JP DroneJ
JP Drone
@JP Drone
  • Request: Add Flight Deck 2 YAML Configurations for OpenVINS Testing
    JP DroneJ JP Drone
    I’m currently evaluating OpenVINS on a Flight Deck 2 platform (VOXL2 + OV7251 tracking camera mounted at a downward-forward angle).
    I would like to test OpenVINS with a proper configuration, but I noticed that there are no Flight Deck 2–specific yaml files in the following directory:
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-open-vins-server/-/tree/master/misc_files/usr/share/modalai/voxl-open-vins/VoxlConfig
    Would it be possible for the ModalAI team to add a set of yaml configurations optimized for Flight Deck 2?
    Thank you very much for your support!
  • EIS merge
    JP DroneJ JP Drone
    Hi @Alex-Kushleyev
    Happy to test it.
    My IMX412 is mounted upside-down on J7-Lower (cam ID 2).
    Could you provide a flip version of the EIS driver, e.g. com.qti.sensormodule.imx412_fpv_flip_eis_2.bin?
    Thanks a lot for all the support!
  • EIS merge
    JP DroneJ JP Drone
    Hi @Alex-Kushleyev
    Some of the videos and photos taken with the IMX412 I have on hand were blurry due to vibration.
    I tried various things but couldn’t resolve the issue—however, it was resolved after I replaced the lens with a different one.
    Would it be possible to include a replacement lens with my current order?
    Also, I have a few units in stock, and I’m concerned there might be similar issues with them.
  • Unexpected characters appearing on OSD
    JP DroneJ JP Drone
    @Eric-Katzfey Thank you for your work!
    It successfully resolved the issue. The unexpected characters no longer appear on the OSD.
    I appreciate your support and quick response.
    JP DroneJ JP Drone
    Re: Request for QURT Compatibility for OSD Program
    I am currently working on integrating MSP DisplayPort OSD, and I have encountered an issue where unexpected characters appear next to the "DISARMED" message on the OSD.
    Version Info:
    voxl-px4: 1.14.0-2.0.95
    Any insights or suggestions would be greatly appreciated.
  • Support Photo/Video Capture via RC Switch
    JP DroneJ JP Drone
    I would like to request a feature that allows taking photos and videos using an RC switch on VOXL 2 Mini.
    We’ve investigated how to trigger photo/video capture by sending MAV_CMD_IMAGE_START_CAPTURE (or MAV_CMD_VIDEO_START_CAPTURE) from PX4-firmware when an RC switch is toggled. However, it seems that mavlink-camera-manager (voxl-mavcam-manager) currently only processes commands coming from GCS, and does not handle commands that originate from the PX4 autopilot.
    Environment:
    VOXL 2 Mini (SDK 1.3.5)
    px4-firmware side with #define ATL_MANTIS_RC_INPUT_HACKS enabled to use photo_switch and video_switch.
    Confirmed that MAV_CMD_IMAGE_START_CAPTURE is indeed being sent by PX4 upon toggling the RC switch.
    From our investigation, mavlink-camera-manager/src/qgc.c only handles messages from FROM_GCS_PIPE_NAME ("mavlink_from_gcs"). As a result, any capture commands (MAV_CMD_*_CAPTURE) sent by the PX4 autopilot via an RC switch are not recognized, so photos or videos are never saved.
    Having the ability to start/stop captures via a user’s RC switch instead of exclusively through a GCS would be extremely helpful. We would greatly appreciate it if mavlink-camera-manager could also accept and handle MAV_CMD_*_CAPTURE commands from PX4 (or if there is an alternative way to accomplish this, we’d be interested in hearing about it).
    Thank you for your time and consideration. We look forward to any updates or guidance you can provide on this topic.
    Feature Requests
  • Camera Display on Portal Using a Smartphone
    JP DroneJ JP Drone
    I am trying to access VOXL Portal from my smartphone(iPhone) to display the camera feed.
    However, even when I select an individual camera from the menu, it does not display.
    Additionally, the snapshot capture feature is not functioning, which is also an issue.
    When I select Multi-View, the camera display does work, but since I cannot take snapshots, it does not meet my intended use case.
    Could this issue be due to a bug?
    One more question: Is there any plan to implement a video recording feature in Portal in the future?
  • Request for QURT Compatibility for OSD Program
    JP DroneJ JP Drone
    @Eric-Katzfey
    Thank you for your quick update.
    I was able to confirm that it is functioning properly.
    Really appreciate your support. Wishing you a wonderful New Year!
