai-vl - 0.1.4 - ModalAI Vision Library
      imu_app - 0.0.6 - imu server
      Done installing dependencies
      Q3) threre're some errors on build without any modification. Could you please check it?
      bash-4.3# ./build.sh
      -- Configuring done
      -- Generating done
      -- Build files have been written to: /home/root/build
      [  9%] Built target voxl-px4-shell
      [ 14%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_monitor.c.o
      [ 19%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o
      [ 23%] Building C object src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o
      [ 28%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_follow_tag.c.o
      In file included from /home/root/src/fixed_frame_pipe.c:35:0:
      /home/root/src/../include/voxl_vision_px4.h:62:16: error: redefinition of 'struct pose_4dof_t'
       typedef struct pose_4dof_t{
      In file included from /usr/include/modal_pipe_deprecated.h:42:0,
                       from /usr/include/modal_pipe_sink.h:42,
                       from /home/root/src/fixed_frame_pipe.c:34:
      /usr/include/modal_pipe_interfaces.h:523:16: note: originally defined here
      /home/root/src/../include/voxl_vision_px4.h:66:3: error: conflicting types for 'pose_4dof_t'
       } pose_4dof_t;
      /usr/include/modal_pipe_interfaces.h:528:27: note: previous declaration of 'pose_4dof_t' was here
       } __attribute__((packed)) pose_4dof_t;
      In file included from /home/root/src/px4_shell.c:36:0:
                       from /home/root/src/px4_shell.c:35:
       } pose_4dof_t;
      /home/root/src/fixed_frame_pipe.c: In function 'fixed_frame_pipe_init':
      /home/root/src/fixed_frame_pipe.c:63:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
      Please use pipe_sink_create() instead [-Wdeprecated-declarations]
        if(pipe_sink_init_channel(FIXED_FRAME_SINK_CH, FIXED_FRAME_PIPE_PATH, 1, READ_BUF_SIZE)){
      /home/root/src/fixed_frame_pipe.c:66:2: warning: implicit declaration of function 'pipe_sink_set_data_cb' [-Wimplicit-function-declaration]
        pipe_sink_set_data_cb(FIXED_FRAME_SINK_CH, data_cb);
      /home/root/src/fixed_frame_pipe.c: In function 'fixed_frame_pipe_stop':
      /home/root/src/fixed_frame_pipe.c:72:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
      Please use pipe_sink_close() instead [-Wdeprecated-declarations]
        pipe_sink_close_channel(FIXED_FRAME_SINK_CH);
      src/CMakeFiles/voxl-vision-px4.dir/build.make:182: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o' failed
      make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o] Error 1
      make[2]: *** Waiting for unfinished jobs....
      /home/root/src/px4_shell.c: In function 'px4_shell_init':
      /home/root/src/px4_shell.c:89:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
        if(pipe_sink_init_channel(TO_PX4_SHELL_CH, TO_PX4_SHELL_PATH, 1, READ_BUF_SIZE)){
      /home/root/src/px4_shell.c:92:2: warning: implicit declaration of function 'pipe_sink_set_data_cb' [-Wimplicit-function-declaration]
        pipe_sink_set_data_cb(TO_PX4_SHELL_CH, data_cb);
      /home/root/src/px4_shell.c:94:2: warning: 'pipe_sink_init_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:735):
        if(pipe_sink_init_channel(FROM_PX4_SHELL_CH, FROM_PX4_SHELL_PATH, 0, 0)){
      /home/root/src/px4_shell.c: In function 'px4_shell_stop':
      /home/root/src/px4_shell.c:106:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
        pipe_sink_close_channel(TO_PX4_SHELL_CH);
      /home/root/src/px4_shell.c:107:2: warning: 'pipe_sink_close_channel' is deprecated (declared at /usr/include    /modal_pipe_deprecated.h:749):
        pipe_sink_close_channel(FROM_PX4_SHELL_CH);
      src/CMakeFiles/voxl-vision-px4.dir/build.make:326: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o' failed
      make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o] Error 1
      CMakeFiles/Makefile2:85: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/all' failed
      make[1]: *** [src/CMakeFiles/voxl-vision-px4.dir/all] Error 2
      Makefile:127: recipe for target 'all' failed
      make: *** [all] Error 2
      • Chad SweetC
        Chad Sweet ModalAI Team
        The dependencies will likely need to line up with that version of voxl-vision-px4. voxl-suite contains all of the different packages. So installing a specific version of voxl-suite that matches voxl-vision-px4 should help.
        To switch to stable channel:
        yocto:/# vi /etc/opkg/opkg.conf
        uncomment the stable branch, and comment out the dev branch at the bottom of this file.
        yocto:/# opkg update
        • S
          shlee853
          Hi chad,
          opkg.conf is already uncommented with stable option.
          I think there's no stable option on version 06.8.
          But, I copied latest install_build_deps.sh and excuted with stable option. I compiled all correctly with errors.
          but, there're still errors on build process.
          -- Configuring done
          -- Generating done
          [ 14%] Building C object src/CMakeFiles/voxl-vision-px4.dir/transform_ringbuf.c.o
          [ 19%] Building C object src/CMakeFiles/voxl-vision-px4.dir/adsb_uart.c.o
          [ 23%] Building C object src/CMakeFiles/voxl-vision-px4.dir/main.c.o
          [ 28%] Building C object src/CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o
          /home/root/src/main.c:44:24: fatal error: modalai_vl.h: No such file or directory
           #include <modalai_vl.h>
          compilation terminated.
          src/CMakeFiles/voxl-vision-px4.dir/build.make:86: recipe for target 'src/CMakeFiles/voxl-vision-px4.dir/main.c.o' failed
          make[2]: *** [src/CMakeFiles/voxl-vision-px4.dir/main.c.o] Error 1
          bash-4.3#
          There's no file 'modalai_vl.h.' what is this for? I cannot find this file.
          • Chad SweetC
            Looks like you are missing this package
            http://voxl-packages.modalai.com/stable/modalai-vl_0.1.3.ipk
            • S
              shlee853 @Chad Sweet
              @Chad-Sweet I installed this package manually
              opkg install moal...ipk
              But, still has error on installing
              Can you provide version 0.6.8 that can build completely?
              Or please try to compile and verify it?
              • Chad SweetC
                Do you need to build it, or can you just install voxl-suite 0.2.0 to get the features you are looking for?
                • Chad SweetC
                  This script should show you how to install a specific version of voxl-suite https://gitlab.com/voxl-public/utilities/voxl-suite/-/blob/master/tools/online-install.sh
                  • S
                    @Chad-Sweet I wanna chage voxl-vision-px4 source code in 0.6.8 and build by myself.
                    • Chad SweetC
                      The I would install voxl-suite 0.2.0 and then build against that. All of the proper dependencies should be there
                      • S
                        @Chad-Sweet said in Errors on build processing for voxl-vision-px4:
                        against
                        OK I'll check it
                        Thanks for your fast reply.
