Kyuhyong YouK
Kyuhyong You
@Kyuhyong You
  • Host PC cannot detect ros topics from voxl2
    Kyuhyong YouK Kyuhyong You
    @Kyuhyong-You
    It actually turned out that the host-pc has ufw enabled.
    Disabling ufw solved the issue.
    Thanks
    VOXL SDK and Software ros
    @Zachary-Lowell-0
    Is there a way to publish ros2 message to certain ethernet port?
  • how to stop microdds-agent from running?
    As soon as I install voxl-ros2-foxy, I see topics being published
    $ ros2 topic list
    /fmu/collision_constraints/out
    /fmu/debug_array/in
    /fmu/debug_key_value/in
    /fmu/debug_value/in
    /fmu/debug_vect/in
    /fmu/manual_control_setpoint/in
    /fmu/offboard_control_mode/in
    /fmu/onboard_computer_status/in
    /fmu/optical_flow/in
    /fmu/position_setpoint/in
    /fmu/position_setpoint_triplet/in
    /fmu/sensor_combined/out
    /fmu/telemetry_status/in
    /fmu/timesync/in
    /fmu/timesync/out
    /fmu/trajectory_bezier/in
    /fmu/trajectory_setpoint/in
    /fmu/trajectory_waypoint/out
    /fmu/vehicle_attitude/out
    /fmu/vehicle_command/in
    /fmu/vehicle_command_ack/out
    /fmu/vehicle_global_position/out
    /fmu/vehicle_local_position/out
    /fmu/vehicle_local_position_setpoint/in
    /fmu/vehicle_mocap_odometry/in
    /fmu/vehicle_odometry/out
    /fmu/vehicle_offboard_setpoints/in
    /fmu/vehicle_setpoints/in
    /fmu/vehicle_status/out
    /fmu/vehicle_trajectory_bezier/in
    /fmu/vehicle_trajectory_waypoint/in
    /fmu/vehicle_trajectory_waypoint_desired/out
    /fmu/vehicle_visual_odometry/in
    /gimbal_attitude
    /mission_command
    /mission_command_ack
    /mission_status
    /parameter_events
    /physical_state
    /rosout
    /set_vehicle_id
    /stick_command
    /timesync_status
    /vehicle_command
    /vehicle_status
    I didn't even installed voxl-microdds-agent, voxl-mpa-to-ros2
    How can I let voxl stop sending these message?
    I just want to run the agent myself.
    Thanks,
  • voxl2 and dshot esc
    I am trying to use 4 in 1 esc from https://holybro.com/collections/autopilot-peripherals/products/tekko32-f4-metal-4in1-65a-esc-65a
    This esc works with DSHOT however
    https://nearth.atlassian.net/l/cp/HSr9ZCoU says DSHOT is "Not yet supported"
    If DSHOT not available, can I use PWM instead?
    Which port should I use on voxl 2 board to connect PWM input to esc?
    Thanks,
    @Zachary-Lowell-0
    I was finally able to install ros2 on voxl2 with latest sdk 1.1.0 and run voxl_mpa_to_ros2_node.
    and I can see the topics on voxl2 as below.
    VOXL:~$ ros2 topic list
    /fmu/in/obstacle_distance
    /fmu/in/offboard_control_mode
    /fmu/in/onboard_computer_status
    /fmu/in/sensor_optical_flow
    /fmu/in/telemetry_status
    /fmu/in/trajectory_setpoint
    /fmu/in/vehicle_attitude_setpoint
    /fmu/in/vehicle_command
    /fmu/in/vehicle_mocap_odometry
    /fmu/in/vehicle_rates_setpoint
    /fmu/in/vehicle_trajectory_bezier
    /fmu/in/vehicle_trajectory_waypoint
    /fmu/in/vehicle_visual_odometry
    /fmu/out/failsafe_flags
    /fmu/out/position_setpoint_triplet
    /fmu/out/sensor_combined
    /fmu/out/timesync_status
    /fmu/out/vehicle_attitude
    /fmu/out/vehicle_control_mode
    /fmu/out/vehicle_local_position
    /fmu/out/vehicle_odometry
    /fmu/out/vehicle_status
    /parameter_events
    /rosout
    Now I am trying to send command via ros2 message from my host pc however those topics are not visible on my host pc.
