VOXL 2 Mini & VOXL Mini 4-in-1 ESC Configuration for PWM Motor Control
Thank you for reply.
We understood the circumstances in which RPM control is recommended.
However, I would like to continue testing PWM control as well.Yes, we are connecting the PWM input to A0 - A3 and try to using with 1-2ms pulse.
Please let me know when it's enabled.@JP-Drone , I can help you with this. However, I am currently out of office until next Wednesday and I can prepare the firmware for you at that time. I hope it is not a big issue for you. Without the firmware update, there is no way to make it work.
Thank you for your response. I understand your availability and appreciate your willingness to assist. I'll await your firmware update next Wednesday.I attempted to upgrade the ESC firmware before, but encountered an error:
ERROR: Bus 12 is already initialized. To reinitialize, please close it first.Besides enabling bridge (disabling voxl-px4), are there any other services I should stop or additional steps I should take to free up the serial bus before attempting the ESC firmware upgrade?
$ voxl-esc Starting Wizard What do you want to do? 1) scan 3) spin 5) upload_params 2) detect 4) upgrade_firmware #? 4 enabling bridge bridge enabled [INFO] Setting CPU to performance mode [INFO] Scanning for ESC... Received standard error event 2 [INFO] M0129-3 detected [INFO] has for most recent firmware: eb6fb500 [INFO] Expected ESC firmware info: Firmware: modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin Firmware hash: eb6fb500 [INFO] Number of ESCs with correct FW: 0 [INFO] 0 of the ESCs do not have the current firmware [INFO] Uploading current ESC firmware... Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin INFO: Firmware file size : 22672 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 WARNING: Unable to detect ESCs in order to reset them..: 'NoneType' object has no attribute 'get_detected' WARGING: Attempting to continue ERROR: Bus 12 is already initialized. To reinitialize, please close it first. Updated baud rate to 230400 INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin ERROR: An error occured during the write process. [ERROR] failed to upload firmware to ESC0 disabling bridge bridge disabled EXITING VOXL-ESC WITH ERROR -
$ voxl-esc Starting Wizard What do you want to do? 1) scan 3) spin 5) upload_params 2) detect 4) upgrade_firmware #? 4 enabling bridge bridge enabled [INFO] Setting CPU to performance mode [INFO] Scanning for ESC... Received standard error event 2 [INFO] M0129-3 detected [INFO] has for most recent firmware: eb6fb500 [INFO] Expected ESC firmware info: Firmware: modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin Firmware hash: eb6fb500 [INFO] Number of ESCs with correct FW: 0 [INFO] 0 of the ESCs do not have the current firmware [INFO] Uploading current ESC firmware... Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin INFO: Firmware file size : 22672 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 WARNING: Unable to detect ESCs in order to reset them..: 'NoneType' object has no attribute 'get_detected' WARGING: Attempting to continue ERROR: Bus 12 is already initialized. To reinitialize, please close it first. Updated baud rate to 230400 INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0129_3_v0_39_RC10_eb6fb500.bin ERROR: An error occured during the write process. [ERROR] failed to upload firmware to ESC0 disabling bridge bridge disabled EXITING VOXL-ESC WITH ERROR@JP-Drone, i am not sure why this is happening - does it happen every time you try to update the firmware this way?
Can you please try another way:
get the latest dev branch of voxl-esc to voxl2 mini:
git clone https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc -b dev /home/root/voxl-escthen go to
/home/root/voxl-esc/voxl-esc-toolsand try:stop px4:
systemctl stop voxl-px4scan to make sure all 4 ESC channels are detected:
./voxl-esc-scan.pyThen update firmware and see if that is successful (it should re-upload the current firmware, since it seems that you do have the latest installed already)
./voxl-esc-upload-firmware-all.sh -
./voxl-esc-upload-firmware-all.shHello @JP-Drone ,
I have added firmware that supports pwm inputs using the aux IO pins. Mini ESC (M0129) is one of the boards that does support this feature (using the inputs labeled A0,A1,A2,A3, also make sure to connect GND between the flight controller and ESC).
You can find the firmware located here https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/enable-pwm-input-in-firmware/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin - you can install it using the standard firmware flashing procedure. Note that the firmware for other ESCs (M0049, M0117, M0134) in this location also supports PWM input (except for M0138 ESC, which has no pwm input connector / pads).
