jacob yaacubovJ
jacob yaacubov
@jacob yaacubov
  • Fixed pose via /run/mpa/vvhub_fixed_pose_input in addion to Open Vins
    jacob yaacubovJ jacob yaacubov
    Hi guys,
    We were using SDK 1.1.3, where we used the QVIO+ our pos fix (Only Z axis) to fly, so in addition to QVIO also used our own nav stack. Our fixed position was sent via a pipe to the modalai VISION-HUB
    we sent the fix pose
    to the
    it wokred well we flew hundreds of times with this setup were we publish to the fix pose pipe, fix the position of the drone and remove accumulated drift by the QVIO
    in the vision-hub .conf we have:
    set the fixed_frame_filter_len: 1 - cause we usually fix the position once in few seconds using tags.
    set the en_transform_mavlink_pos_setpoints_from_fixed_frame: true
    But now, after using the new DK 1.4.0 and using OPEN VINS + our fix it still works but occasionally our drone crashes we investigated and seems this fix might be responsible (we doubled check THE VALUES they were good )
    1. does the Open vins works well when we also publish to the /run/mpa/vvhub_fixed_pose_input?
    2. any major changes to VISION-HUB that could make its buffer full or something or race with conflicting positions between the fixed pipe and local pipe from open vins that can cause it maybe take an old fix of ours ?
      We had this warning which might be related to crash
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.208726
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.208766
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.208140
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.206414
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.202729
    Jan 07 17:29:36 BALD voxl-open-vins-server[17387]: INFO: MAYBE ON GROUND, POSITION LOCK? -- INVOKE ESTOP! (This is just a warning) 0.000000 0.000000 -15.197531
    VOXL SDK and Software mpa
  • VOXL2 usb camera support
    @Eric-Katzfey
    Hi thanks for replying still have not chosen a model for the sensor since we are not sure its possible
    the configuration we need is two USB cam any suggestions? do you offer USB host expansion module so i can connect 2 UVC sensors ?
    Hi Couldn't really find info on this
    Does the voxl2 or the modal dev drones supports camera other then the one featured as the official sensors ..
    I ask about USB connection cameras mainly
    currently we use 2 IMX412 sensors and would like to use other one which do not have same connector and of the box support is this possible?
  • px4 params flow to autopilot
    on the voxl2 qrb5165 there is this folder
    /data/px4/param
    holding the PX4 parameters and calibration
    sometimes at bootup the QGC says all parameters lost
    seems that on each flight those params are being modified
    I want to solve this issue of calibration & params loss by the px4
    I will appreciate a short explanation of how the voxl-px4-params data is flowing on the device
    my guess is params shall be set and saved via QGC later the VOXL will pull them from the autopilot on each flight to /data/px4/params is this the case ?
    thank you !
  • Mavlink server configuration of ports wont work
    @Eric-Katzfey
    Thanks for the replay
    I understand the IP isolation indeed this how I expect this to work
    well to answer this I have these weird issues
    When QGC is connected only to a single drone the attitude indicator jump between the values of the two drones - hence the home position jumps and the drone refuses to take off
    switching one of them off and rebooting the second makes the second one work well when alone on the network
    1. when looking at the ROS topic which is reading from the MPA - (qgc is off at this stage )
    the local pose values jumped as well, at first I didn't understand why, but then I realized it was getting one value from drone A second From drone B
    both drones run same voxl2 with same SDK 1.1.3
    same packages and branches on both
    tried to play with MAV_SYS_ID param maybe its mavlink issue
    kind of confused
    both ros master run on 127.0.01 so its local ros communication looks more like mavlink issue not sure though
    Hi all,
    you've ben very helpful i have an issue with mavlink-server / Voxl-px4-parameters
    I have an issue with mavlink-server I tired to change the config files
    	"onboard_port_from_autopilot":	14557,
    	"gcs_port_to_autopilot":	14558,
    	"gcs_port_from_autopilot":	14559,
    I want to change it cause when using two drones or more , it seems like Mavlink comms are interfering between (both connected to same network when it occurs )
    each other, and I want to isolate each in its own domain
    I changed the config file but that makes the mavlink-server not to pass any data between the autopilot and the voxl px4
    voxl-mavlinke-inspect
    this passes no data from autopilot or to autopilot
    I think or guess this happens since the ports are hardcoded in the firmware
    I tried to cahnge parameters
    MAV_0_UDP_PRT
    MAV_1_UDP_PRT
    but they don't even exist on the params list of modalais voxl2 qrb5165
    any suggestions how to isolate each drone? or to add those parameters?
    how to add the paramers without recompiling the px4-firmware ?
    i will appreciate your help having trouble flying more than one drone at each moment hinders my work
    Best Regard
    Jacob
  • Hires With AprilTags
    @Alex-Kushleyev yes seems like it, thank you!
