@tom would you recommend using a text editor like Vim and restarting the service or is there a better way to do it?
Joshua Ermias
@Joshua Ermias
Low stability in qvio due to low number of features -
Low stability in qvio due to low number of features@Erez-Nehama What command did you type in to increase the "ae_desired_msv"? I've tried using voxel-camer-server and voxel-send-command but neither let me change that value directly @Chad-Sweet
Calibrating Stereo Cams for DFSHey team! I tried calibrating the stereo pair on my VOXL Cam (v1) but I’m nat able to see anything on the disparity view or on the 3D view
https://docs.modalai.com/calibrate-cameras/
The live stream from the cameras look very clear and it is hard mounted according to documented procedure.
Any thoughts?