    JP DroneJ JP Drone
    @Eric-Katzfey
    I think the messages of OSD_STATUS_ROW appear on both, OSD_STATUS and OSD_FM.
    Problem seems the message is appear to OSD_FM_ROW when OSD_STATUS_ROW is enabled.
    JP DroneJ JP Drone
    @Eric-Katzfey
    Here is the OSD params
    1	1	OSD_BAND	5	6
    1	1	OSD_BATT_COL	44	6
    1	1	OSD_BATT_ROW	17	6
    1	1	OSD_CBATT_COL	44	6
    1	1	OSD_CBATT_ROW	16	6
    1	1	OSD_CHANNEL	1	6
    1	1	OSD_CH_COL	-1	6
    1	1	OSD_CH_HEIGHT	0	6
    1	1	OSD_CH_ROW	-1	6
    1	1	OSD_CURR_COL	-1	6
    1	1	OSD_CURR_ROW	-1	6
    1	1	OSD_DIS_COL	1	6
    1	1	OSD_DIS_ROW	11	6
    1	1	OSD_DWELL_TIME	500	6
    1	1	OSD_FM_COL	1	6
    1	1	OSD_FM_ROW	9	6
    1	1	OSD_HDG_COL	21	6
    1	1	OSD_HDG_ROW	0	6
    1	1	OSD_HOME_COL	-1	6
    1	1	OSD_HOME_ROW	-1	6
    1	1	OSD_LAT_COL	-1	6
    1	1	OSD_LAT_ROW	-1	6
    1	1	OSD_LOG_LEVEL	3	6
    1	1	OSD_LONG_COL	-1	6
    1	1	OSD_LONG_ROW	-1	6
    1	1	OSD_REMOTE	0	6
    1	1	OSD_RSSI_COL	-1	6
    1	1	OSD_RSSI_ROW	-1	6
    1	1	OSD_SCROLL_RATE	125	6
    1	1	OSD_STATUS_COL	1	6
    1	1	OSD_STATUS_ROW	17	6
    1	1	OSD_SYMBOLS	16383	6
    1	1	OSD_VIO_COL	38	6
    1	1	OSD_VIO_ROW	0	6
    Thank you for the advice.
    Both messages are disappeared when I set OSD_STATUS_ROW to -1
    Also it was working as expected when I try it from the J10 port
    JP DroneJ JP Drone
    @Eric-Katzfey Thank you for your support and the updated package.
    I have successfully verified that the OSD works using J19 pins for UART communication. The msp_dp_osd program is displaying the OSD as expected.
    However, I noticed an issue where a STATUS message or similar text is displayed in two locations. One appears correctly in the lower-left corner, as configured, but another is also visible near the center-left of the screen (please see the attached image).
    Could you confirm if this behavior is expected?
    Current configurations:
    OSD_DIS_COL 1
    OSD_DIS_ROW 11
    OSD_STATUS_COL 1
    OSD_STATUS_ROW 17
    I would also be happy to handle long error messages.
    JP DroneJ JP Drone
    @Eric-Katzfey Thank you for providing the updated package.
    I will test it within the next three days.
    I’ll get back to you with the results shortly.
    JP DroneJ JP Drone
    @Eric-Katzfey Thank you for your response.
    Yes, that's correct. I don't use GPS for indoor flight, so it's fine to use that UART port on J19 for OSD.
    I appreciate your support and look forward to the update.
    JP DroneJ JP Drone
    I am currently working on configuring the OSD program (msp_dp_osd) on VOXL 2 Mini. I have successfully confirmed that the OSD works using Pins 4/5 on J10 (/dev/ttyHS0).
    However, Pins 4/5 on J10 (/dev/ttyHS0) are required for other critical purposes, and as a result, I would like to utilize J19 Pins 2/3 (SSC_QUP6) for OSD UART communication.
    As these pins are connected to the DSP (SLPI processor), the current OSD implementation cannot access SSC_QUP6 directly because it requires QURT compatibility.
    I kindly request that the OSD program be extended for QURT compatibility so it can function over SSC_QUP6 (J19 Pins 2/3). This modification would free up /dev/ttyHS0 for other critical tasks and allow more efficient use of the VOXL 2 Mini's available UART resources.
    Thank you for considering this request. I look forward to your response and any guidance on potential workarounds or a timeline for implementing QURT compatibility for the OSD program.
  • VOXL 2 Mini & VOXL Mini 4-in-1 ESC Configuration for PWM Motor Control
    JP DroneJ JP Drone
    @Alex-Kushleyev
    I try reducing the pulse next.
