Sébastien de Pret Roose de CalesbergS
@Sébastien de Pret Roose de Calesberg
  • OpenVpn don't launch on boot
    Sébastien de Pret Roose de CalesbergS Sébastien de Pret Roose de Calesberg
    It gives me 2021 when I launch the time-sync command, so it should be ok.
    Going to try the sudo command.
    sudo /usr/sbin/openvpn --daemon --script-security 2 --config /etc/openvpn/modal-connector_amsterdam.ovpn
    So something like that in the vpn-start file, right?
    I have OpenVpn that work when I launch the command:
    But when I try to have it launch on boot I have the service that launch but I don't have the tun0 showing in ifconfig.Screenshot from 2021-11-19 14-51-17.png
    And i did
    systemctl enable vpn-start.service
    Any idea where the problem could be? Thanks.
    (And I ask on the side but is it possible to install zerotier?)
  • ADB no device showing in terminal
    Hello @modaltb,
    It look like in the end I managed to reinstall the image on the board but the fastboot devices and adb shell does not work.
    Hi @modaltb,
    So now it is stuck on this line
    Hi @modaltb,
    Here is what came out of it.
    And no problem, I know that this kind of thing take time.
    Thanks for your answer.
    hi @Chad-Sweet,
    Thanks for your suggestion but it is the same thing describe in the ADB setup and it is already done, and the second part is not possible because we do not have the possibility to place the device in Transfer mode, or do we?
    -Sébastien
    Hi @modaltb,
    Here is what is hapening wen i do the fastboot devices.
    But should I install an other version of Ubuntu ? If so witchone ?
    Thanks for the answear,
    -Sébastien
    Thank you @modaltb for your answer, but sadly I have already tried to unbrick it without good result.
    And I had used the sudo command wen installing fastboot.
    Here on the screenshot, I’m stuck on “waiting for any fastboot” and it run indefinitely.
    I’m running ubuntu 20.04
    I am working on VOXL Flight and the device is not showing up in the terminal, I have tried to kill the server and restart it with no success. I have also tried with the debug add-on Board. With no success eighter.
    Also, I tried power it up with a power supply with the power module and then switch to a lipo, but no success eighter.
    And from the beginning I was not having any success with the installation of a new image, but I did have the ADB connection. So, I am a little stuck if someone could help me It would be great.
    Thanks you.