Some notes about this functionality:
- the acceptable pulse is 1000-2000us
- suggested minimum for use in flight controller is 1050 when armed, 950 when disarmed
- 2000us is mapped to 100% power
- the pwm input signal is mapped to % output power, not RPM
- if there is any valid packets received by the ESC via UART, the pwm input interface is disabled until the ESC is rebooted. This should not happen unless you are actually communicating with the ESC via UART. This is done to avoid any possible interference between UART-based control and PWM-based control while in flight. UART protocol is still fully functional.
- there is no filtering on of the PWM input signal (sometimes done using a Resistor + Capacitor circuit to reduce signal noise). If wires between flight controller and ESC are long, the input signal could be noisy.
Even if you don't use UART for sending real-time commands, I still suggest that you update the ESC parameters for your motor / propeller / battery and spin-up parameters for smooth sinusoidal spin-up. You can start with the following param file and update the following :https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/enable-pwm-input-in-firmware/voxl-esc-params/boards/esc_params_generic_m0129.xml
- vbat_nominal_mv
- num_cycles_per_rev
- pwm_vs_rpm_curve_a0, a1, a2 (set to zero)
- max_rpm_delta (set to zero)
- protection_stall_check_rpm (set to min_rpm/2 or min_rpm/3 - this will trigger stall protection and stop motor if motor is spinning slower than this rpm)
if you want to use smooth sinusoidal spinup, update the following ( you could choose not to use sinusoidal spinup as well)
- spinup_type (set to 1)
- motor_kv
- spinup_bemf_comp (set to 1)
- spinup_rpm_target and spinup_time_ms (according to desired)
- tune spinup_power (increase from 70 to 80, 90, or 100 if the motor has trouble spinning up), but avoid setting too high, otherwise motor will draw higher current during spinup (not very critical)
As I mentioned before, this feature is not thoroughly tested, but it does work. Please test with caution and build up your confidence using bench testing before you start flying. Let me know if you have any further questions.
Hello @JP-Drone ,
- vbat_nominal_mv
- motor_kv
@Alex-Kushleyev Thank you! I will check it works.
Hello @JP-Drone ,
- vbat_nominal_mv
- motor_kv
I updated to the new firmware.
However, ESC ID 3 doesn't work now.ESC ID 3 is set as the fallback from this message.
WARNING: 57600 baud rate is the fallback baud rate if ESC params are not validI then attempted to rewrite the parameter using this command, but it failed.
./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml --device /dev/slpi-uart-2 --baud-rate 57600In light of this situation, could you advise if it's possible to fix the configuration issue with ESC ID 3 for proper functionality?
Logs:
Here is the log of the firmware update, and it's successful.
voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-scan.py Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware INFO: ESC Information: INFO: --------------------- ID : 0 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0036 Firmware : version 37, hash a0ca0a86 Bootloader : version 184, hash 10bf24c8 ID : 1 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0032 Firmware : version 37, hash a0ca0a86 Bootloader : version 184, hash 10bf24c8 ID : 2 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0034 Firmware : version 37, hash a0ca0a86 Bootloader : version 184, hash 10bf24c8 ID : 3 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0038 Firmware : version 37, hash a0ca0a86 Bootloader : version 184, hash 10bf24c8 --------------------- voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-upload-firmware-all.sh Usage: - Autodetect board and upload latest firmware to all ESCs: ./voxl-esc-upload-firmware-all.sh - Autodetect board and upload latest firmware to a single ESC ID <esc_id>: ./voxl-esc-upload-firmware-all.sh <esc_id> Detecting ESCs... Received standard error event 2 [INFO] M0129-3 detected ESC Firmware: modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin Flashing all ESCs Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin INFO: Firmware file size : 23024 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 INFO: ESC(s) detected: [0, 1, 2, 3] INFO: Sending reset command to ESC ID 0 Updated baud rate to 230400 INFO: Installing firmware to ESC ID 0 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin Progress: 100% [##################################################] INFO: Firmware successfully updated for ESC id 0 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin INFO: Firmware file size : 23024 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 INFO: ESC(s) detected: [1, 2, 3] INFO: Sending reset command to ESC ID 1 Updated baud rate to 230400 INFO: Installing firmware to ESC ID 1 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin Progress: 100% [##################################################] INFO: Firmware successfully updated for ESC id 1 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin INFO: Firmware file size : 23024 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 INFO: ESC(s) detected: [2, 3] INFO: Sending reset command to ESC ID 2 Updated baud rate to 230400 INFO: Installing firmware to ESC ID 2 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin Progress: 100% [##################################################] INFO: Firmware successfully updated for ESC id 2 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Firmware file name : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin INFO: Firmware file size : 23024 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 INFO: ESC(s) detected: [3] INFO: Sending reset command to ESC ID 3 Updated baud rate to 230400 INFO: Installing firmware to ESC ID 3 : /home/root/voxl-esc/voxl-esc-tools/firmware/modalai_esc_firmware_m0129_3_v0_39_RC13_eef79926.bin Progress: 100% [##################################################] INFO: Firmware successfully updated for ESC id 3And then I uploaded the parameters. It seems to write IDs 0, 1, and 2, but it fails for ID 3.
