Yoshimaru TanakaY
Yoshimaru Tanaka
@Yoshimaru Tanaka
  • [Starling2] The devices are recognized as /dev/video* but no assigned as the device available in the voxl system
    Yoshimaru TanakaY Yoshimaru Tanaka
    @Alex-Kushleyev We replaced the camera and the cable, and the issue had been resolved. Thanks for your help.
    However, it was difficult to figure out this problem, and we spent a lot of time. Therefore, the SDK should automatically detect its hardware failure from dmsg. Or, there should be a trouble shooting in the document.
    I hope our awesome chatGPT to learn from my post and give us better resolution in earlier round next time XD
  • [Starling2Max] Unable to take off due to no valid local position estimate
    I resolved this issue with replacing indoor_vio.params with indoor_vio_missing_gps.params.
    @Alex-Kushleyev Could you please check my last post? I attached the full dmsg log.
    @Alex-Kushleyev
    I tried your advice, and I'm curious about the messages which looks like hardware related:
    [    6.363892] qcom,camera ac4f000.qcom,cci:qcom,cam-sensor1: Dropping the link to regulator.79
    [    6.413925] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Linked as a consumer to regulator.79
    [    7.591724] CAM_ERR: CAM-ISP: cam_ife_csid_cid_reserve: 1040 CSID:2 IPP resource not available
    Should I check the physical connection between the camera and the board?
    I also give you all I got below:
    dmesg log
    https://drive.google.com/file/d/1SR9mGPbrsWaXHDW1HW4sHUVJHjCLTbcf/view?usp=drive_link
    @Alex-Kushleyev
    I inspected with the command and got the output below:
    voxl2:/$ voxl-inspect-sku
    family code:   MRB-D0014 (starling-2)
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    27
    modem config:  22 (M0141 w/ Alfa Networks WiFi Dongle AWUS036EACS)
    tx config:     0 (none)
    extras config: 0 (none)
    SKU:           MRB-D0014-4-V1-C27-T0-M22-X0
    This is the correct setting and this is also suggested by the automatic detection of the wizard.
    I tested the 3 settings below by modifying /etc/modalai/voxl-camera-server.conf
    1. all camera
    2. w/o IMX412
    3. only IMX412
    The details are below.
    1. all camera
    Under this settings, as the drone's CPU load increases with such as viewing the image stream from VOXL portal, the likelihood that the process will fail increases. Sometimes, it dies during the starting up.
    No output from voxl-inspect-cam -a
    1. w/o IMX412
    This setting works fine. I can see the 4 image streams in VOXL portal.
    voxl-inspect-cam -a says:
    |                Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps t
    |                 tof_conf |   43200 |  180 |  240 |  1.53 |    0 |     3559 |     23.4  | 10.0 |    3.58
    |                tof_depth |   43200 |  180 |  240 |  1.53 |    0 |     3560 |     23.3  | 10.0 |    3.58
    |                   tof_ir |   43200 |  180 |  240 |  1.53 |    0 |     3560 |     23.2  | 10.0 |    3.58
    |            tracking_down | 1024000 | 1280 |  800 |  5.29 |  192 |     7690 |     31.1  | 30.0 |  245.88
    |      tracking_down_bayer | 1024000 | 1280 |  800 |  5.29 |  192 |     7690 |     30.7  | 30.0 |  245.88
    |  tracking_down_misp_grey | 1024000 | 1280 |  800 |  5.29 |  192 |     7690 |     29.8  | 30.0 |  245.88
    |  tracking_down_misp_norm | 1024000 | 1280 |  800 |  5.29 |  192 |     7690 |     30.9  | 30.0 |  245.88
    |           tracking_front | 1024000 | 1280 |  800 |  5.45 |  257 |     7577 |     30.8  | 30.0 |  245.88
    |     tracking_front_bayer | 1024000 | 1280 |  800 |  5.45 |  257 |     7577 |     30.8  | 30.0 |  245.88
    | tracking_front_misp_grey | 1024000 | 1280 |  800 |  5.45 |  257 |     7577 |     29.8  | 30.0 |  245.88
    | tracking_front_misp_norm | 1024000 | 1280 |  800 |  5.45 |  257 |     7577 |     31.3  | 30.0 |  245.88
    |            tracking_rear | 1024000 | 1280 |  800 |  5.42 |  249 |     7341 |     31.0  | 30.0 |  245.88
    |      tracking_rear_bayer | 1024000 | 1280 |  800 |  5.42 |  249 |     7341 |     31.0  | 30.0 |  245.88
    |  tracking_rear_misp_grey | 1024000 | 1280 |  800 |  5.42 |  249 |     7341 |     29.8  | 30.0 |  245.88
    |  tracking_rear_misp_norm | 1024000 | 1280 |  800 |  5.42 |  249 |     7341 |     31.1  | 30.0 |  245.88
    1. only IMX412
    No image stream.
    |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | fot
    |   hires_large_color |
    | hires_large_encoded |
    |    hires_large_grey |
    |   hires_small_color |
    | hires_small_encoded |
    |    hires_small_grey |
    |      hires_snapshot |
    As the result, this one seems to have some hardware issue. I spent a lot of time for this but any resolutions do not work at all.
