  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. VOXL2 SDK 1.0.0-beta6 voxl-px4 couldn't arm UAV (GPS LED always RED blinking)
33 Posts 2 Posters 5.8k Views 1 Watching
  • A Offline
    Aaky
    I am testing voxl-px4 over VOXL2 SDK 1.0.0-beta6 with voxl-px4 version 1.14.0-2.0.34. I have connected Holybro GPS for VOXL2 on J19 and also followed instructions to enable. Also I have configured EKF2 in outdoor GPS configuration but I am still unable to arm. Here are problems which I am facing.
    • GPS LED is constantly blinking red which as per PX4 LED meaning means CPU load is > 80 % or RAM > 95%. I have also caliberated IMU,Compass but still this error dosen't go away.
    • I am unable to ARM the drone and QGC always say's "MAV_CMD_COMPONENT_ARM_DISARM command temperorily rejected". This is happening because QGC is not turning green with "Ready to fly" status even in manual mode.
    Please help me resole this problem. Also find logs of PX4 service while this issue is occuring.
    @Eric-Katzfey @tom Please help on this problem.
    voxl2:/home$ voxl-px4 -b
    [INFO] /etc/modalai/voxl-px4.conf not found, using defaults
    Found DSP signature file
    [INFO] Holybro GPS selected
    GPS=HOLYBRO
    RC=SPEKTRUM
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    EXTRA STEPS:
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    GPS: HOLYBRO
    RC: SPEKTRUM
    OSD: DISABLE
    EXTRA STEPS:
    Running on M0054
    INFO  [parameters] BSON document size 2220 bytes, decoded 2220 bytes (INT32:39, FLOAT:63)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: >>> ICM42688P this: 3176c0b0
    INFO  [qshell] qshell return value timestamp: 798752959, local time: 798756880
    INFO  [muorb] SLPI: Register interrupt b21d3164 e620e71c 3176c0b0
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 799808828, local time: 799811536
    Starting Holybro magnetometer
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 799866569, local time: 799870467
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
    INFO  [qshell] qshell return value timestamp: 799920368, local time: 799921761
    Starting Holybro LED driver
    INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0x38
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 799983414, local time: 799985455
    INFO  [muorb] SLPI: qshell gotten: modal_io start
    INFO  [muorb] SLPI:   arg0 = 'modal_io'
    INFO  [qshell] Send cmd: 'modal_io start'
    INFO  [muorb] SLPI: Ok executing command: modal_io start
    INFO  [muorb] SLPI: Opened UART ESC device
    INFO  [qshell] qshell return value timestamp: 800106560, local time: 800109710
    INFO  [uORB] Advertising remote topic esc_status
    Starting Spektrum RC
    INFO  [qshell] Send cmd: 'spektrum_rc start'
    INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
    INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
    INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
    INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
    INFO  [qshell] qshell return value timestamp: 801167468, local time: 801171213
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    INFO  [muorb] SLPI:   arg4 = '2'
    INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    INFO  [muorb] SLPI: Set i2c address 0x6a, fd 3
    INFO  [muorb] SLPI: Set i2c address 0x44, fd 3
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    INFO  [muorb] SLPI:  address 0x44
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [uORB] Advertising remote topic power_monitor
    INFO  [qshell] qshell return value timestamp: 802235350, local time: 802238457
    ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_MAG_MODE
    INFO  [uORB] Advertising remote topic sensors_status_mag
    INFO  [qshell] qshell return value timestamp: 802480300, local time: 802484086
    INFO  [qshell] qshell return value timestamp: 802811996, local time: 802817305
    INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO  [qshell] qshell return value timestamp: 802952043, local time: 802955388
    INFO  [qshell] qshell return value timestamp: 803028679, local time: 803030562
    INFO  [qshell] qshell return value timestamp: 803167767, local time: 803169977
    INFO  [qshell] qshell return value timestamp: 803246587, local time: 803250035
    INFO  [qshell] qshell return value timestamp: 803313189, local time: 803315350
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI:   arg2 = 'multicopter'
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [qshell] qshell return value timestamp: 803386434, local time: 803390743
