    External autopilot not getting serial communication with M0090 board
    714
    • A
      andrespalomino
      Re: [Using M.2 5G Modem Addon Board (M0090) on voxl2]
      Hi
      My question is quite similar to this previous topic. I'm trying to conect an external autopilot with the Addon Board (M0090) in J9 pin. The device /dev/ttyHS2 is available but can not get serial data using mavros (voxl-mavlink-service is disabled).
      I launch in a different voxl2 kit and I am able to get the serial comunication running with the external autopilot.
      The differences are:
      • System working with voxl-suite: 0.9.5 and M0090 board with J8 soldered
      • System not working with voxl-suite: 0.9.4 and M0090 board with 5G module and mising J8 (we noticed it was shipped without this J8 pin), could it be a hardware issue?
      V 1 Reply Last reply 9 May 2023, 19:09 Reply Quote 0
      • M
        modaltb ModalAI Team
        Hi @andrespalomino , J9 on the M0090 board has the UART exposed (see https://docs.modalai.com/voxl2-external-flight-controller/#using-m2-5g-modem-addon-board-m0090) on pins 2/3 and you'll also need GND on pin 6.
        J8 exposes GPIO by default or a SPI, so it definitely won't work for a UART... so don't use J8.
        Can you post a pic of your M0090? I don't expect it to be missing J8 connector... Perhaps J6 is DNI as that is a kernel debug UART not used by most.
        • V
          Vinny ModalAI Team @andrespalomino
          Hi @andrespalomino
          J8 should not be missing on a Voxl2 variant that also has J2.
          If you bought a Voxl1 version, then yes, J8 is missing by design.
          Can you please send a photo of your M0090 board top and bottom?
          If you have the Voxl1 version, most of the extra UART ports are not present.
          • A
            andrespalomino
            Hi @Vinny and @modaltb
            The picture below shows the board that can not get serial in /dev/ttyHS2. I'm using J9 with pins 2/3 and 6. The cable and serial connection works in a different M0090 board
            I mentioned the missing J8 as a difference from the working board and this one. 5G module and the wifi dongle on the USB works though
            • M
              @andrespalomino we have manufactured a couple types of the M0090.
              There's a VOXL1 based flavor, that only has a single board to board connector on the BOTTOM side of the M0090.
              The VOXL2 based flavor has TWO board to board connectors.
              Did the M0090 come pre-installed or did you add it yourself?
              Can you look under the non-functional board and see if there's 2 board to board connectors? EG for VOXL2, the J3 and J5 connectors, should both be plugged into. The UART referenced here is on the "High Speed Board to Board Connector" which is J5 --> https://docs.modalai.com/voxl2-linux-user-guide/#devttyhs2---hsb2b-connector-uart
              If you have the VOXL1 version of the M0090, perhaps this is the culprit....
              • A
                andrespalomino
                Hi @modaltb
                Thanks for your information. Yes that's the point. The non-funtional board of the picture just have the J3 board to board connector
                We bought it separately with the following link which states carrier board only for VOXL2 https://www.modalai.com/products/mdk-m0090?variant=40594936463411
                I believe I could test /dev/ttyHS1 connecting to J12 USB2? Otherwise, could we start a process to return this board and get the VOXL2 based board
                V 1 Reply Last reply 11 May 2023, 18:19 Reply Quote 0
                • V
                  Hi @andrespalomino
                  Sorry for your troubles, it looks like we may have sent you a Voxl1 variant by mistake instead of a Voxl2 version.
                  I'll make sure our operations team gets you a new M0090 board meant for Voxl2, and if possible, we'll include a return shipping label for your Voxl1 version M0090 you have now.
                  A 1 Reply Last reply 15 May 2023, 09:17 Reply Quote 0
                  • A
                    andrespalomino @Vinny
                    Hi @Vinny
                    Sounds good. I have order number 3143. We have the Voxl1 version ready to return.
                    I'll be here for further instructions
                    Andres
                    • W wilkinsaf referenced this topic on 29 Jun 2023, 22:36
                    1 out of 8