voxl2-mini:~/voxl-esc/voxl-esc-tools(enable-pwm-input-in-firmware)$ ./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 INFO: Params file name : ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml INFO: Params file size : 7419 bytes VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000 INFO: ESCs detected: INFO: --------------------- ID: 1, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3) ID: 2, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3) --------------------- INFO: Loading XML config file... INFO: Uploading params for ESC ID 255... -- board config -- id config -- uart config -- tune config DONE INFO: Resetting ESCs... DONE VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 ERROR: No ESC(s) detected VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 ERROR: No ESC(s) detected VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 ERROR: No ESC(s) detected VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600 INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600 INFO: ESCs detected: INFO: --------------------- ID: 0, SW: 39, HW: 40: ModalAi 4-in-1 ESC (M0129-3) --------------------- INFO: Loading XML config file... INFO: Uploading params for ESC ID 255... -- board config -- id config -- uart config -- tune config DONE INFO: Resetting ESCs... DONE VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 ERROR: voxl_uart_read_bytes: Bus '12' is not initialized Updated baud rate to 230400 ERROR: No ESC(s) detectedScan command says ID 3 is fallback mode.
voxl2-mini:/$ voxl-esc Starting Wizard What do you want to do? 1) scan 3) spin 5) upload_params 2) detect 4) upgrade_firmware #? 1 enabling bridge bridge enabled Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.6 VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Received standard error event 2 Sending initialization request INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware INFO: ESC Information: INFO: --------------------- ID : 0 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0036 Firmware : version 39, hash eef79926 Bootloader : version 184, hash 10bf24c8 ID : 1 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0032 Firmware : version 39, hash eef79926 Bootloader : version 184, hash 10bf24c8 ID : 2 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0034 Firmware : version 39, hash eef79926 Bootloader : version 184, hash 10bf24c8 --------------------- VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 WARNING: No ESC(s) detected VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 ERROR: voxl_uart_read_bytes: Bus '12' is not initialized Updated baud rate to 230400 WARNING: No ESC(s) detected VOXL Platform: M0104 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600 INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600, protocol: firmware INFO: ESC Information: INFO: --------------------- ID : 3 Board : version 40: ModalAi 4-in-1 ESC (M0129-3) UID : 0x2039333557555304003D0038 Firmware : version 39, hash eef79926 Bootloader : version 184, hash 10bf24c8 --------------------- WARNING: 57600 baud rate is the fallback baud rate if ESC params are not valid WARNING: Please verify params using voxl-esc-verify-params.py WARNING: Motors will not spin unless valid params are present --------------------- Found ESCs: id: 0, port: /dev/slpi-uart-2, baud rate: 2000000 id: 1, port: /dev/slpi-uart-2, baud rate: 2000000 id: 2, port: /dev/slpi-uart-2, baud rate: 2000000 id: 3, port: /dev/slpi-uart-2, baud rate: 57600 successfully pinged ESCs disabling bridge bridge disabled DONE./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml --device /dev/slpi-uart-2 --baud-rate 57600
<EscParameters> <IdParams> <param name="id" value="127"/> <!-- 0-7 .. 127 means use hardware ID pins to read ID--> <param name="dir" value="2"/> <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based --> </IdParams> <UartParams> <param name="protocol_version" value="2"/> <!-- reserved for future use --> <param name="input_mode" value="0"/> <!-- reserved for future use --> <param name="baud_rate" value="2000000"/> <!-- communication bit rate --> <param name="char_timeout_ns" value="0"/> <!-- not used --> <param name="cmd_timeout_ns" value="100000000"/> <!-- timeout for incoming commands before ESC will stop the motor --> </UartParams> <TuneParams> <param name="pwm_frequency" value="48000"/> <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now --> <param name="vbat_nominal_mv" value="14800"/> <!-- used for sanity checking and limiting of voltage-dependent funcions --> <param name="num_cycles_per_rev" value="7"/> <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm --> <param name="min_rpm" value="4000"/> <!-- minimum RPM that will be attempted, otherwise capped --> <param name="max_rpm" value="29344"/> <!