    HOST_PC:~$ ros2 topic list
    /parameter_events
    /rosout
    They both have same ROS_DOMAIN_ID=0
    They are in the same network router and share same ip layer 10.10.150.XXX
  • RMW_IMPLEMENTATION not set for ros2
    @Kyuhyong-You
    After reboot this error is magically gone.
    now I can see topics
    after $ ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
    then in another terminal on voxl, I see below topics
    $ ros2 topic list
    /parameter_events
    /rosout
  • voxl_mpa_to_ros2 error with libtinyxml2.so.6
    @Kyuhyong-You
    I found solution.
    This error was resolved by apt installing libtinyxml2 by
    sudo apt install libtinyxml2-dev
    With sdk 1.1.0 up and running.
    apt installed ros-foxy and voxl_mpa_to_ros2 as well.
    as described in this document https://docs.modalai.com/ros2-installation-voxl2/
    When trying to start voxl_mpa_to_ros2_node I get following error.
    /opt/ros/foxy/mpa_to_ros2/install/voxl_mpa_to_ros2/lib/voxl_mpa_to_ros2/voxl_mpa_to_ros2_node: error while loading shared libraries: libtinyxml2.so.6: cannot open shared object file: No such file or directory
    How to fix this error?
    I just upgraded my voxl2 with the latest sdk 1.1.0 and apt installed ros2 relate packages as follows
    sudo apt install voxl-ros2-foxy
    $ sudo apt install voxl-microdds-agent
    $ sudo apt install voxl-mpa-to-ros2
    $ pip3 install netifaces
    $ pip3 install pyyaml
    After source /opt/ros/foxy/setup.bash and tried to run ros2 topic and it returns following error.
    $ ros2 topic list
    Unable to get rmw_implementation_identifier, try specifying the implementation to use via the 'RMW_IMPLEMENTATION' environment variable
    It seems like RMW_IMPLEMENTATION not set in the bash.
    How to set this variable to run on voxl?
    Also tried to run configuration as below
    $ sudo voxl-configure-microdds
    Starting Wizard
    do you want to enable or disable voxl-microdds-agent
    factory-enable will also reset the config file back to default
    1) disable
    2) enable
    #? 2
    enabling  voxl-microdds-agent systemd service
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-microdds-agent.service → /etc/systemd/system/voxl-microdds-agent.service.
    Done configuring voxl-microdds-agent
    And inspect service returns
    $ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.7%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     6.2%
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |     3.4%
     voxl-microdds-agent      |  Enabled  |   Running   |    13.5%
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    40.2%
     voxl-qvio-server         |  Enabled  |   Running   |     4.2%
     voxl-rangefinder-server  | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.1%
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  |   Running   |     1.8%
     voxl-wait-for-fs         |  Enabled  |  Completed  |``
  • How to check which version of sdk is running?
    @tom
    Wow I didn't know there is dedicated apt package to install ros-foxy and why the guide leads to install ros via script.
    Anyway thanks for the comment and I will try to install as you mentioned.
    FAQs
    @tom I see.
    I updated flash with the latest sdk image and now I can see the version number.