    We use ArduPilot with an external flight controller.
    It would be nice to use the ESC UART protocol directly from the FC.
    Having ArduPilot work on the VOXL 2 mini would be even better.
    JP DroneJ JP Drone
    We are planning to fly only in PWM.
    Can PWM based control always be enabled as we want to avoid crashing due to the PWM to be disabled in flight?
    if there is any valid packets received by the ESC via UART, the pwm input interface is disabled until the ESC is rebooted. This should not happen unless you are actually communicating with the ESC via UART. This is done to avoid any possible interference between UART-based control and PWM-based control while in flight. UART protocol is still fully functional.
    Also, the flight is PWM based control, but I would like to get the ESC telemetry (RPM, voltage and current) via UART.
    Could you make it possible?
    JP DroneJ JP Drone
    @Alex-Kushleyev Thank you very much.
    I was able to set the parameter for ID 3 from the information you provided.
    And, I also confirmed that the motor spins via PWM by motor tests.
    However, after the motor test was completed, some motors continued to spin even after the FC set the PWM to 1000.
    Some motors will stop rotating once the motor test is complete.
    I don't know if this is a parameter issue or an ESC firmware issue.
    I modified min_rpm and min_pwm, but did not solve the problem.
    <EscParameters>
      <IdParams>
        <param name="id"              value="127"/>  <!-- 0-7 .. 127 means use hardware ID pins to read ID-->
        <param name="dir"             value="2"/>    <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based -->
      </IdParams>
      <UartParams>
        <param name="protocol_version" value="2"/>          <!-- reserved for future use -->
        <param name="input_mode"       value="0"/>          <!-- reserved for future use -->
        <param name="baud_rate"        value="2000000"/>     <!-- communication bit rate -->
        <param name="char_timeout_ns"  value="0"/>          <!-- not used -->
        <param name="cmd_timeout_ns"   value="100000000"/>  <!-- timeout for incoming commands before ESC will stop the motor -->
      </UartParams>
      <TuneParams>
        <param name="pwm_frequency"       value="48000"/>  <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now -->
        <param name="vbat_nominal_mv"     value="14800"/>  <!-- used for sanity checking and limiting of voltage-dependent funcions -->
        <param name="num_cycles_per_rev"  value="7"/>      <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm -->
        <param name="min_rpm"             value="500"/>   <!-- minimum RPM that will be attempted, otherwise capped -->
        <param name="max_rpm"             value="29344"/>  <!-- maximum RPM that will be attempted, otherwise capped -->
        <param name="min_pwm"             value="30"/>     <!-- cap for minimum power to be ever applied. max is 999 -->
        <param name="max_pwm"             value="999"/>    <!-- cap for maximum power to be ever applied. max is 999 -->
        <param name="pwm_vs_rpm_curve_a0" value="0"/>  <!-- this is actually motor_voltage vs rpm curve.. using legacy naming -->
        <param name="pwm_vs_rpm_curve_a1" value="0"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 -->
        <param name="pwm_vs_rpm_curve_a2" value="0"/>
        <param name="kp"                  value="250"/>    <!-- RPM controller proportional gain -->
        <param name="ki"                  value="30"/>     <!-- RPM controller proportional gain -->
        <param name="max_kpe"             value="300"/>    <!-- maximum proportional erorr term (max is 999) -->
        <param name="max_kie"             value="100"/>    <!-- maximum integral error term (max is 999) -->
        <param name="max_rpm_delta"       value="0"/>    <!-- cap for maximum rpm error used in RPM controller -->
        <param name="spinup_type"         value="1"/>      <!-- 0: traditional, 1: sinusoidal -->
        <param name="spinup_power"        value="70"/>     <!-- power used to during spin-up procedure -->
        <param name="latch_power"         value="70"/>     <!-- power used during latching stage of spin-up (out of 999)-->
        <param name="spinup_power_ramp"   value="8"/>      <!-- it will take ( 4096 / (spinup_power_ramp*10000) ) seconds to ramp sinusoidal start-up power from 0 to spinup_power -->
        <param name="spinup_rpm_target"   value="1000"/>   <!-- Desired RPM at the end of the sinusoidal spin-up procedure -->
        <param name="spinup_time_ms"      value="1000"/>   <!-- Duration of the sinusoidal spin-up procedure -->
        <param name="spinup_bemf_comp"    value="1"/>      <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure -->
        <param name="motor_kv"            value="2850 "/>    <!-- kV value of the motor. used in back-emf compensation during spin-up -->
        <param name="min_num_cross_for_closed_loop" value="50"/>  <!-- exit latching mode of fixed power after this number of zero crossings -->
        <param name="protection_stall_check_rpm" value="1000"/> <!-- if motor spins below this RPM, stall check will trigger and stop / restart the motor -->