    Autonomy: VIO, Mapping and Navigation apriltag
    @Alex-Kushleyev
    basically the consumer is the vision hub
    specifically [https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/v1.7.3/src/geometry.c?ref_type=tags](link url)
    as far as i understood
    and i am trying to fix the right part
    the issue lies in this transformation i marked red .. i think i need to change the cam_wrt_to_imu since it looks like
    the code assumes my hires in looking forward of the drone while its actually mounted on the right side ( Local frames Y axis)
    so tag works well and detection of my tag on fixed is Ok but when afterwards drown is moving with just qvio without tag the axis are flipped
    voxl-vision-hub -g output
    example
    y can see that fixed_wrt_local x=-0.83 while it corresponds to the local_wrt_fixed y= 0.83 so the frames i get from both arrow in the pic above are not the same do you have suggestions where should i start with , should i modify the geometry.c?
    @jacob-yaacubov the picture describes TOP VIEW the tag is attached to a wall
    Hi guys i have a hires IMX412 mounted on my drone , my camera is looking to the right side of the drone (Positive y axis on the local frame)
    I have configured the tag rotation matrix from tag to fixed correctly my tag is hanged on the wall.
    but seems the drone rotating 90 degrees CCW, I guess its doing this since it assumes the camera which is catching the tag, is mounted at the front
    hence, when right side camera sees the tag it rotates to the left (ccw) to "fix" this!
    I tried to add extrinsics to extrinsics.conf both from IMU to hires and from body to hires with the correct camera name (which used in voxl-camera-server)
    but it has no effect
    any one had this issue ? any suggestions ? does the voxl code is really taking into account that tags are seen only in front of the drone (X axis)
    Thanks
  • mpa_to_ros crashes When echoing HIRES
    Hi, Hope its the correct thread for this question.
    I use ROS on my drones system and have launched mpa_to_ros.
    my drone has two HIRES cameras (imx 412) apart for tracking
    when trying to rosbag record both of them or even echo to both topics the voxl-map-to-ros crashes
    i tried to echo different hires topics and even dropped the quality to 1024x768, even 800x600
    this doesn't happen with one topic but but only both doesn't matter if its small color or large raw format i am trying to echo
    i will appreciate any help on the matter
    Thanks
    here is the crash output:
    MPA to ROS app is now running
    Found new interface: hires2_color
    Found new interface: hires2_grey
    Found new interface: hires2_small_color
    Found new interface: hires2_small_encoded
    Found new interface: hires2_small_grey
    Found new interface: hires_color
    Found new interface: hires_grey
    Found new interface: hires_small_color
    Found new interface: hires_small_encoded
    Found new interface: hires_small_grey
    Found new interface: tracking[voxl_mpa_to_ros_node-1] process has died [pid 12947, exit code -11, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/opt/ros/foxy/log/d48631fa-3f7f-11ef-9105-97639b9c163b/voxl_mpa_to_ros_node-1.log].
    log file: /opt/ros/foxy/log/d48631fa-3f7f-11ef-9105-97639b9c163b/voxl_mpa_to_ros_node-1*.log
    all processes on machine have died, roslaunch will exit
    /usr/bin/voxl-list-pipes: line 35: echo: write error: Broken pipe
    /usr/bin/voxl-list-pipes: line 38: echo: write error: Broken pipe
    /usr/bin/voxl-list-pipes: line 32: echo: write error: Broken pipe
    shutting down processing monitor...
    ... shutting down processing monitor complete
    done
    GONI:/data/wds/bags$ /usr/bin/voxl-list-pipes: line 35: echo: write error: Broken pipe
    Also sometimes it expects on size of data lets say 1444000 bytes but gets 12000000000
  • VOXL2 WIFI KIT mismatch
    @Vinny i have received the new adapter few days ago thank you
    @Vinny Yes just received it this week i have 3 of them
    the order #4937
    Hi Guys we ordered 3 units of MDK-M0151-1-02 and received a usb 2 cable which not fits to the USB 3 connector (pic below)
    i received cable
    USB 2 MXBL-00041-1 instead of MCBL-00022-2: 10-pin JST to USB3 Type A Female Cable (70 mm)
    is there a way to establish a wlan connection like this ?