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [qshell] qshell return value timestamp: 803465069, local time: 803467188
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 803852335, local time: 803854764
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 804260177, local time: 804262967
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] SLPI: qshell gotten: commander start
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097641
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: Ok executing command: commander start
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [qshell] qshell return value timestamp: 804561255, local time: 804563422
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic mavlink_log
    INFO  [muorb] SLPI: Preflight Fail: No connection to the ground control station
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [qshell] Send cmd: 'commander mode manual'
    INFO  [muorb] SLPI: qshell gotten: commander mode manual
    INFO  [muorb] SLPI:   arg1 = 'mode'
    INFO  [muorb] SLPI:   arg2 = 'manual'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: commander mode manual
    INFO  [uORB] Advertising remote topic vehicle_command_ack
    INFO  [qshell] qshell return value timestamp: 804627695, local time: 804634365
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [qshell] Send cmd: 'param_set_selector start'
    INFO  [muorb] SLPI: qshell gotten: param_set_selector start
    INFO  [muorb] SLPI:   arg0 = 'param_set_selector'
    INFO  [muorb] SLPI: Ok executing command: param_set_selector start
    INFO  [qshell] qshell return value timestamp: 804695137, local time: 804697170
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 804888186, local time: 804890908
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh> INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
    INFO  [muorb] SLPI: u-blox protocol version: 18.00
    INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
    INFO  [muorb] SLPI: Advertising remote topic ping
    INFO  [uORB] Advertising remote topic sensor_gps
    INFO  [uORB] Advertising remote topic estimator_gps_status
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_gnss_vel
    INFO  [muorb] SLPI: Preflight: GPS Horizontal Pos Error too high
    INFO  [uORB] Advertising remote topic home_position
    INFO  [muorb] SLPI: Advertising remote topic mission_result
    • A Aaky
      GPS=HOLYBRO
      RC=SPEKTRUM
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: HOLYBRO
      RC: SPEKTRUM
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      @Aaky Your parameters must not be set correctly. You can find our parameter sets here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params. One of the parameters controls the CPU monitoring and our parameter set disables that check here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/Sentinel_V1.params#L17
      • A Aaky
        GPS=HOLYBRO
        RC=SPEKTRUM
        OSD=DISABLE
        DAEMON_MODE=DISABLE
        SENSOR_CAL=ACTUAL
        EXTRA STEPS:
        ______  __   __    ___
        | ___ \ \ \ / /   /   |
        | |_/ /  \ V /   / /| |
        |  __/   /   \  / /_| |
        | |     / /^\ \ \___  |
        \_|     \/   \/     |_/
        px4 starting.
        GPS: HOLYBRO
        RC: SPEKTRUM
        OSD: DISABLE
        EXTRA STEPS:
        Running on M0054
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        INFO  [muorb] SLPI:
        @Aaky said in VOXL2 SDK 1.0.0-beta6 voxl-px4 couldn't arm UAV (GPS LED always RED blinking):
        This is the error that is preventing arming.
        A 1 Reply Last reply
          Aaky
          wrote on last edited by Aaky
          @Eric-Katzfey Thank you for the quick response. I am aware of those default parameters. Will again give it a try.
          What is the reason behind GPS LED continuously blinking RED? That wasn't happening even if I was in indoor with GPS on older version PX4 1.12.31.
          Also in manual mode GPS Horizontal pos error preflight check shouldn't matter right? I am trying to arm in manual mode only and not in position mode.
          A Eric KatzfeyE 3 Replies Last reply
          • A Aaky
            Aaky
            @Eric-Katzfey I tried to set parameters from above-mentioned link with ekf2_helpers for GPS outdoor with baro but with no luck, still GPS led continues to blink red.
            I also tried deleting default parameter file at /data/px4/parm/parameter and again restarting PX4 service still with no luck.
            I also tried flashing sentinel V1/V2 parameters but again with no luck.
