Rowin LeemeijerR
Rowin Leemeijer
@Rowin Leemeijer
  • VOXL-UVC-Server on QGC latency & ethernet
    Rowin LeemeijerR Rowin Leemeijer
    I got the UVC-Server working now with a USB camera, but it has a ~1 second latency when viewed on QGC compared to voxl-portal with only milliseconds delay over wifi, can that be fixed?
    And is there also a way to get the USB camera to work via ethernet as it currently only works on QGC with the IP of the wifi and I want it to work on the IP of the ethernet adapter attached to the VOXL.
  • UVC USB Camera glitchy
    @Eric-Katzfey
    I tried to plug in a Arducam B0200, it got detected by the VOXL but the image was glitchy. It works on my windows laptop and on ubuntu linux but it does not work on the VOXL.
    Anyone knows what could be causing an issue and or if there is a fix for it?
  • USB2.0 to Ethernet
    The ones I linked or did you mean other ones? @tom
    @Eric-Katzfey That works, thanks. Are you guys testing any alternatives? As it seems the apple adapter is not widely available anymore.
    I've tried several, here's a few ones:
    UGreen
    UGreen
    UGreen
    I want to use the USB2.0 port on the expansion board to route ethernet. This sort of works in our current setup, but when pinging it randomly stops and says "Request timed out" after that it continues pinging fine until another "Request timed out". I've tried another device instead of the VOXL and that works perfectly with the same setup.
    Anyone knows what could be causing an issue?
