Jonathan JeffJ
Jonathan Jeff
@Jonathan Jeff
  • ALTİTUDE MODE
    Jonathan JeffJ Jonathan Jeff
    After I set the parameter called ekf2_aid mask to 329, I lift the drone to the open air and after about 10 meters it enters the "land-altitude" mode and "no local position" warning appears even though it has gps. When I set the "ekf2_aid mask" parameter to default, there was no problem.what could be problem?
  • voxl-camera-server
    @Jonathan-Jeff Sorry for my late reply, unfortunately I noticed that the cable broke.
    I can't find what is causing the problem.
    my camera is broken and i am getting this error.
  • VIO FLİGHT
    @Chad-Sweet This is the first time I have encountered this problem, I have not encountered it before, I tested it 1-2 times in this way and there was no problem. It is a sudden situation. While passing over GPS, the camera gives correct data, but when we write over GPS stop mavlink, it gives failsafe.
  • VIO FLİGHT
    There are pauses in the VIO system.When the VIO system is activated, it stops after a certain distance.When I look at the local_position messages the data is not visible.
  • VOXL GLOBAL SHUTTER CAMERA
    can we change the flight controller camera which is inside flight deck
  • VİO
    I integrated it on the drone, the drone sees its feet and motors, does that affect it?
  • VİO
    If something is in front of our camera, will it affect the VIO navigation?