            I can see 12 satellites with good enough HDOP and VDOP but still GPS led blinks red and never let's me arm the drone.
            I can sense some initialisation is not correct which is causing this. I have freshly installed system image with no changes on PX4 firmware side.
            Please help me further on this issue.
            • A Aaky
              @Aaky Do you still see it fail with GPS Horizontal Pos Error too high?
              • A Aaky
                @Aaky Yes, you should be able to arm in manual mode without good GPS.
                • A Aaky
                  @Aaky Can you show us the current output messages of px4 like in your first post?
                  • A Aaky
                    @Aaky What happens if you set the parameter SYS_HAS_GPS to 0?
                    • A Aaky
                      @Aaky What if you set COM_ARM_WO_GPS to 1?
                        Aaky
                        @Eric-Katzfey Yes I still see it fail.
                        SYS_HAS_GPS setting to 0 has no effect.
                        COM_ARM_WO_GPS has no effect.
                        I will share the logs in this situation soon.
                        My main concern is why GPS LED is not going into blue blink even if it dosent have GPS lock in indoor just like it used to go in 1.12.31 PX4 version?
                        • A Aaky
                          @Aaky It flashes red when a preflight check is failing. It doesn't necessarily have anything to do with GPS.
                            Aaky
                            @Eric-Katzfey Okay but On QGC No such preflight check failure notification is coming up which can help solve this problem. I am using QGC v4.2.4 but I have also tried with v3.5.6.
                            • A Aaky
                              @Aaky That is why you need to share the output from voxl-px4. It should print out an indication of which preflight check failed.
                                Aaky
                                @Eric-Katzfey Please find attached logs of voxl-px4 service.
                                Below log is without daemon mode and with Holybro GPS
                                voxl2:/etc/systemd/system$ voxl-px4 -b
                                GPS=HOLYBRO
                                RC=SPEKTRUM
                                OSD=DISABLE
                                DAEMON_MODE=DISABLE
                                SENSOR_CAL=ACTUAL
                                EXTRA STEPS:
                                ______  __   __    ___
                                | ___ \ \ \ / /   /   |
                                | |_/ /  \ V /   / /| |
                                |  __/   /   \  / /_| |
                                | |     / /^\ \ \___  |
                                \_|     \/   \/     |_/
                                px4 starting.
                                GPS: HOLYBRO
                                RC: SPEKTRUM
                                OSD: DISABLE
                                EXTRA STEPS:
                                Running on M0054
                                INFO  [parameters] BSON document size 2081 bytes, decoded 2081 bytes (INT32:30, FLOAT:64)
                                INFO  [muorb] SLPI:
                                INFO  [muorb] SLPI: >>> ICM42688P this: 3176c0c0
                                INFO  [qshell] qshell return value timestamp: 1444994972, local time: 1444999175
                                INFO  [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176c0c0
                                INFO  [muorb] SLPI:
                                INFO  [qshell] qshell return value timestamp: 1446063254, local time: 1446065261
                                INFO  [muorb] SLPI:
                                INFO  [qshell] qshell return value timestamp: 1446122603, local time: 1446124645
                                INFO  [qshell] qshell return value timestamp: 1446176501, local time: 1446178234
                                INFO  [muorb] SLPI:
                                INFO  [qshell] qshell return value timestamp: 1446211242, local time: 1446214237
                                INFO  [qshell] qshell return value timestamp: 1446338696, local time: 1446341515
                                INFO  [qshell] qshell return value timestamp: 1447405538, local time: 1447407699
                                INFO  [muorb] SLPI:
                                INFO  [qshell] qshell return value timestamp: 1448475700, local time: 1448478307
                                INFO  [qshell] qshell return value timestamp: 1448704886, local time: 1448712168
                                INFO  [qshell] qshell return value timestamp: 1449031475, local time: 1449039018
                                INFO  [qshell] qshell return value timestamp: 1449174525, local time: 1449176355
                                INFO  [qshell] qshell return value timestamp: 1449244387, local time: 1449246464