        <param name="brake_to_stop"       value="0"/>             <!-- apply brake when stopping motor (or not) -->
        <param name="stall_timeout_ns"    value="20000000"/>      <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled -->
        <param name="require_reset_if_stalled"      value="0"/>   <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled -->
        <param name="tone_freqs"          value="[200, 215, 225, 250, 0,0,0,0, 0,0,0,0]"/> <!-- 200 is 2000Hz, max 255 -->
        <param name="tone_durations"      value="[10,  10,  10,  10,  0,0,0,0, 0,0,0,0]"/> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! -->
        <param name="tone_powers"         value="[60,  60,  60,  60,  0,0,0,0, 0,0,0,0]"/> <!-- max is 255 -->
        <param name="dt_threshold_ns"       value="150000"/>      <!-- during start up, ignore inter-commutation times less than this val, probably noise -->
        <param name="max_dt_ns"             value="2500000"/>     <!-- min and max values for time between two commutations. these are used as caps -->
        <param name="min_dt_ns"             value="10000"/>
        <param name="dt_bootstrap_ns"       value="2000000"/>     <!-- filter bootstrap value for commutation dt during start up -->
        <param name="spinup_stall_dt_ns"    value="6000000"/>     <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled -->
        <param name="spinup_stall_check_ns" value="30000000"/>    <!-- time after beginning of spinup to start checking for spinup stall -->
        <param name="alignment_time_ns"     value="0"/>           <!-- alignment time before spin-up -->
        <param name="timing_advance"        value="0"/>
        <param name="sense_advance"         value="0"/>
        <param name="demag_timing"          value="0"/>    <!-- unused -->
      </TuneParams>
    </EscParameters>
    JP DroneJ JP Drone
    @Alex-Kushleyev
    I updated to the new firmware.
    However, ESC ID 3 doesn't work now.
    ESC ID 3 is set as the fallback from this message.
    WARNING: 57600 baud rate is the fallback baud rate if ESC params are not valid
    I then attempted to rewrite the parameter using this command, but it failed.
    ./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml --device /dev/slpi-uart-2 --baud-rate 57600
    In light of this situation, could you advise if it's possible to fix the configuration issue with ESC ID 3 for proper functionality?
    Logs:
    Here is the log of the firmware update, and it's successful.
    voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-scan.py
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.6
    VOXL Platform: M0104
    Received standard error event 2
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware
    INFO: ESC Information:
    INFO: ---------------------
            Board      : version 40: ModalAi 4-in-1 ESC (M0129-3)
            UID        : 0x2039333557555304003D0036
            Firmware   : version   37, hash a0ca0a86
            Bootloader : version  184, hash 10bf24c8
            UID        : 0x2039333557555304003D0032
            UID        : 0x2039333557555304003D0034
            UID        : 0x2039333557555304003D0038
    voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-upload-firmware-all.sh
    Usage:
    - Autodetect board and upload latest firmware to all ESCs:
    - Autodetect board and upload latest firmware to a single ESC ID <esc_id>:
        ./voxl-esc-upload-firmware-all.sh <esc_id>
    Detecting ESCs...
    [INFO] M0129-3 detected
    ESC Firmware:  modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
    Flashing all ESCs
    [GCC 8.4.0]
    INFO: Firmware file name : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
    INFO: Firmware file size : 23024 bytes
    INFO: ESC(s) detected: [0, 1, 2, 3]
    INFO: Sending reset command to ESC ID 0
    Updated baud rate to 230400
    INFO: Installing firmware to ESC ID 0 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
            Progress: 100% [##################################################]
    INFO: Firmware successfully updated for ESC id 0
    [GCC 8.4.0]
    INFO: ESC(s) detected: [1, 2, 3]
    INFO: Sending reset command to ESC ID 1
    INFO: Installing firmware to ESC ID 1 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
    INFO: Firmware successfully updated for ESC id 1
    [GCC 8.4.0]
    INFO: ESC(s) detected: [2, 3]
    INFO: Sending reset command to ESC ID 2
    INFO: Installing firmware to ESC ID 2 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
    INFO: Firmware successfully updated for ESC id 2
    [GCC 8.4.0]
    INFO: ESC(s) detected: [3]
    INFO: Sending reset command to ESC ID 3
    INFO: Installing firmware to ESC ID 3 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin
    INFO: Firmware successfully updated for ESC id 3
    And then I uploaded the parameters. It seems to write IDs 0, 1, and 2, but it fails for ID 3.
    voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml
    [GCC 8.4.0]
    INFO: Params file name : ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml
    INFO: Params file size : 7419 bytes
    INFO: ESCs detected:
    ID: 1, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3)
    ID: 2, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3)
    INFO: Loading XML config file...
