Isabella YuI
Isabella Yu
@Isabella Yu
  • Subscribe to voxl_mpa_to_ros topics
    Isabella YuI Isabella Yu
    @Matt-Turi how would I manually start /run/mpa/tflite_data? I switched to a different m500 and started voxl-tflite-server, but there appears to be no /run/mpa/tflite_data pipe, only the /run/mpa/tflite pipe. The model I'm using is the default MobileNetV2 object detection model for VOXL, and I reset the drone to factory defaults using voxl-configure-tflite
    General Questions ros
  • voxl-tflite-server abort
    @Matt-Turi Yep, turns out switching to wall power fixed it. My battery power was too low. Thanks!
    @Matt-Turi that did reinstall voxl-tflite-server 0.1.8, but still having the abort issue.
    voxl-version gives the same output, and voxl-inspect-services -v says the version of voxl-tflite-server is 0.1.8 as expected
    @Matt-Turi I downloaded voxl-tflite-server_0.1.8.ipk from http://voxl-packages.modalai.com/stable/, pushed it to the drone via adb, and ran opkg install voxl-tflite-server_0.1.8.ipk. However, it seems that 0.1.8 is already installed:
     * opkg_prepare_file_for_install: Refusing to load file 'voxl-tflite-server_0.1.8.ipk' as it matches the installed version of voxl-tflite-server (0.1.8).
    I tried installing version 0.2.0 from dev instead, but it requires upgrading libmodal_pipe, libmodal_json, and voxl-opencv and I don't really want to do an upgrade right now in fear of breaking things 😞
    @Matt-Turi I actually don't have a custom version running, so I don't know how that happened. I'll reinstall voxl-tflite-server from the voxl packages page and see if that fixes things
    @Matt-Turi
    Here's the output of voxl-version
    cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
    system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
    kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
    factory-bundle:  1.0.1 (Yocto installation)
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.5.0
    Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-cpu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-server (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>= 2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
    Status: install user installed
    Architecture: all
    Installed-Time: 2166
    Here's the output of `voxl-inspect-services -v"
     Service Name          |  Version  |  Enabled  |   Running   |  CPU Usage
     docker-autorun        |    1.1.3  |  Enabled  | Not Running | Not Running
     docker-daemon         |    1.1.3  |  Enabled  |   Running   |     1.0
     modallink-relink      |   0.12.0  | Disabled  | Not Running | Not Running
     voxl-camera-server    |    0.8.1  |  Enabled  |   Running   |     7.1
     voxl-cpu-monitor      |    0.2.0  |  Enabled  |   Running   |     0.0
     voxl-dfs-server       |    0.2.2  |  Enabled  |   Running   |     8.0
     voxl-drogon-detector  |    0.3.4  | Disabled  | Not Running | Not Running
     voxl-imu-server       |    0.9.1  |  Enabled  |   Running   |     4.4
     voxl-modem            |   0.12.0  | Disabled  | Not Running | Not Running
     voxl-portal           |    0.1.2  |  Enabled  | Not Running | Not Running
     voxl-qvio-server      |    0.3.4  |  Enabled  |   Running   |     0.0
     voxl-streamer         |    0.2.6  | Disabled  | Not Running | Not Running
     voxl-tag-detector     |    0.0.2  |  Enabled  | Not Running | Not Running
     voxl-tflite-server    |    0.8.5  |  Enabled  | Not Running | Not Running
     voxl-time-sync        |    0.9.5  | Disabled  | Not Running | Not Running
     voxl-vision-px4       |    0.8.5  |  Enabled  |   Running   |     4.0
     voxl-wait-for-fs      |           |  Enabled  |  Completed  |  Completed
    I'm trying to run voxl-tflite-server on an m500, but when I run the command, this is the output:
    skip_n_frames:                    5
    model:                            /usr/bin/dnn/ssdlite_mobilenet_v2_coco.tflite
    input_pipe:                       /run/mpa/hires/
    ------VOXL TFLite Server------
    Aborted
    I tried running voxl-configure-tflite again, but same result. My configuration file from /etc/modalai/voxl-tflite-server.conf looks like this:
     * This file contains configuration that's specific to voxl-tflite-server.
     * skip_n_frames - how many frames to skip between processed frames. For 30hz
     *                   input frame rate, we recommend skipping 5 frame resulting
     *                   in 5hz model output.
     * model         - which model to use. Currently support mobilenet for
     *                   object detection or midas for monocular depth
     * input_pipe    - which camera to use (tracking or hires).
            "skip_n_frames":        5,
            "model":        "/usr/bin/dnn/ssdlite_mobilenet_v2_coco.tflite",
            "input_pipe":   "/run/mpa/hires/"
  • docker load -i roskinetic-xenial-opencv.tar gives no such file or directory error
    Actually, using docker import fixed it, nvm!
    I'm trying to build a customized version of the roskinetic docker image mentioned in the docs. I added opencv, cv_bridge, and other misc dependencies to the roskinetic-xenial docker image by installing them with apt inside the image, committing the changes to a new image (roskinetic-xenial:opencv), running docker save roskinetic-xenial:opencv > roskinetic-xenial-opencv.tar, and running adb push roskinetic-xenial-opencv /data/. I get this error when I run docker load -i roskinetic-xenial-opencv.tar inside /data/:
    Error response from daemon: open /data/tmp/docker-import-737782374/repo/a36ddef81cb09cd9fa7749e7d29fe7ff252301cb330d369f05648c681e726448/layer.tar: no such file or directory.
    I tried deleting the contents of /data/tmp and restarting VOXL to no avail. I was able to get the original roskinetic-xenial:v1.0 docker image running following the docs linked above, but for some reason, this customized docker image isn't loading.
    Thanks! I'll try this out
    I'm writing a C++ ros node to do 3D object detection using AiDetectionMsg and the pointcloud generated from the stereo camera. How would I subscribe to the AiDetection topic in my code? I couldn't find the topic name via rostopic list. I tried doing
    #include <voxl_mpa_to_ros/AiDetection.h>
    but running catkin build gives a not found error.
  • /camera_info in voxl_mpa_to_ros
    Re: Publishing /camera_info topic from voxl_mpa_to_ros
    Bumping this; is there a way to publish the /camera_info topic via voxl_mpa_to_ros? If not, should I create my own node for that after I've calibrated the cameras?
  • Cannot connect host computer to VOXL SoftAP
    Ayy same problem, also hi drew