    $ voxl-version
    system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025
    kernel:       #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:   1.1.0
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2023-11-20 08:24:30
    List:
    	libmodal-cv                 0.4.0
    	libmodal-exposure           0.1.0
    	libmodal-journal            0.2.2
    	libmodal-json               0.4.3
    	libmodal-pipe               2.9.2
    	libqrb5165-io               0.4.2
    	libvoxl-cci-direct          0.2.1
    	libvoxl-cutils              0.1.1
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0
    	qrb5165-imu-server          1.0.0
    	qrb5165-rangefinder-server  0.0.4
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3
    	qrb5165-tflite              2.8.0-2
    	voxl-bind-spektrum          0.1.0
    	voxl-camera-calibration     0.5.1
    	voxl-camera-server          1.8.7
    	voxl-configurator           0.4.4
    	voxl-cpu-monitor            0.4.7
    	voxl-docker-support         1.3.0
    	voxl-elrs                   0.1.3
    	voxl-esc                    1.3.4
    	voxl-feature-tracker        0.3.2
    	voxl-flow-server            0.3.3
    	voxl-gphoto2-server         0.0.10
    	voxl-jpeg-turbo             2.1.3-5
    	voxl-lepton-server          1.2.0
    	voxl-libgphoto2             0.0.4
    	voxl-libuvc                 1.0.7
    	voxl-logger                 0.3.5
    	voxl-mavcam-manager         0.5.3
    	voxl-mavlink                0.1.1
    	voxl-mavlink-server         1.3.1
    	voxl-microdds-agent         2.4.1-0
    	voxl-modem                  1.0.8
    	voxl-mongoose               7.7.0-1
    	voxl-mpa-to-ros             0.3.7
    	voxl-mpa-to-ros2            0.0.1
    	voxl-mpa-tools              1.1.2
    	voxl-opencv                 4.5.5-2
    	voxl-portal                 0.6.2
    	voxl-px4                    1.14.0-2.0.55
    	voxl-px4-imu-server         0.1.2
    	voxl-px4-params             0.2.7
    	voxl-qvio-server            0.9.4
    	voxl-remote-id              0.0.9
    	voxl-streamer               0.7.4
    	voxl-suite                  1.1.0
    	voxl-tag-detector           0.0.4
    	voxl-tflite-server          0.3.1
    	voxl-utils                  1.3.3
    	voxl-uvc-server             0.1.6
    	voxl-vision-hub             1.7.1
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
    I also tried to install ros2 as described in https://docs.modalai.com/ros2-installation-voxl2/
    by running ./installROS2.sh and I got following error while building the foonathan_memory.
    CMake Error at CMakeLists.txt:7 (cmake_minimum_required):
      CMake 3.11 or higher is required.  You are running version 3.10.2
    make[2]: *** [foo_mem-ext-prefix/src/foo_mem-ext-stamp/foo_mem-ext-configure] Error 1
    make[1]: *** [CMakeFiles/foo_mem-ext.dir/all] Error 2
    make: *** [all] Error 2
    Failed   <<< foonathan_memory_vendor [0.54s, exited with code 2]
    It looks like it requires to update Cmake.
    Do you have any suggestions?
    FAQs
    I could not find command to check the version of sdk.
    Below is the info from sdb shell
    system-image: 1.6.2-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
    hw version:   M0054
    voxl-suite:
    current IP: eth0:
    FAQs
  • running uxrce_client with voxl2-px4
    @Zachary-Lowell-0
    Thanks for your comment!
    So it means px4 on voxl2 is running microdds_client which is not compatible with uxrce_dds_cleint on the PX4 release/1.14.0
    And the microdds_client will start automatically when px4 on voxl2 service is up and running?
    I just wondering if volx2-px4 can run uxrce_dds_client as described here.
    https://docs.px4.io/main/en/middleware/uxrce_dds.html
    I was able to build install ros2 on voxl2 and uxrce_dds_agent and runs ok with external FC.
    I also found voxl-px4 runs with v1.14.0 version
    pxh> ver mcu
    UNKNOWN MCU
    pxh> ver hw
    HW arch: MODALAI_VOXL2
    pxh> ver all
    PX4 git-hash:
    PX4 version: 1.14.0 0 (17694720)
    Vendor version: 2.0.34 0 (33563136)
    OS: Linux
    OS version: Release 4.19.125 (68386303)
    Build datetime: Jun  7 2023 14:33:27
    Build uri: localhost
    Build variant: default
    Toolchain: GNU GCC, 7.5.0
    PX4GUID:
    UNKNOWN MCU
    Is it possible to run dds client?
  • How to untilize DBG_UART12 pins as generic tty device?
    I am trying to use debug pins (GPIO_35_DBG_UART12_RX, TX) on voxl2 as described here.
    https://docs.modalai.com/voxl2-connectors/#j3---legacy-board-to-board-connector-b2b
    Which /dev/tty can I acess?
    If not listed in /dev/tty how can I enable this pin as tty pin?
    Is there any alternative way to talk/listen from serial port?
    Thanks
    Kyu