    INFO: Uploading params for ESC ID 255...
    -- board config
    -- id config
    -- uart config
    -- tune config
        DONE
    INFO: Resetting ESCs...
        DONE
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000
    INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
    ERROR: No ESC(s) detected
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600
    ID: 0, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3)
    -- board config
    -- id config
    -- uart config
    -- tune config
        DONE
        DONE
    INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
    ERROR:   voxl_uart_read_bytes: Bus '12' is not initialized
    Scan command says ID 3 is fallback mode.
    voxl2-mini:/$ voxl-esc
    Starting Wizard
    What do you want to do?
    1) scan              3) spin              5) upload_params
    2) detect            4) upgrade_firmware
    #? 1
    enabling bridge
    bridge enabled
    [GCC 8.4.0]
            Firmware   : version   39, hash eef79926
    WARNING: No ESC(s) detected
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600, protocol: firmware
    WARNING: Please verify params using voxl-esc-verify-params.py
    WARNING: Motors will not spin unless valid params are present
    Found ESCs:
    id: 0, port: /dev/slpi-uart-2, baud rate: 2000000
    id: 1, port: /dev/slpi-uart-2, baud rate: 2000000
    id: 2, port: /dev/slpi-uart-2, baud rate: 2000000
    id: 3, port: /dev/slpi-uart-2, baud rate: 57600
    successfully pinged ESCs
    disabling bridge
    bridge disabled
    DONE
    <EscParameters>
      <IdParams>
      </IdParams>
      <UartParams>
      </UartParams>
      <TuneParams>
        <param name="min_rpm"             value="4000"/>   <!-- minimum RPM that will be attempted, otherwise capped -->
        <param name="min_pwm"             value="70"/>     <!-- cap for minimum power to be ever applied. max is 999 -->
        <param name="kp"                  value="0"/>    <!-- RPM controller proportional gain -->
        <param name="ki"                  value="0"/>     <!-- RPM controller proportional gain -->
        <param name="max_kpe"             value="0"/>    <!-- maximum proportional erorr term (max is 999) -->
        <param name="max_kie"             value="0"/>    <!-- maximum integral error term (max is 999) -->
        <param name="spinup_type"         value="0"/>      <!-- 0: traditional, 1: sinusoidal -->
        <param name="latch_power"         value="80"/>     <!-- power used during latching stage of spin-up (out of 999)-->
        <param name="spinup_bemf_comp"    value="0"/>      <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure -->
        <param name="min_num_cross_for_closed_loop" value="100"/>  <!-- exit latching mode of fixed power after this number of zero crossings -->
      </TuneParams>
    </EscParameters>
    JP DroneJ JP Drone
    @Alex-Kushleyev Thank you! I will check it works.
    JP DroneJ JP Drone
    @Alex-Kushleyev
    Thank you for your response. I understand your availability and appreciate your willingness to assist. I'll await your firmware update next Wednesday.
    I attempted to upgrade the ESC firmware before, but encountered an error:
    ERROR: Bus 12 is already initialized. To reinitialize, please close it first.
    Besides enabling bridge (disabling voxl-px4), are there any other services I should stop or additional steps I should take to free up the serial bus before attempting the ESC firmware upgrade?
    $ voxl-esc
    Starting Wizard
    #? 4
    enabling bridge
    bridge enabled
    [INFO] Setting CPU to performance mode
    [INFO] Scanning for ESC...
    [INFO] has for most recent firmware: eb6fb500
    [INFO] Expected ESC firmware info:
            Firmware: modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin
            Firmware hash: eb6fb500
    [INFO] Number of ESCs with correct FW: 0
    [INFO] 0 of the ESCs do not have the current firmware
    [INFO] Uploading current ESC firmware...
    [GCC 8.4.0]
    INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin
    INFO: Firmware file size : 22672 bytes
    WARNING: Unable to detect ESCs in order to reset them..:
    'NoneType' object has no attribute 'get_detected'
    WARGING: Attempting to continue
    INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin
    ERROR: An error occured during the write process.
    [ERROR] failed to upload firmware to ESC0
    disabling bridge
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