-- maximum RPM that will be attempted, otherwise capped --> <param name="min_pwm" value="70"/> <!-- cap for minimum power to be ever applied. max is 999 --> <param name="max_pwm" value="999"/> <!-- cap for maximum power to be ever applied. max is 999 --> <param name="pwm_vs_rpm_curve_a0" value="0"/> <!-- this is actually motor_voltage vs rpm curve.. using legacy naming --> <param name="pwm_vs_rpm_curve_a1" value="0"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 --> <param name="pwm_vs_rpm_curve_a2" value="0"/> <param name="kp" value="0"/> <!-- RPM controller proportional gain --> <param name="ki" value="0"/> <!-- RPM controller proportional gain --> <param name="max_kpe" value="0"/> <!-- maximum proportional erorr term (max is 999) --> <param name="max_kie" value="0"/> <!-- maximum integral error term (max is 999) --> <param name="max_rpm_delta" value="0"/> <!-- cap for maximum rpm error used in RPM controller --> <param name="spinup_type" value="0"/> <!-- 0: traditional, 1: sinusoidal --> <param name="spinup_power" value="70"/> <!-- power used to during spin-up procedure --> <param name="latch_power" value="80"/> <!-- power used during latching stage of spin-up (out of 999)--> <param name="spinup_power_ramp" value="8"/> <!-- it will take ( 4096 / (spinup_power_ramp*10000) ) seconds to ramp sinusoidal start-up power from 0 to spinup_power --> <param name="spinup_rpm_target" value="1000"/> <!-- Desired RPM at the end of the sinusoidal spin-up procedure --> <param name="spinup_time_ms" value="1000"/> <!-- Duration of the sinusoidal spin-up procedure --> <param name="spinup_bemf_comp" value="0"/> <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure --> <param name="motor_kv" value="2850 "/> <!-- kV value of the motor. used in back-emf compensation during spin-up --> <param name="min_num_cross_for_closed_loop" value="100"/> <!-- exit latching mode of fixed power after this number of zero crossings --> <param name="protection_stall_check_rpm" value="1000"/> <!-- if motor spins below this RPM, stall check will trigger and stop / restart the motor --> <param name="brake_to_stop" value="0"/> <!-- apply brake when stopping motor (or not) --> <param name="stall_timeout_ns" value="20000000"/> <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="require_reset_if_stalled" value="0"/> <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled --> <param name="tone_freqs" value="[200, 215, 225, 250, 0,0,0,0, 0,0,0,0]"/> <!-- 200 is 2000Hz, max 255 --> <param name="tone_durations" value="[10, 10, 10, 10, 0,0,0,0, 0,0,0,0]"/> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! --> <param name="tone_powers" value="[60, 60, 60, 60, 0,0,0,0, 0,0,0,0]"/> <!-- max is 255 --> <param name="dt_threshold_ns" value="150000"/> <!-- during start up, ignore inter-commutation times less than this val, probably noise --> <param name="max_dt_ns" value="2500000"/> <!-- min and max values for time between two commutations. these are used as caps --> <param name="min_dt_ns" value="10000"/> <param name="dt_bootstrap_ns" value="2000000"/> <!-- filter bootstrap value for commutation dt during start up --> <param name="spinup_stall_dt_ns" value="6000000"/> <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="spinup_stall_check_ns" value="30000000"/> <!-- time after beginning of spinup to start checking for spinup stall --> <param name="alignment_time_ns" value="0"/> <!-- alignment time before spin-up --> <param name="timing_advance" value="0"/> <param name="sense_advance" value="0"/> <param name="demag_timing" value="0"/> <!-- unused --> </TuneParams> </EscParameters> -
Logs:
<EscParameters> <IdParams> <param name="id" value="127"/> <!-- 0-7 .. 127 means use hardware ID pins to read ID--> <param name="dir" value="2"/> <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based --> </IdParams> <UartParams> <param name="protocol_version" value="2"/> <!-- reserved for future use --> <param name="input_mode" value="0"/> <!-- reserved for future use --> <param name="baud_rate" value="2000000"/> <!-- communication bit rate --> <param name="char_timeout_ns" value="0"/> <!-- not used --> <param name="cmd_timeout_ns" value="100000000"/> <!-- timeout for incoming commands before ESC will stop the motor --> </UartParams> <TuneParams> <param name="pwm_frequency" value="48000"/> <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now --> <param name="vbat_nominal_mv" value="14800"/> <!-- used for sanity checking and limiting of voltage-dependent funcions --> <param name="num_cycles_per_rev" value="7"/> <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm --> <param name="min_rpm" value="4000"/> <!-- minimum RPM that will be attempted, otherwise capped --> <param name="max_rpm" value="29344"/> <!-- maximum RPM that will be attempted, otherwise capped --> <param name="min_pwm" value="70"/> <!