J
Judoor 0
@Judoor 0
Regular
  • Issue sending custom odometry to PX4 via MAVROS
    J Judoor 0
    Hi @teddy-zaremba,
    The fusing part was a bit tricky, but it works now.
    Thank you!
    VOXL SDK and Software ros
    J Judoor 0
    PX4 firmware: 1.15.4
    Using Starling 2.
    I’m trying to send custom odometry data to PX4 using MAVROS on ROS melodic.
    For testing, I’m publishing a message filled with zeros (except w) at 30 Hz to the topic /mavros/vision_pose/pose. Then i disabled openvins and qvio services.
    I also tried to follow this topic : https://forum.modalai.com/topic/2118/send-motion-capture-system-pose-data-to-px4/3
    However, when I check /mavros/local_position/odom, I don’t see my message. Instead, I only receive a 30hz position message from an unknown source.
    On QGC, i don't see any messages like visual pose or odometry.
    I also tried publishing to /mavros/odometry/out, but it didn’t change anything.
    Additionally, I modified some EKF2 parameters, including EKF2_EV_CTRL, following the PX4 documentation, but still no success.
    I’m not sure what I’m missing here.
    Any help or guidance would be greatly appreciated.
  • Apriltag relocalization not relocalizing?
    J Judoor 0
    @Alex-Kushleyev Is there some news about this issue ?
    Autonomy: VIO, Mapping and Navigation apriltag
  • Getting Range finder information in ROS and more.
    J Judoor 0
    @teddy-zaremba Hi teddy,
    I'm on ROS 1 so it's just MPA_TO_ROS and not MPA_TO_ROS2.
    Yes I looked at the rangefinder pipes and did get the rangefinder data and republished_it in ROS and same with the ov_status.
    I don't have access to microdds in ROS1 unless I do a ROS2 to ROS1 bridge.
    Julien
    J Judoor 0
    @Alex-Kushleyev I don't know who can help me on this one, I tried to modify the mpa_to_ros package and I think I did it successfully (adding range-sensor and some vins status). How can I share it, so someone from your team can verify it and then if it's good enough put it on the gitlab ?
    Julien
    J Judoor 0
    @Judoor-0 For the rangefinder part i've looked into the mpa_to_ros code and modified it to add rangefinder_data_t and republished it in a ros_topic.
    But for the covariance/error of the vio I still have no clue how to get it
    Julien
    J Judoor 0
    I'd like to get the range finder data in ROS, right now it doesn't appear in mpa_to_ros, what should I change for it to appear?
    I cannot get it from MAVROS either, the distance_sensor doesn't appear in my topics. But it appears on GQC and i've got the right value.
    Is it cause I set it up wrong in voxl-px4.conf (right now the value is NONE).
    Also, how can i get an idea of when the VIO / OV start to fail so I can activate a failsafe in my ROS Node?
    Setup : Starling 2 max, dual cam, with TOF
    Have a good day
    Julien
  • LIO with TOF LiDAR: Seeking Point Intensity & Noise Data from mpa_to_ros
    J Judoor 0
    @teddy-zaremba Thank you
    I think Aaron was maybe talking about the depth image that we can get from the tof sensor.
    I'll check the aligned point cloud but i don't think he has the confidence data (XYZC)
    Julien
    J Judoor 0
    @Aaron-Porter Hi,
    Did you had time to check it out ?
    Julien
    J Judoor 0
    @Aaron-Porter Hi Aaron, Yes i'm using the modalAI TOF with a Starling2 MAX. If you can test it, I'll appreciate it ! Thank you!
    J Judoor 0
    Hello everyone,
    I'm working on developing a LIO (LiDAR-Inertial Odometry) algorithm and am looking to use TOF (Time-of-Flight) LiDAR data.
    When I look at the ROS messages published by mpa_to_ros, I only seem to receive the points positions. I'm wondering if it's possible to also include the intensity value and noise information for each point?
    Any insights or suggestions would be greatly appreciated!
  • IMU stream rate fixed at 10Hz (PX4)
    J Judoor 0
    @Eric-Katzfey I'm using integrated IMU with VOXL2
    J Judoor 0
    I'm using an IMU with PX4 firmware. I attempted to change the stream rate of the IMU data to at least 50Hz, instead of the default 10Hz. However, when I use rosservice /mavros/set_stream_rate or rosservice /mavros/set_message_interval, there is no change.
    Could this be related to MPA, PX4, or another factor?
    Thanks in advance.