    We have three of starling 2 and compared with the working one. There is no diff.
    And, this one have not been healthy since the arrival, and we have unblicked it and reinstalled the SDK:
    https://docs.modalai.com/voxl2-unbricking/
    https://docs.modalai.com/flash-system-image/
    I also found the following:
    1. px4-commander does not start automatically.
    2. "Compasse sensor 0 missing" does not disappear with the following comannd, and the preflight check fails.
    EKF2_EV_CTRL = 15
    EKF2_HGT_REF = 3
    COM_ARM_WO_GPS = 1
    SENS_MAG_MODE = 0
    @Eric-Katzfey Thanks for you response.
    I uploaded the log.
    https://logs.px4.io/plot_app?log=8129ccfb-6ab4-4851-914c-5066e4667d9f
    Recentry, I configured Staring2 Max with the indoor mode, but it is not able to take off due to no valid local position estimate:
    Arming Check Report:
    No valid local position estimate
    To resolve this issue, I tried to figure out the cause.
    Then, I found that "xy_valid: False" with the command "px4-listener vehicle_local_position".
    Could you please help me to fix this issue?
    Thanks.
    • What hardware are you using? If you have specific SKU or serial number, that is also helpful
    What version of software are you using? voxl-version is very helpful for determining software version.
    How have you configured the software? What is the output of voxl-inspect-services
    Do you have any logs? Uploading PX4 logs to https://logs.px4.io can be very helpful. See details on PX4 logs here
    Can you share pictures of your setup?
    Have you looked at the source code? If so, can you point to any potential issues?
    • What version of software are you using? voxl-version is very helpful for determining software version.
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:59:41 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.2.1
    voxl-suite:   1.4.1
    no current network connection
    • How have you configured the software? What is the output of voxl-inspect-services
     voxl-auto-logger         | Disabled  | Not Running |
     voxl-camera-server       |  Enabled  |   Running   |    79.8%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.4%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     1.2%
     voxl-io-server           | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |     3.4%
     voxl-open-vins-server    |  Enabled  |   Running   |   101.0%
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    26.7%
     voxl-qvio-server         |  Enabled  |   Running   |    29.2%
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.5%
     voxl-softap              |  Enabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.6%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    • Do you have any logs? Uploading PX4 logs to https://logs.px4.io can be very helpful. See details on PX4 logs here
    voxl2:/$ px4-listener vehicle_local_position
    TOPIC: vehicle_local_position
        timestamp: 326528208 (0.008416 seconds ago)
        timestamp_sample: 326527550 (658 us before timestamp)
        ref_timestamp: 0
        ref_lat: nan
        ref_lon: nan
        x: -0.00292
        y: -0.00900
        z: -4.82586
        delta_xy: [-0.00000, 0.00000]
        delta_z: 0.00000
        vx: 0.00147
        vy: 0.00107
        vz: 0.00699
        z_deriv: -0.00125
        delta_vxy: [-0.00078, 0.00095]
        delta_vz: 0.00020
        ax: -0.01182
        ay: 0.06224
        az: -0.02922
        heading: 0.23297
        delta_heading: 0.00000
        ref_alt: nan
        dist_bottom: 0.10000
        eph: 0.01332
        epv: 0.33389
        evh: 0.03809
        evv: 0.07235
        vxy_max: inf
        vz_max: inf
        hagl_min: inf
        hagl_max: inf
        xy_valid: False
        z_valid: True
        v_xy_valid: False
        v_z_valid: True
        xy_reset_counter: 1
        z_reset_counter: 1
        vxy_reset_counter: 1
        vz_reset_counter: 1
        heading_reset_counter: 0
        heading_good_for_control: False
        xy_global: False
        z_global: False
        dist_bottom_valid: False
        dist_bottom_sensor_bitfield: 0
        dead_reckoning: True
    • Can you share pictures of your setup?
    • Have you looked at the source code? If so, can you point to any potential issues?
      No.
    Hi, I unblicked one of our Starling2, but I can not see any video in the app QGroundControl.
    I found the problem with the debug tool described in the following log section.
    However, I could not figure out how to fix it. Could you give me any help, please?
    Thanks.
    hw version:    1
    cam config:    27
    tx config:     7 (elrs_beta_fpv)
    SKU:           MRB-D0014-4-V1-C27-T7-M22-X0
    • What version of software are you using? voxl-version is very helpful for determining software version.*
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:   1.4.1
    current IP:   wlan0: 192.168.8.1
     voxl-camera-server       |  Enabled  |   Running   |    31.9%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.7%
     voxl-imu-server          |  Enabled  |   Running   |     4.3%
     voxl-mavlink-server      |  Enabled  |   Running   |     4.0%
     voxl-open-vins-server    |  Enabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    42.9%
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.9%
     voxl-softap              |  Enabled  |  Completed  |
     voxl-vision-hub          |  Enabled  |   Running   |     9.3%
    With this command:
    voxl-inspect-cam -a
    I got this:
    Client is cleaning up pipes for the server
    ERROR in pipe_client_open opening request pipe: No such device or address
    closing and exitingver stopped without cleaning up
    I also tried this:
    voxl2:/$ ls /dev/video*
    /dev/video0  /dev/video1  /dev/video32  /dev/video33
      No.