-- cap for minimum power to be ever applied. max is 999 --> <param name="max_pwm" value="999"/> <!-- cap for maximum power to be ever applied. max is 999 --> <param name="pwm_vs_rpm_curve_a0" value="0"/> <!-- this is actually motor_voltage vs rpm curve.. using legacy naming --> <param name="pwm_vs_rpm_curve_a1" value="0"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 --> <param name="pwm_vs_rpm_curve_a2" value="0"/> <param name="kp" value="0"/> <!-- RPM controller proportional gain --> <param name="ki" value="0"/> <!-- RPM controller proportional gain --> <param name="max_kpe" value="0"/> <!-- maximum proportional erorr term (max is 999) --> <param name="max_kie" value="0"/> <!-- maximum integral error term (max is 999) --> <param name="max_rpm_delta" value="0"/> <!-- cap for maximum rpm error used in RPM controller --> <param name="spinup_type" value="0"/> <!-- 0: traditional, 1: sinusoidal --> <param name="spinup_power" value="70"/> <!-- power used to during spin-up procedure --> <param name="latch_power" value="80"/> <!-- power used during latching stage of spin-up (out of 999)--> <param name="spinup_power_ramp" value="8"/> <!-- it will take ( 4096 / (spinup_power_ramp*10000) ) seconds to ramp sinusoidal start-up power from 0 to spinup_power --> <param name="spinup_rpm_target" value="1000"/> <!-- Desired RPM at the end of the sinusoidal spin-up procedure --> <param name="spinup_time_ms" value="1000"/> <!-- Duration of the sinusoidal spin-up procedure --> <param name="spinup_bemf_comp" value="0"/> <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure --> <param name="motor_kv" value="2850 "/> <!-- kV value of the motor. used in back-emf compensation during spin-up --> <param name="min_num_cross_for_closed_loop" value="100"/> <!-- exit latching mode of fixed power after this number of zero crossings --> <param name="protection_stall_check_rpm" value="1000"/> <!-- if motor spins below this RPM, stall check will trigger and stop / restart the motor --> <param name="brake_to_stop" value="0"/> <!-- apply brake when stopping motor (or not) --> <param name="stall_timeout_ns" value="20000000"/> <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="require_reset_if_stalled" value="0"/> <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled --> <param name="tone_freqs" value="[200, 215, 225, 250, 0,0,0,0, 0,0,0,0]"/> <!-- 200 is 2000Hz, max 255 --> <param name="tone_durations" value="[10, 10, 10, 10, 0,0,0,0, 0,0,0,0]"/> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! --> <param name="tone_powers" value="[60, 60, 60, 60, 0,0,0,0, 0,0,0,0]"/> <!-- max is 255 --> <param name="dt_threshold_ns" value="150000"/> <!-- during start up, ignore inter-commutation times less than this val, probably noise --> <param name="max_dt_ns" value="2500000"/> <!-- min and max values for time between two commutations. these are used as caps --> <param name="min_dt_ns" value="10000"/> <param name="dt_bootstrap_ns" value="2000000"/> <!-- filter bootstrap value for commutation dt during start up --> <param name="spinup_stall_dt_ns" value="6000000"/> <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="spinup_stall_check_ns" value="30000000"/> <!-- time after beginning of spinup to start checking for spinup stall --> <param name="alignment_time_ns" value="0"/> <!-- alignment time before spin-up --> <param name="timing_advance" value="0"/> <param name="sense_advance" value="0"/> <param name="demag_timing" value="0"/> <!-- unused --> </TuneParams> </EscParameters>@JP-Drone , sorry this happened to you. Sometimes from updating from much older firmware, this happens.
Can you please try the command you already tried with a small modification. try it several times if ti does not work:
./voxl-esc-upload-params.py --params-file ../voxl-esc-params/boards/esc_params_generic_m0129_pwm.xml --device /dev/slpi-uart-2 --baud-rate 57600 --id 3Also maybe try to power cycle voxl2 mini and the ESC and try the above command again.
also please try
voxl-set-cpu-mode perfto set cpu to perf mode to avoid long sleeps, maybe that causes thevoxl-esctool to time out. -
also please try
voxl-set-cpu-mode perfto set cpu to perf mode to avoid long sleeps, maybe that causes thevoxl-esctool to time out.Additionally, do you have a USB to serial adapter that you could use to connect to the ESC directly from a linux PC? Then you could run the
voxl-esctools on the PC and that is a good backup option if running the tools on VOXL2 is not working reliably. We are working to make this more reliable, but using a PC for ESC configuration is a good option as well. -
voxl-esctools on the PC and that is a good backup option if running the tools on VOXL2 is not working reliably. We are working to make this more reliable, but using a PC for ESC configuration is a good option as well.@Alex-Kushleyev Thank you very much.
