  3. voxl-tflite-server abort
11 Posts 2 Posters 2.5k Views
  • ? Offline
    Hi @Isabella-Yu,
    Could please share the output of running voxl-version and voxl-inspect-services -v? It would also be good to know if the voxl-tflite-server code has been modified in any way.
    Isabella YuI 1 Reply Last reply
    • ? A Former User
      Hi @Isabella-Yu,
      Isabella YuI Offline
      Isabella Yu
      @Matt-Turi
      Here's the output of voxl-version
      cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
      system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
      kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
      factory-bundle:  1.0.1 (Yocto installation)
      architecture:    aarch64
      processor:       apq8096
      os:              GNU/Linux
      voxl-suite:
      Package: voxl-suite
      Version: 0.5.0
      Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-cpu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-server (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>= 2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
      Architecture: all
      Installed-Time: 2166
      Here's the output of `voxl-inspect-services -v"
       Service Name          |  Version  |  Enabled  |   Running   |  CPU Usage
       docker-autorun        |    1.1.3  |  Enabled  | Not Running | Not Running
       docker-daemon         |    1.1.3  |  Enabled  |   Running   |     1.0
       modallink-relink      |   0.12.0  | Disabled  | Not Running | Not Running
       voxl-camera-server    |    0.8.1  |  Enabled  |   Running   |     7.1
       voxl-cpu-monitor      |    0.2.0  |  Enabled  |   Running   |     0.0
       voxl-dfs-server       |    0.2.2  |  Enabled  |   Running   |     8.0
       voxl-drogon-detector  |    0.3.4  | Disabled  | Not Running | Not Running
       voxl-imu-server       |    0.9.1  |  Enabled  |   Running   |     4.4
       voxl-modem            |   0.12.0  | Disabled  | Not Running | Not Running
       voxl-portal           |    0.1.2  |  Enabled  | Not Running | Not Running
       voxl-qvio-server      |    0.3.4  |  Enabled  |   Running   |     0.0
       voxl-streamer         |    0.2.6  | Disabled  | Not Running | Not Running
       voxl-tag-detector     |    0.0.2  |  Enabled  | Not Running | Not Running
       voxl-tflite-server    |    0.8.5  |  Enabled  | Not Running | Not Running
       voxl-time-sync        |    0.9.5  | Disabled  | Not Running | Not Running
       voxl-vision-px4       |    0.8.5  |  Enabled  |   Running   |     4.0
       voxl-wait-for-fs      |           |  Enabled  |  Completed  |  Completed
      • ? Offline
        It looks like you have a custom version of voxl-tflite-server running - voxl-inspect-services shows v0.8.5 and we are currently at v0.2.7. Is this correct?
        • ? A Former User
          Isabella Yu
          @Matt-Turi I actually don't have a custom version running, so I don't know how that happened. I'll reinstall voxl-tflite-server from the voxl packages page and see if that fixes things
          • ? Offline
            Please let me know if that resolves the issue!
            • ? A Former User
              Isabella Yu
              wrote on last edited by Isabella Yu
              @Matt-Turi I downloaded voxl-tflite-server_0.1.8.ipk from http://voxl-packages.modalai.com/stable/, pushed it to the drone via adb, and ran opkg install voxl-tflite-server_0.1.8.ipk. However, it seems that 0.1.8 is already installed:
               * opkg_prepare_file_for_install: Refusing to load file 'voxl-tflite-server_0.1.8.ipk' as it matches the installed version of voxl-tflite-server (0.1.8).
              I tried installing version 0.2.0 from dev instead, but it requires upgrading libmodal_pipe, libmodal_json, and voxl-opencv and I don't really want to do an upgrade right now in fear of breaking things 😞
              • ? Offline
                To force a fresh installation when it is the same version you have loaded, you can give opkg the flag: --force-reinstall to reinstall without needing to upgrade. The full command then would be:
                opkg install voxl-tflite-server_0.1.8.ipk --force-reinstall
                • ? A Former User
                  Isabella Yu
                  @Matt-Turi that did reinstall voxl-tflite-server 0.1.8, but still having the abort issue.
                  voxl-version gives the same output, and voxl-inspect-services -v says the version of voxl-tflite-server is 0.1.8 as expected
                  • ? Offline
                    @Isabella-Yu,
                    I flashed a VOXL with the 3.3.0 system image and installed voxl-tflite-server v0.1.8 but was unable to recreate the abort issue you are seeing. voxl-tflite-server is a very power-hungry application, and I have seen issues like this arise from a bad apm/power connection to the drone. If this is not the cause, it may be worth attempting to reflash your system after backing up any important files. The latest stable release for voxl is VOXL Platform 3.8.0-0.7.
                    • ? A Former User
                      @Isabella-Yu,
                      Isabella Yu
                      @Matt-Turi Yep, turns out switching to wall power fixed it. My battery power was too low. Thanks!
