Pavel ArdashovP
Pavel Ardashov
@Pavel Ardashov
  • Video recording from a 4k camera to a SD card.
    Pavel ArdashovP Pavel Ardashov
    Is it currently possible with VOXL to stream in Full HD and record 4k30 from the M0025?
    @Eric-Katzfey The documentation says about the ability to record 4k30 video. Currently, I don't care about the recording format.
    I need to stream full hd and record 4k30 from camera M0025
    @Eric-Katzfey camera MPA https://www.modalai.com/products/4k-high-resolution-sensor-for-voxl-8x8x5-8mm
    format RAW or compressed
    I need to stream full hd and record original 4k video.
  • Component offsets
    @Alex-Gardner thank you very much
  • Component offsets
    On the drone, the tracking camera and tof are installed in the front, the VOXL is shifted to the back, and the flight controller is installed in the center.
    Where to specify offsets for sensors, VOXL and flight controller.
    Please tell me how can record video in original quality from a 4k camera to a SD card?
  • Recording camera frames to file using MPA
    @Cliff-Wong Thanks! Happened.
    Please tell me how to record video to SD?
    @Eric-Katzfey please tell me how to recording the raw frames coming from the sensor (voxl-camera-server) to a SD card?
  • Flight Deck error after arm
    @modaltb my FlightDeck have a barometer 3D printed cap.
    But it was not tight, there was a groove in it. Maybe it was planned?
    By completely closing the barometer, we fixed the problem.
  • VOXL error
    ADB was not connected.
    After connecting the fastboot board, it turned out to turn on the device in fastboot mode.
    After connecting in the fastboot mode manually, using the fastboot command, the disk partitions were flashed, as is done in the install.sh script.
    Problem solved
    Thank you, the issue was resolved on my own.
    An additional box helped to close the barometer. After installing it, there is no problem with height data.
    Hi @modaltb
    Flight deck attached to a custom drone.
    After ARM, the propellers were spinning, but the drone remained in place, as you can see in the video. The video from the Hires camera is displayed on the monitorизображение_viber_2021-10-21_08-34-00-588.jpg .
    During the crash voxl-inspect-qvio send
    error_code BAD_CAM_CAL
    After launching Flight Deck, the odometry section displays coordinates and altitude correctly.
    After ARM, the altitude and coordinates start to change, although the drone stays in place. After a few seconds, the service stops.
    What could be the reason?
    Link video:
    https://drive.google.com/file/d/1F8AQSUKgaRQQLYBb7HapdTN5cBDFk7Hk/view?usp=sharing
  • VOXL error
    @Chad-Sweet Thanks for the answer.
    Should the Poweroff command be performed every time at the end of the flight?
  • VOXL error
    Hi!
    VOXL Flight Deck stopped connecting via WI -FI.
    When connecting adb, first connected with an error, then stopped connecting.
    Now adb does not define as a connected device.
    What could be the reason and how can you fix it?
  • CE, RoHS certifications
    Please tell me, do your products have CE, RoHS certificates?
  • stereo camera down
    Hi.
    1. Can I buy a flight core with a thermal imaging camera from you?
    2. I need to install the stereo camera down. Is it possible? What needs to be done for this?
  • ERROR: failed to start modalai vision lib
    @Chad-Sweet now the odometry data is in the mavlink inspector, but x and y = 0
    @Chad-Sweet when connecting QGC, there was no odometry in the mavlink inspector. After that I ran voxl-configure-modalai-vl