I was able to set the parameter for ID 3 from the information you provided.And, I also confirmed that the motor spins via PWM by motor tests.
However, after the motor test was completed, some motors continued to spin even after the FC set the PWM to 1000.
Some motors will stop rotating once the motor test is complete.
I don't know if this is a parameter issue or an ESC firmware issue.
I modified min_rpm and min_pwm, but did not solve the problem.<EscParameters> <IdParams> <param name="id" value="127"/> <!-- 0-7 .. 127 means use hardware ID pins to read ID--> <param name="dir" value="2"/> <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based --> </IdParams> <UartParams> <param name="protocol_version" value="2"/> <!-- reserved for future use --> <param name="input_mode" value="0"/> <!-- reserved for future use --> <param name="baud_rate" value="2000000"/> <!-- communication bit rate --> <param name="char_timeout_ns" value="0"/> <!-- not used --> <param name="cmd_timeout_ns" value="100000000"/> <!-- timeout for incoming commands before ESC will stop the motor --> </UartParams> <TuneParams> <param name="pwm_frequency" value="48000"/> <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now --> <param name="vbat_nominal_mv" value="14800"/> <!-- used for sanity checking and limiting of voltage-dependent funcions --> <param name="num_cycles_per_rev" value="7"/> <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm --> <param name="min_rpm" value="500"/> <!-- minimum RPM that will be attempted, otherwise capped --> <param name="max_rpm" value="29344"/> <!-- maximum RPM that will be attempted, otherwise capped --> <param name="min_pwm" value="30"/> <!-- cap for minimum power to be ever applied. max is 999 --> <param name="max_pwm" value="999"/> <!-- cap for maximum power to be ever applied. max is 999 --> <param name="pwm_vs_rpm_curve_a0" value="0"/> <!-- this is actually motor_voltage vs rpm curve.. using legacy naming --> <param name="pwm_vs_rpm_curve_a1" value="0"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 --> <param name="pwm_vs_rpm_curve_a2" value="0"/> <param name="kp" value="250"/> <!-- RPM controller proportional gain --> <param name="ki" value="30"/> <!-- RPM controller proportional gain --> <param name="max_kpe" value="300"/> <!-- maximum proportional erorr term (max is 999) --> <param name="max_kie" value="100"/> <!-- maximum integral error term (max is 999) --> <param name="max_rpm_delta" value="0"/> <!-- cap for maximum rpm error used in RPM controller --> <param name="spinup_type" value="1"/> <!-- 0: traditional, 1: sinusoidal --> <param name="spinup_power" value="70"/> <!-- power used to during spin-up procedure --> <param name="latch_power" value="70"/> <!-- power used during latching stage of spin-up (out of 999)--> <param name="spinup_power_ramp" value="8"/> <!-- it will take ( 4096 / (spinup_power_ramp*10000) ) seconds to ramp sinusoidal start-up power from 0 to spinup_power --> <param name="spinup_rpm_target" value="1000"/> <!-- Desired RPM at the end of the sinusoidal spin-up procedure --> <param name="spinup_time_ms" value="1000"/> <!-- Duration of the sinusoidal spin-up procedure --> <param name="spinup_bemf_comp" value="1"/> <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure --> <param name="motor_kv" value="2850 "/> <!-- kV value of the motor. used in back-emf compensation during spin-up --> <param name="min_num_cross_for_closed_loop" value="50"/> <!-- exit latching mode of fixed power after this number of zero crossings --> <param name="protection_stall_check_rpm" value="1000"/> <!-- if motor spins below this RPM, stall check will trigger and stop / restart the motor --> <param name="brake_to_stop" value="0"/> <!-- apply brake when stopping motor (or not) --> <param name="stall_timeout_ns" value="20000000"/> <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="require_reset_if_stalled" value="0"/> <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled --> <param name="tone_freqs" value="[200, 215, 225, 250, 0,0,0,0, 0,0,0,0]"/> <!-- 200 is 2000Hz, max 255 --> <param name="tone_durations" value="[10, 10, 10, 10, 0,0,0,0, 0,0,0,0]"/> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! --> <param name="tone_powers" value="[60, 60, 60, 60, 0,0,0,0, 0,0,0,0]"/> <!-- max is 255 --> <param name="dt_threshold_ns" value="150000"/> <!-- during start up, ignore inter-commutation times less than this val, probably noise --> <param name="max_dt_ns" value="2500000"/> <!