Seungjae BaekS
Seungjae Baek
@Seungjae Baek
  • About the usage of CPU core
    Seungjae BaekS Seungjae Baek
    @Alex-Kushleyev
    Hi Alex,
    we turned on only front cam (rgb + tracking) and turned off all bottom cam.
    We will try performance mode as you said, while we reduced the resoltuion from the default 4k to 1024 x 768.
  • EM9291 on Starling 2 / VOXL 2 Only Connecting on LTE — No 5G NR Bands Detected (Firmware Issue?)
    @Seungjae-Baek
    One more question: Should we use 5G antenna, not LTE? As I know when we buy the 5g modem the default antenna is the one with LTE.
    Hi ModalAI team,
    I’m using a Starling 2 max with the 5G modem add-on (Sierra Wireless EM9291). I’ve now fully activated a US Mobile Dark Star (AT&T) 5G plan, and the modem successfully registers on the network. However, the modem only connects over LTE and does not show any support for 5G NR bands.
    Here is the current status:
    1. SIM + Network Registration Working
      The SIM is active, and the module now registers correctly:
    Registration state: 'registered'
    CS: 'attached'
    PS: 'attached'
    Radio interfaces: 'lte'
    PLMN: 310/410 (AT&T Dark Star)
    1. No 5G NR Detection Anywhere
      All QMI queries indicate LTE-only operation:
    --nas-get-serving-system → only “lte”
    --nas-get-rf-band-info → EUTRAN band only
    --nas-get-system-selection-preference shows:
    Mode preference: cdma-1x, gsm, umts, lte, td-scdma
    (There is no nr5g entry at all.)
    Attempting to enable NR returns errors:
    error: invalid rat mode pref value given: 'mode-preference=nr5g'
    This only occurs when the modem firmware does not support NR.
    1. Firmware Appears to Be LTE-Only
      Firmware reported by the module:
    Modem/PRI Build ID: 02.13.08.00_GENERIC
    Based on Sierra Wireless documentation, NR-capable EM9191/EM9291 firmware versions are typically in the 03.xx.xx.xx or 04.xx.xx.xx series.
    The build I have (02.13.08.00_GENERIC) appears to be a pre-NR (LTE-only) firmware image.
    This seems to explain:
    No NR bands
    No NR technology preferences
    Failure to set NR mode
    LTE-only operation despite 5G plan
    1. Question
      Does the Starling 2 / VOXL 2 modem carrier ship with an LTE-only EM9191 firmware by default?
      If so:
    Can ModalAI provide a 5G NR-capable EM9191/EM9291 firmware package (CWE/NVU)?
    Or instructions for safely updating the modem firmware on VOXL 2?
    My goal is to enable 5G NR (NSA/SA) operation so the drone can use the full Dark Star 5G plan.
    Thanks,
    Seungjae Baek
    Hi Modal AI Team,
    Currently we are using Starling 2 max, and we want to ask you whether we can mitigate the CPU usage of voxl-camera-server.
    As you can see the bottom right terminal, we manually turn off 3 cams and only using 2 front cams (total 5, turn off 3 at bottom) by modifying .conf file.!
    but still the CPU usage of camera is very high (over 100% when seeing with voxl-inspect-services) , as you can see in the top right and bottom left terminal.
    We attached the screenshot. Thank you.
