  3. Sentinel flips during takeoff
sentinel
39 Posts 2 Posters 12.4k Views 1 Watching
    @stevedan A couple of questions. First, are you power cycling the drone in between each of these flight attempts or just landing and then attempting the next flight without a power cycle? Is it always the same motor that appears to not be turning? If so, is it the same motor on the second drone?
    S Offline
    S Offline
    stevedan
    @Eric-Katzfey yes, it happens on a different motor on the second drone but when it happens on eahc drone, it happens in the same motors
      @stevedan Couple more questions. Are you setting the altitude for the mission to be 0.51m? That's pretty low. It could be trying to turn towards the first waypoint before it has even left the ground. Can you try at a higher altitude? What are you using for position control. Doesn't look like you are using GPS.
      S Offline
      S Offline
      stevedan
      @Eric-Katzfey i am flying indoor. Going high is a bit dangerous. I have done this multiple times on the rb5 without issue.
        @stevedan And if you set the parameter UART_ESC_VLOG to 1 then we can see in the logs if the ESC is doing the right thing.
        S Offline
        S Offline
        stevedan
        @Eric-Katzfey i will log it on Monday and send it.
        • S stevedan
          @stevedan A video of a good flight and of a bad one would also be pretty helpful.
          S 1 Reply Last reply
            @stevedan Also, with battery / power removed, can you slowly rotate each motor by hand and see if you can feel any sticky spots? Any unusual noise from the motor when it is being powered?
            S Offline
            S Offline
            stevedan
            @Eric-Katzfey when I spin the motor slow, it does as shown in the video but spinning it a bit fast, it goes smoothly. No unusual noise when I turn the drone up. Videos are in the same link as before. https://drive.google.com/drive/folders/1tFS2fI25ayHK0pZ4bpmeG1JC0PZRACEX?usp=sharing
              S Offline
              S Offline
              stevedan
              wrote on last edited by stevedan
              #12
              @Eric-Katzfey I have also added a video to the link and the log file with the name test_flight_UART_ESC_VLOG_fail for the failed flight test and test_flight_UART_ESC_VLOG_sucess for the successful flight test.
              • S stevedan
                @stevedan Thanks! It's clear from the logs that PX4 is commanding the proper motor speed to the ESC but the ESC is reporting that the motor is spinning much slower than the desired speed until the drone starts to take off. At that point that motor is commanded to go to maximum rpm and then all of a sudden the motor does start spinning at the desired speed. We are discussing this internally and will come up with a recommendation for next steps.
                • S stevedan
                  @stevedan One quick thing you can try is to blow some compressed air through the motor. If there is some debris stuck inside the motor then the air could blow it out.
                    S Offline
                    S Offline
                    stevedan
                    @Eric-Katzfey I have tried that and it seems not to work. As you said, this happens when during the arming, one of the propellers does not spin fast enough like the others. It happens randomly on both drones.
                    • S stevedan
                      @stevedan Okay, thanks for trying that. We are still discussing internally on best next steps.
                      • S Offline
                        S Offline
                        stevedan
                        #17
                        @Eric-Katzfey Just adding more information, this also happens sometimes in manual flight, but it take time for the motors to get to speed during arming.
                        • S stevedan
                          #18
                          @stevedan Okay, thanks! And thanks for your patience. We are locating a drone here in San Diego that exhibits the same behavior so we have a way to reproduce and resolve the issue. One option is to send some new motors but our lead ESC engineer believes he can resolve this with an update to the ESC firmware.
                            S Offline
                            S Offline
                            stevedan
                            @Eric-Katzfey Thank you for the fast response. Let us know because there is a bit of urgency to use the drone and there wont be enough time to procure another due to lead time. We currently have 3 new drone and plan to procure more but this is hindering us from doing so.
                            • S stevedan
                              @stevedan Okay, understood. We are testing some new ESC firmware now and hope to have an update for you early next week.
                              • S stevedan
                                @stevedan We will need to walk you through the procedure to update the ESC firmware. In order to do that we need to know what software you have running on the drone now. Can you paste the output of voxl-version?
                                • S Offline
                                  S Offline
                                  stevedan
                                  #22
                                   Service Name         |  Version  |  Enabled  |   Running   |  CPU Usage
                                   docker-autorun       |    1.2.4  | Disabled  | Not Running |
                                   docker-daemon        |    1.2.4  | Disabled  | Not Running |
                                   modallink-relink     |   0.16.1  | Disabled  | Not Running |
                                   voxl-camera-server   |    1.3.5  |  Enabled  |   Running   |   116.7
                                   voxl-cpu-monitor     |    0.3.0  |  Enabled  |   Running   |     0.0
                                   voxl-dfs-server      |    0.1.0  | Disabled  | Not Running |
                                   voxl-imu-server      |    0.5.0  |  Enabled  |   Running   |     0.0
                                   voxl-mavlink-server  |    0.3.0  |  Enabled  |   Running   |     0.0
                                   voxl-modem           |   0.16.1  | Disabled  | Not Running |
                                   voxl-portal          |    0.5.0  |  Enabled  |   Running   |     5.6
                                   voxl-px4-imu-server  |    0.1.2  | Disabled  | Not Running |
                                   voxl-px4             |  1.12.31  |  Enabled  |   Running   |     0.0
                                   voxl-qvio-server     |    0.8.2  |  Enabled  |   Running   |    27.8
                                   voxl-remote-id       |    0.0.5  | Disabled  | Not Running |
                                   voxl-softap          |    0.1.5  | Disabled  | Not Running |
                                   voxl-static-ip       |    0.1.5  | Disabled  | Not Running |
                                   voxl-streamer        |    0.4.1  |  Enabled  |   Running   |     0.0
                                   voxl-tag-detector    |    0.0.4  | Disabled  | Not Running |
                                   voxl-tflite-server   |    0.3.1  | Disabled  | Not Running |
                                   voxl-time-sync       |    1.2.2  | Disabled  | Not Running |
                                   voxl-vision-px4      |    1.4.0  |  Enabled  |   Running   |     5.6
                                   voxl-wait-for-fs     |    1.2.2  |  Enabled  |  Completed  |
                                    S Offline
                                    S Offline
                                    stevedan
                                    @Eric-Katzfey Is it possible we can set a time that both of us are available to speed up the process given that your timezone is different from mine?. like 6pm spain time?
                                    • S stevedan
                                      @stevedan Would you be willing to just move to our latest software platform release to resolve this rather than trying to get new ESC firmware setup in the release that you have now? It is in beta but we can give you access to it and it should solve your flipping issue.
                                      • S stevedan
                                        @stevedan I sent you a link to the new platform release in email if you are interested in trying it out.
                                          S Offline
                                          S Offline
                                          stevedan
                                          #26
                                          @Eric-Katzfey I can test this release and see if it solves the problem. When would this release be officially out?.
