Michael HattonM
Michael Hatton
@Michael Hatton
  • Starling 2 Max GPS - denied Development Drone Batteries
    Michael HattonM Michael Hatton
    My Starling 2 Max GPS - denied Development Drone came with 4 batteries. It also came with a power supply. I used the instructions to power the drone with the power supply. But I see no way to charge the batteries with the power supply. Is that something else I will need to purchase?
  • LTE Modem v2 Pro
    I installed an LTE Modem v2 Pro module onto the Starling 2 Max GPS - denied Development Drone. When I power on the Drone the module lights up. I even installed a SIM card. But it does not attach to the cellular network. Does firmware for the LTE Modem v2 Pro module need to be installed? If so are there any guides for this? I could find a datasheet but there was no info about what needs to happen to cause the module to work?
    I am not actually sure what is needed for the Starling 2 Max GPS - denied Development Drone either. Does this also come without firmware and that must be installed too?
  • Powering Starling 2 Max
    I have a Starling 2 Max GPS-denied Development Drone. I have 4 batteries. I plugged in two of them and the drone powered on.
    It also came with an AC Adapter and the instructions on how to plug into drone make sense. The issue is that it also comes with a warning, "DO NOT ARM DRONE WHILE XT30 JUMPER OR POWER SUPPLY IS IN USE. FAILURE TO DO SO WILL LIKELY RESULT IN DAMAGED HARDWARE. COULD RESULT IN FIRE"
    What do you mean by "Armed". When I plug in the batteries the drone turns on. I assume that means when I plug in the power supply it will also turn on. Does that mean it is Armed?
  • How to install LTE Modem v2 Pro
    I have a Starling 2 Max GPS-denied Development Drone and an LTE Modem v2 Pro.
    The LTE Modem v2 Pro came with antennas, which I have installed and a JST-to-USB Female A cable. I plugged this JST end to the module but there is no USB A connector on the drone. Is there another way to connect to the drone?