  • Instruction to set a Static IP for wlan0 voxl2
    J Judoor 0
    Another way to do it, maybe more in line with the way modal ai intended it is this :
    Update dhcpcd.conf for Static IP
    Open the dhcpcd.conf file for editing:
    nano /etc/dhcpcd.conf
    Add the following lines at the end of the file to configure a static IP for wlan0:
    interface wlan0
    static ip_address=192.168.XX.XX/24
    static routers=192.168.XX.1
    static domain_name_servers=8.8.8.8 1.1.1.1
    Explanation:
    interface wlan0: Specifies the network interface to configure.
    static ip_address=192.168.XX.XX/24: Assigns the static IP and subnet mask.
    static routers=192.168.XX.1: Sets the gateway address.
    static domain_name_servers=8.8.8.8 1.1.1.1: Configures DNS servers (Google and Cloudflare in this case).
    Save and exit the file.
    Restart dhcpcd Service
    Apply the changes by restarting the dhcpcd service:
    systemctl enable dhcpcd
    systemctl restart dhcpcd
    J Judoor 0
    Guide to Configure a Static IP Address with systemd-networkd
    I didn't find any guide on how to do it with the voxl2, even the static-ip service seem reserved for eth0 configuration, tell me, if i'm wrong i'll delete this.
    If you want to assign a static IP address to your wireless network interface (using systemd-networkd), follow this simple guide. In this example, we configure the wlan0 interface to use the static IP address 192.168.XX.XX.
    1. Check the Status of systemd-networkd
    Before starting, ensure that systemd-networkd is enabled and running:
    sudo systemctl status systemd-networkd
    If the service is not active, enable it:
    sudo systemctl enable systemd-networkd
    sudo systemctl start systemd-networkd
    2. Create the Configuration File for wlan0
    1. Navigate to the configuration directory:
      cd /etc/systemd/network/
    2. Create a configuration file for your wireless interface (e.g., 10-wlan0.network)
      sudo nano 10-wlan0.network
    3. Add the following lines to the file:
      [Match]
      Name=wlan0
      [Network]
      Address="192.168.XX.XX"/24
      Gateway="192.168.XX.1"
      DNS=8.8.8.8 1.1.1.1
      Explanation:
      • Name=wlan0: Specifies the target interface.
      • Address=192.168.XX.XX/24: Defines the IP address and subnet mask.
      • Gateway=192.168.XX.1: Sets the default gateway.
      • DNS=8.8.8.8 1.1.1.1: Configures the DNS servers.
    4. Save and close the file.
    3. Restart systemd-networkd
    Apply the new configuration by restarting the service:
    sudo systemctl restart systemd-networkd
    4. Verify the Configuration
    To verify that the IP address has been assigned to wlan0:
    ip addr show wlan0
    You should see the IP address 192.168.XX.XX assigned to the interface.
    5. Enable the Service at Boot
    Ensure that systemd-networkd is enabled to run at every boot:
    6. Reboot the System
    To confirm everything works correctly on startup:
    sudo reboot
    You have now successfully configured a static IP address for the wlan0 interface using systemd-networkd on your voxl2!
  • /tof_depth image conversion problem
    J Judoor 0
    @Alex-Kushleyev thank you alex i'll try that
    J Judoor 0
    Can you help me with the depth image conversion ?
    J Judoor 0
    I would like to convert the depth image from mono8 to UC16 while maintaining accurate depth references.
    Currently, I am doing this, but I am ending up with a flat image.
    void depthCallback(const sensor_msgs::ImageConstPtr &msg)
             try
                 // Convert the input ROS image to an OpenCV image
                 cv_bridge::CvImagePtr cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::MONO8);
                 // Create a new image in CV_16UC1 format
                 cv::Mat converted_image;
                 cv_ptr->image.convertTo(converted_image, CV_16UC1, 256.0); // Scale mono8 values to 16-bit
                 // Publish the converted image
                 cv_bridge::CvImage out_msg;
                 out_msg.header = msg->header; // Keep the same header
                 out_msg.encoding = sensor_msgs::image_encodings::TYPE_16UC1;
                 out_msg.image = converted_image;
                 depth_pub_.publish(out_msg.toImageMsg());
                 // depth_pub_.publish(depth_msg);
             catch (cv_bridge::Exception &e)
                 ROS_ERROR("CvBridge Error in depthCallback: %s", e.what());
    Also, I want to mix it with an RGB image to get an RGBD image, I'm using the rgbdsync nodelet from rtabmap_ros. But I'm unable to make it work. Does someone already did that ?
    Julien
  • Motor stop functionning on starling 2
    J Judoor 0
    @Jeremy-Schmidt Hi,
    It's resolved now, in the mean time I had a response from the support.
    Have a good day
    Julien
    Development Drones starling
    J Judoor 0
    @Alex-Kushleyev I sent an email to the modal ai support for the RMA process and after a first response telling me that they'll check it, I still got no news from them and it has been 3 weeks. Do you know some other way to get in touch with the support. My starling is stuck to the ground since and I can't test anything.
    Thanks
    Julien