                                INFO  [qshell] qshell return value timestamp: 1449391261, local time: 1449394034
                                INFO  [qshell] qshell return value timestamp: 1449469671, local time: 1449473908
                                INFO  [qshell] qshell return value timestamp: 1449531494, local time: 1449532797
                                INFO  [qshell] qshell return value timestamp: 1449602580, local time: 1449606580
                                INFO  [qshell] qshell return value timestamp: 1449685436, local time: 1449688087
                                INFO  [qshell] qshell return value timestamp: 1450104510, local time: 1450108431
                                INFO  [qshell] qshell return value timestamp: 1450511359, local time: 1450513507
                                INFO  [qshell] qshell return value timestamp: 1450817059, local time: 1450818888
                                INFO  [qshell] qshell return value timestamp: 1450866530, local time: 1450874528
                                INFO  [qshell] qshell return value timestamp: 1450932625, local time: 1450933962
                                INFO  [qshell] qshell return value timestamp: 1451123263, local time: 1451126349
                                pxh> INFO  [muorb] SLPI: Advertising remote topic ping
                                WARN  [uORB] orb_advertise_multi: failed to set queue size
                                INFO  [uORB] Advertising remote topic actuator_test
                                INFO  [uORB] Advertising remote topic trajectory_setpoint
                                INFO  [uORB] Advertising remote topic vehicle_constraints
                                INFO  [uORB] Advertising remote topic landing_gear
                                INFO  [uORB] Advertising remote topic actuator_controls_status_0
                                INFO  [muorb] SLPI: Connection to ground station lost
                                INFO  [muorb] SLPI: GCS connection regained
                                One quick question, Is daemon mode enabling necessary on 1.14? What does daemon mode mean? Even with daemon enabled I face same problem.
                                I can see warning "WARN [uORB] orb_advertise_multi: failed to set queue size" coming up when first time I try to arm the UAV. Can this be problem?
                                Please help further what preflight check is failing as per above log. I am still unable to arm the UAV in manual mode and GPS LED is also always blinking red.
                                • A Aaky
                                  GPS=HOLYBRO
                                  RC=SPEKTRUM
                                  OSD=DISABLE
                                  DAEMON_MODE=DISABLE
                                  SENSOR_CAL=ACTUAL
                                  EXTRA STEPS:
                                  ______  __   __    ___
                                  | ___ \ \ \ / /   /   |
                                  | |_/ /  \ V /   / /| |
                                  |  __/   /   \  / /_| |
                                  | |     / /^\ \ \___  |
                                  \_|     \/   \/     |_/
                                  px4 starting.
                                  GPS: HOLYBRO
                                  RC: SPEKTRUM
                                  OSD: DISABLE
                                  EXTRA STEPS:
                                  Running on M0054
                                  INFO  [muorb] SLPI:
                                  INFO  [muorb] SLPI:
                                  INFO  [muorb] SLPI:
                                  INFO  [muorb] SLPI:
                                  INFO  [muorb] SLPI:
                                  @Aaky Daemon mode means it is running as a background system process. And that orb_advertise_multi warning can be safely ignored. Did you try to arm and get a failure in that log?
                                    Aaky
                                    @Eric-Katzfey Yes I tried to arm and got failure. What can be the reason as per the logs?
                                    • A Aaky
                                      @Aaky There isn't really anything in the log declaring a preflight failure. If you keep trying to arm do you get anything in the log? What does QGC tell you if you try to arm?
                                        Aaky
                                        #19
                                        @Eric-Katzfey QGC says, " MAV_CMD_COMPONENT_ARM_DISARM temperorily rejected".
                                        This happens in manual mode and GPS LED blinks red, even after I have completed calibration of Mag, Accel and gyro.
                                        Also whenever I ARM, I do not get anything on voxl-px4 logs.
                                        Should I send over my parameter file? Can that help?
                                        • A Aaky
                                          @Aaky What is the contents of /data/modalai/sku.txt?