-- min and max values for time between two commutations. these are used as caps --> <param name="min_dt_ns" value="10000"/> <param name="dt_bootstrap_ns" value="2000000"/> <!-- filter bootstrap value for commutation dt during start up --> <param name="spinup_stall_dt_ns" value="6000000"/> <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="spinup_stall_check_ns" value="30000000"/> <!-- time after beginning of spinup to start checking for spinup stall --> <param name="alignment_time_ns" value="0"/> <!-- alignment time before spin-up --> <param name="timing_advance" value="0"/> <param name="sense_advance" value="0"/> <param name="demag_timing" value="0"/> <!-- unused --> </TuneParams> </EscParameters> -
I modified min_rpm and min_pwm, but did not solve the problem.<EscParameters> <IdParams> <param name="id" value="127"/> <!-- 0-7 .. 127 means use hardware ID pins to read ID--> <param name="dir" value="2"/> <!-- 0=fwd, 1=rev, 2=fwd id-based, 3=rev id-based --> </IdParams> <UartParams> <param name="protocol_version" value="2"/> <!-- reserved for future use --> <param name="input_mode" value="0"/> <!-- reserved for future use --> <param name="baud_rate" value="2000000"/> <!-- communication bit rate --> <param name="char_timeout_ns" value="0"/> <!-- not used --> <param name="cmd_timeout_ns" value="100000000"/> <!-- timeout for incoming commands before ESC will stop the motor --> </UartParams> <TuneParams> <param name="pwm_frequency" value="48000"/> <!-- switching freqency of PWM signal going to motors. 24Khz and 48Khz are only options for now --> <param name="vbat_nominal_mv" value="14800"/> <!-- used for sanity checking and limiting of voltage-dependent funcions --> <param name="num_cycles_per_rev" value="7"/> <!-- number of pole pairs in the motor. used for converting electrical frequency to mechanical rpm --> <param name="min_rpm" value="500"/> <!-- minimum RPM that will be attempted, otherwise capped --> <param name="max_rpm" value="29344"/> <!-- maximum RPM that will be attempted, otherwise capped --> <param name="min_pwm" value="30"/> <!-- cap for minimum power to be ever applied. max is 999 --> <param name="max_pwm" value="999"/> <!-- cap for maximum power to be ever applied. max is 999 --> <param name="pwm_vs_rpm_curve_a0" value="0"/> <!-- this is actually motor_voltage vs rpm curve.. using legacy naming --> <param name="pwm_vs_rpm_curve_a1" value="0"/> <!-- Emax RS1306 3300KV with tri-blade 3x3x3 --> <param name="pwm_vs_rpm_curve_a2" value="0"/> <param name="kp" value="250"/> <!-- RPM controller proportional gain --> <param name="ki" value="30"/> <!-- RPM controller proportional gain --> <param name="max_kpe" value="300"/> <!-- maximum proportional erorr term (max is 999) --> <param name="max_kie" value="100"/> <!-- maximum integral error term (max is 999) --> <param name="max_rpm_delta" value="0"/> <!-- cap for maximum rpm error used in RPM controller --> <param name="spinup_type" value="1"/> <!-- 0: traditional, 1: sinusoidal --> <param name="spinup_power" value="70"/> <!-- power used to during spin-up procedure --> <param name="latch_power" value="70"/> <!-- power used during latching stage of spin-up (out of 999)--> <param name="spinup_power_ramp" value="8"/> <!-- it will take ( 4096 / (spinup_power_ramp*10000) ) seconds to ramp sinusoidal start-up power from 0 to spinup_power --> <param name="spinup_rpm_target" value="1000"/> <!-- Desired RPM at the end of the sinusoidal spin-up procedure --> <param name="spinup_time_ms" value="1000"/> <!-- Duration of the sinusoidal spin-up procedure --> <param name="spinup_bemf_comp" value="1"/> <!-- 0: disable, 1:enable back-emf compensation in sinusoidal spin-up procedure --> <param name="motor_kv" value="2850 "/> <!-- kV value of the motor. used in back-emf compensation during spin-up --> <param name="min_num_cross_for_closed_loop" value="50"/> <!-- exit latching mode of fixed power after this number of zero crossings --> <param name="protection_stall_check_rpm" value="1000"/> <!-- if motor spins below this RPM, stall check will trigger and stop / restart the motor --> <param name="brake_to_stop" value="0"/> <!-- apply brake when stopping motor (or not) --> <param name="stall_timeout_ns" value="20000000"/> <!-- after spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="require_reset_if_stalled" value="0"/> <!-- require sending an array of zero commands to reset before next spin-up, if motor stalled --> <param name="tone_freqs" value="[200, 215, 225, 250, 0,0,0,0, 0,0,0,0]"/> <!