  • voxl-px4 service pipeline uORB failure
    @Eric-Katzfey i tried this now
    i reinstalled 1.1.3 and even tried again to reinstall 1.0.0
    i used different px4 parameters file backed up by me
    and still get error in the px4 service
    i cant even see my drone in the ground control seems like something seriously wrong with px4 any other suggestions ? @Eric-Katzfey
    ● voxl-px4.service - px4
       Loaded: loaded (/etc/systemd/system/voxl-px4.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2024-04-14 11:55:27 UTC; 3min 38s ago
      Process: 12036 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
     Main PID: 12042 (voxl-px4)
        Tasks: 15 (limit: 4915)
       CGroup: /system.slice/voxl-px4.service
               ├─12042 /bin/bash /usr/bin/voxl-px4
               ├─12045 px4 -d -s /usr/bin/voxl-px4-start
               ├─12062 /bin/sh /usr/bin/voxl-px4-start 0
               └─13882 px4-qshell --instance 0 ekf2 start
    Apr 14 11:58:19 m0054 voxl-px4[12042]: ERROR [qshell] command timed out
    Apr 14 11:58:19 m0054 voxl-px4[12042]: ERROR [qshell] Command failed
    my voxl2 which is running on dev drone is failing to communicate with the PX4
    i use the 1.0.0 SDK
    systemctl status voxl-px4 gives this
    PORT:/etc/modalai$ systemctl status voxl-px4.service
       Active: active (running) since Thu 2024-04-11 18:14:47 IDT; 9s ago
      Process: 18235 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
     Main PID: 18358 (voxl-px4)
        Tasks: 13 (limit: 4915)
               ├─18358 /bin/bash /usr/bin/voxl-px4
               ├─18365 px4 -d -s /usr/bin/voxl-px4-start
               ├─18886 /bin/sh /usr/bin/voxl-px4-start 0
               └─18956 px4-param --instance 0 load
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] orb_publish failed parameter_update
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] Error Sending [parameter_client_set_value_request] topic data over comm_channel
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO1_PRIO
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] Error Sending [parameter_update] topic data over comm_channel
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO2_PRIO
    looks like no parameters passed successfully to pxs4 dsp - the parameters were unchnged so it not related to their content
    itried to restart various services but it doenst help
    i compared the config files to other working drone
    nothing helped shall i reinstall the sdk
  • voxl_mpa_to_ros2 camera_interface timestamp
    @Alex-Kushleyev i have used the dev branch in the voxl-mpa_to_ros2
    and this branch has a fix , built it from source
    VOXL SDK and Software ros
    Hi guys sorry for getting this thread up again,
    i am experiencing same issue with my cameras and qvio ros2 topics
    time stamp rests after few seconds , time stamp of seconds stays at zero
    sec 0  STUCK AT ZERO
    nsec 3300161870  REACHING TO 3 BILLION (3 SECONDS)
    frame_id "tracking"
    height 480
    width 640
    encoding "mono8"
    is_bigendian 0
    step 640
    any fixes that match SDK 1.1.3 ?
  • VOXL2 Camera Configuration 2XHires + Tracking
    @Alex-Kushleyev
    Thank You, i understand makes things clearer now
    since you mention software still does not support this...
    how complicated and even if its possible on my side to open J6 or J8 for One More single camera , or one more stereo??
    since i see there is two different ID_SLOTS on them which make me wonder
    question 2:
    regarding the previous setup you inspected 2 X HIRES (5hz) J7 and 2 X Stereo (30hz) J6, J8
    on the hires, we process the raw8 (yuv) format at 5hz (plan maybe at 3hz)
    based on what you checked whats your verdict will the mpa support this or is this a stretch?
    @Alex-Kushleyev
    Great i understand thank you very much, i understand
    the most extreme case i need to check is the following :
    two hi-res IMX214 sensor working at 5hz
    2 sets of stereo ov7251 VGA - ( front & rear) - 30hz
    1 - tracking - 30hz
    this is just one more HI-RES that the max you suggested
    i plan to use the Dual Image Sensor Expander to
    group 0 - 1 x Stereo , 1 x Tracking
    group 1 - 1 x HI-RES, 1 x Stereo
    group 2 - 1 x HI-RES
    if this is possible it will be great
    Again Thanks for the quick response