-- 200 is 2000Hz, max 255 --> <param name="tone_durations" value="[10, 10, 10, 10, 0,0,0,0, 0,0,0,0]"/> <!-- duration of each tone in units of 10 milli-seconds. Poor naming!!! --> <param name="tone_powers" value="[60, 60, 60, 60, 0,0,0,0, 0,0,0,0]"/> <!-- max is 255 --> <param name="dt_threshold_ns" value="150000"/> <!-- during start up, ignore inter-commutation times less than this val, probably noise --> <param name="max_dt_ns" value="2500000"/> <!-- min and max values for time between two commutations. these are used as caps --> <param name="min_dt_ns" value="10000"/> <param name="dt_bootstrap_ns" value="2000000"/> <!-- filter bootstrap value for commutation dt during start up --> <param name="spinup_stall_dt_ns" value="6000000"/> <!-- during spin-up, if no zero crossing is not detected for this amount of time, motor is considered stalled --> <param name="spinup_stall_check_ns" value="30000000"/> <!-- time after beginning of spinup to start checking for spinup stall --> <param name="alignment_time_ns" value="0"/> <!-- alignment time before spin-up --> <param name="timing_advance" value="0"/> <param name="sense_advance" value="0"/> <param name="demag_timing" value="0"/> <!-- unused --> </TuneParams> </EscParameters>We are planning to fly only in PWM.
Can PWM based control always be enabled as we want to avoid crashing due to the PWM to be disabled in flight?if there is any valid packets received by the ESC via UART, the pwm input interface is disabled until the ESC is rebooted. This should not happen unless you are actually communicating with the ESC via UART. This is done to avoid any possible interference between UART-based control and PWM-based control while in flight. UART protocol is still fully functional.
Also, the flight is PWM based control, but I would like to get the ESC telemetry (RPM, voltage and current) via UART.
Could you make it possible? -
Could you make it possible?You should change your px4 params to send out pulse less than 1000us (900 or 950) when in disarmed mode or you can just stop sending the pulses. Please note that pwm calibration is not supported, it should not be needed.
Please do not change the pwm_min and max values, they are not for this purpose. These parameters limit the power that is applied to the motor, not the input pwm signal.
The pwm mode will not be disabled unless the esc receives a valid packet via uart (which includes correct checksum), which is virtually impossible if you do not actually have uart signals connected to flight controller.
Standard PWM protocol does not support requesting telemetry, so there is no way to tell ESC to send it. If you would like to make use of the full feature set of the esc, you should use our UART communication protocol, which offers the benefits that you are looking for.
Are you able to tell me what flight controller software you are using? Our ESC uart protocol is open and can be included into any flight controller.
I try reducing the pulse next.We use ArduPilot with an external flight controller.
It would be nice to use the ESC UART protocol directly from the FC.
Having ArduPilot work on the VOXL 2 mini would be even better. -
Hello @JP-Drone ,
- vbat_nominal_mv
- motor_kv
@Alex-Kushleyev Reading through this thread and access to the PWM output without using the VOXL IO board would definitely be of interest for my team, any chance the full sized VOXL ESC would have a similar capability using its AUX outputs?
@Jeremy-Frederick, can you specify which ESC you are asking about?
The PWM pins on the ModalAI ESCs (which have the pwm signals on a connector or test pads) are bi-directional, and yes they could be used as PWM output. However, a firmware change is required and enabling PX4 to send out PWM signals is another change
We were considering enabling this feature but it is not yet implemented. Can you please provide more information about your requirements?
- what type of PWM signal are you trying to send ? min/max range, update frequency, (is it one shot, or just preriodic)
- how often are you planning to update the value of this PWM signal?
- how many PWM signals do you need?
- what is the source for the control of PWM signal in your application (RC or something else?). The reason why I am asking, the ESC would need to receive a serial data packet from
voxl_escdriver in px4, so somehow that pwm output information would need to enter thevoxl_escdriver.
